Starting and stopping a demo module
Hello,
how do I start and stop the demo module in the Voiceguide (other than the Script Designer)? Even when I remove a string in the configuration file, the Credit Card demo module starts running seemingly by itself. Is it possible that I am not able to place an outbound call because the demo module is running on the same port?
Thanks.
The "Default Script" setting that shows in the line Status Monitor indicates the script that will be used should an incoming call arrive on that channel.
It is unrelated to outgoing calls, and does not prevent making of outgoing calls.
