Result Variables Not Set
I've noticed that sometimes some of the result variables are not set on outgoing calls. Specifically, the $RV_STARTTIME is set to an empty string, and $RV_CALLLENGTH is set to 0, well after the call has started. This seems to occur randomly -- sending out the same call using the same script will work one time, but not the next time. It seems to occur more often with calls answered by an answering machine, but it has occurred with those answered by a human as well.
We currently have the outgoing calls setup to use different scripts depending on whether or not an answering machine answered the call. Each script plays a different wave file, hangs up the call, and runs another VG script. This third script contains a single VB script module that writes the call start time and length to a file. It parses the date using MyDate = CDate("$RV_STARTTIME"). When it reaches that line, VG gives a runtime error if the $RV_STARTTIME variable is not set, since the line would be run as MyDate = CDate(""). It works fine if the variable is set, however.
I've tried having the VB script duplicated in both scripts (instead of running a separate VG script when the call is finished) before and after the hangup time, and they all exhibit the same behavior. Any thoughts?
$RV_STARTTIME etc should be getting set at start of every call.
I've included the VG scripts that were used as a separate file. Below is what I received in the event log while running a test call to an answering machine (cell phone voice mail):
085600.61 5 dial [748,3034753383,404230856,0,2359,MoTuWeThFrSaSu,,,dxxxB1C1,dxxxB1C2,,,1,,C:\data\testscripts\dialout.vgs,C:\data\testscripts\dialout_ansmach.vgs,[Message]{C:\data\testscripts\messages\call10037.wav}[CRID]{490}[AttemptID]{103}[Message2]{C:\data\testscripts\messages\call10037_2.wav},60,0,1,C:\data\testscripts\endofcall103.vb script:[C:\data\testscripts\endofcall.vgs]
085622.23 0 LoadedVgs_Find C:\data\testscripts\endofcall.vgs at idx=3
085622.24 5 TimeoutClear
085622.25 5 [updateStatus] Running VB Script...
085622.26 5 RVreplace start (strlen>500)
085622.27 5 RVns [Message]{C:\data\testscripts\messages\call10037.wav}[CRID]{490}[AttemptID]{103}[Message2]{C:\data\testscripts\messages\call10037_2.wav}[OutDial_RetriesLeft]{0}[scriptEnd_Time]{4/23/2004 8:56:19 AM}[scriptEnd_Goto_Script]{C:\data\testscripts\dialout_ansmach.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{4/23/2004 8:56:19 AM}[scriptStart_CalledFrom_Module]{UpdateStatus}[scriptsPath]{C:\data\testscripts\}[isAnsMach_Input]{true}[isAnsMach]{True}[isAnsMach]{True}[Hangup Time]{4/23/2004 8:56:22 AM}
085622.31 5 Run Script waiting... (shellid=1672, process=1328)
085622.32 5 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
085622.33 5 tapi Reply (LineEvReply) ok 65809 0
085623.24 5 Timer fired EV_TIMEOUT_CHECKONSTATE
085623.25 5 ScriptEventCode 9007 iLineState=1501
085623.26 5 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
085623.28 5 task still running (shellid=1672, process=1328)
085623.29 5 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
085624.30 5 Timer fired EV_TIMEOUT_CHECKONSTATE
085624.31 5 ScriptEventCode 9007 iLineState=1501
085624.32 5 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
085624.33 5 task still running (shellid=1672, process=1328)
085624.34 5 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
085625.35 5 Timer fired EV_TIMEOUT_CHECKONSTATE
085625.36 5 ScriptEventCode 9007 iLineState=1501
085625.37 5 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
085625.38 5 task still running (shellid=1672, process=1328)
085625.39 5 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
085626.40 5 Timer fired EV_TIMEOUT_CHECKONSTATE
085626.41 5 ScriptEventCode 9007 iLineState=1501
085626.42 5 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
085626.43 5 task completed (shellid=1672, process=1328)
085626.44 5 No information returned from program to VG (no VGRUNRESULT_5.TXT or SHLRESLT.TXT)
085626.45 5 rv add [Hangup Time]{4/23/2004 8:56:26 AM}
085626.46 5 Hanging up call... [WaitTillFinished - next module not specified]
085626.47 5 HangupCall_Common Mode=AfterHangupRun
085626.48 5 ReinitTelephony due to IDLE
085626.50 5 tapic lineDeallocateCall(MainCall:65826) 0
085626.68 5 lineOpen(5)=>
085626.70 5 Waiting for a call...
085626.71 5 LineHandle=65792
085626.71 5 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
085629.73 5 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
085629.75 5 ScriptEventCode 9013 iLineState=900
scripts.txt
Looks like $RV_STARTTIME was not getting set when an outgoing call was being answered by an Answering Machine (it was set on other calls).
Please place attached .exe in the VoiceGuide directory, overwriting previous file. The $RV_STARTTIME will now be set on calls answered by answering machine as well.
VgMulti_5.2.1032.zip
The update works well for $RV_STARTTIME, but $RV_CALLLENGTH is still being set to 0. The test we're sending out lasts around 20 seconds.
