Transfer Path To Different Script
Im using the evaluation version of voice guide. We have a seperate script that plays when an answering machine answers the phone on an outbound call. The script has an option to press 1 just in case a real person is mistaken for an answering machine which will then transfer them over to the main script. For some reason no matter how many times you press 1 it wont transfer over to the new script.
I've tried changing the goto commmand to gosub to see if that works and it doesnt. Your help would be appreciated the log is below
144822.53 0 cl Dialer_OutDialQueAdd 93318320, 0, 0, 0, , , 1, C:\BookingAngel\AcceptAutoCall.wav, C:\BookingAngel\Main.vgs, C:\BookingAngel\Callback.vgs, [bID]{183}[bAttempt]{1316}[Offset](-10}, 0, 0, 0, C:\BookingAngel\NoConnect.vgs,
144822.53 0 DialListDB_AddCall '93318320', 0, 0, 0, MoTuWeThFrSaSu, , 1, C:\BookingAngel\AcceptAutoCall.wav, C:\BookingAngel\Main.vgs, C:\BookingAngel\Callback.vgs, [bID]{183}[bAttempt]{1316}[Offset](-10}, 0, 0, 0, C:\BookingAngel\NoConnect.vgs ESCALATION:
144822.80 5 dial [194,93318320,0,0,2359,MoTuWeThFrSaSu,,,,1,C:\BookingAngel\AcceptAutoCall.wav,C:\BookingAngel\Main.vgs,C:\BookingAngel\Callback.vgs,[bID]{183}[bAttempt]{1316}[Offset](-10},60,0,0,C:\BookingAngel\NoConnect.vgs,none]
144822.80 0 dial callque update id=194 next call time 0404191450
144822.80 0 dial callque DB update returned
144822.80 5 dial found entry: tel[93318320] ann[C:\BookingAngel\AcceptAutoCall.wav] vgs[C:\BookingAngel\Main.vgs] am[C:\BookingAngel\Callback.vgs]
144822.80 5 Dialing: 93318320
144822.80 5 MakeCall => 66428
144822.80 5 TimeoutSet 60 EV_TIMEOUT_MAKECALL_NORESPONSE
144822.80 5 TapiCbTrigSet 66428 7002
144823.34 5 tapi Reply (LineEvReply) ok 66428 0
144823.34 5 TapiCbTrigClear
144823.34 5 linedevstate 2048 0 0
144823.34 5 callstate DIALTONE 65848 0 0
144823.34 5 callstate DIALING 65848 0 0
144823.34 5 callstate PROCEEDING 65848 0 0
144823.34 5 callinfo CALLEDID
144823.34 5 callinfo REASON
144823.34 5 Lev_CallerID [0000,]
144823.34 5 callinfo ORIGIN
144835.89 5 callstate DISCONNECTED 65848,16,0
144835.89 5 ScriptEventCode 9250 iLineState=5200
144835.89 5 LsWaitAfterDialingOut EV_REMOTEPARTY_DISCONNECT
144835.89 0 dial callque delete id=194
144835.89 5 AddRVns [OutDial_Result]{Contacted_AM}
144835.91 5 AM - wait for end of welcome message...
144835.91 5 dial awaiting end of answering machine message (lvl:10 for 20)
144835.91 5 RecSoundStart file[C:\Program Files\VoiceGuide\data\RecAm_5.wav] ok
144835.91 5 TimeoutSet 120 EV_TIMEOUT_HANGUP
144840.48 5 ScriptEventCode 9300 iLineState=1152
144840.48 5 LsDialoutRecAnswerMachineWelcMsg EV_SILENCE_DETECTED
144840.53 5 RecSoundStop ok
144840.53 5 TimeoutSet 1 EV_REC_FINISHED
144840.55 5 ScriptEventCode 8003 iLineState=1152
144840.55 5 LsDialoutRecAnswerMachineWelcMsg EV_REC_FINISHED
144840.55 5 RVreplace start: [$RV[AmWelcMsg_RecLen100ms]]
144840.55 5 RVns [bID]{183}[bAttempt]{1316}[Offset](-10}[OutDial_RetriesLeft]{0}
144840.55 5 RVreplace end: []
144840.55 5 am msglen=0, minrequired=10
144840.55 5 Run Answer Machine script [C:\BookingAngel\Callback.vgs]
144840.55 2 tr NewVgsVgm_Goto C:\BookingAngel\Callback.vgs,,,,,0
144840.55 5 rv add [scriptEnd_Time]{19/04/2004 2:48:40 PM}
144840.55 5 rv add [scriptEnd_Goto_Script]{C:\BookingAngel\Callback.vgs}
144840.55 5 rv add [scriptEnd_Goto_Module]{}
144840.55 5 rv add [scriptStart_Time]{19/04/2004 2:48:40 PM}
144840.55 5 rv add [scriptStart_CalledFrom_Module]{Hangup}
144840.55 0 LoadedVgs_Find C:\BookingAngel\Callback.vgs at idx=4
144840.55 5 AddRVns [scriptsPath]{C:\BookingAngel\}
144840.56 5 cl NewVgsVgm_RunModule module not found:
144840.56 2 tr NewVgsVgm_Goto 1
144840.56 2 tr NewVgsVgm_Goto 2
144840.56 5 TimeoutClear
144840.56 5 [Answer Machine] Playing
144840.56 5 tts generate start[Hi, This was just Booking Angel trying to make a reservation. we have detected this call was answered by a machine. If this is an error press 1 to hear your reservation now. Otherwise call our Booking Angels on 1,3, hundred, 3,6,7,1,4,8. Thankyou, We hope to speak to you soon.]
144840.56 5 tts generate wait
144840.56 5 RunModule PLAY end
144840.56 2 tr NewVgsVgm_Goto end
144840.81 5 tts generate finish
144840.81 5 [Answer Machine] Playing (C:\Program Files\VoiceGuide\data\tts5.wav)
144840.81 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\tts5.wav]
144840.81 5 TimeoutClear
144840.81 5 wa(23143,74153100)
144904.00 5 wb(74153100)
144904.05 5 Play End line[5] (id=741531)
144904.05 5 ScriptEventCode 8001 iLineState=1100
144904.05 5 LsPlayMsg EV_PLAY_FINISHED
144904.05 5 TimeoutSet 10 EV_TIMEOUT_HANGUP
144904.05 5 TimeoutSet 5 EV_TIMEOUT_GOTOMODULE
144909.44 5 Timer fired EV_TIMEOUT_GOTOMODULE
144909.44 5 ScriptEventCode 9002 iLineState=1101
144909.44 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
144909.44 5 TimeoutClear
144909.44 5 [VB Script] Running VB Script...
144909.44 5 RVreplace start (strlen>500)
144909.44 5 RVns [bID]{183}[bAttempt]{1316}[Offset](-10}[OutDial_RetriesLeft]{0}[scriptEnd_Time]{19/04/2004 2:48:40 PM}[scriptEnd_Goto_Script]{C:\BookingAngel\Callback.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{19/04/2004 2:48:40 PM}[scriptStart_CalledFrom_Module]{Hangup}[scriptsPath]{C:\BookingAngel\}
144909.45 5 Run Script waiting... (shellid=2024, process=1848)
144909.45 5 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
144910.55 5 Timer fired EV_TIMEOUT_CHECKONSTATE
144910.55 5 ScriptEventCode 9007 iLineState=1501
144910.55 5 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
144910.55 5 task still running (shellid=2024, process=1848)
144910.55 5 Terminating process (timeout reached).
144910.55 5 TimeoutClear
144910.55 5 rv add [Hangup Time]{19/04/2004 2:49:10 PM}
144910.55 5 Hanging up call... [Hangup Module]
144910.55 5 RecSoundStop ok
144910.55 5 PlaySoundStop err=0
144910.55 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
144910.55 5 fnHangupCall end
144910.59 5 linedevstate 2048 0 0
144910.59 5 callstate IDLE 65848 0 0
144910.59 5 WorkingMode@Idle=
144910.59 5 TimeoutClear
144910.59 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
144910.59 5 tapi Reply (LineEvReply) ok 65865 0
144911.64 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE
144911.64 5 ScriptEventCode 9008 iLineState=900
144911.64 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
144911.64 5 ReinitTelephony due to IDLE
144911.64 5 tapic lineDeallocateCall(MainCall:65848) 0
144911.73 5 lineOpen(5)=>
144911.73 5 Waiting for a call...
144911.73 5 LineHandle=66019
144911.73 5 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
144915.02 5 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
144915.02 5 ScriptEventCode 9013 iLineState=900
145602.69 0 cl Dialer_OutDialQueAdd 93318320, 0, 0, 0, , , 1, C:\BookingAngel\AcceptAutoCall.wav, C:\BookingAngel\Main.vgs, C:\BookingAngel\Callback.vgs, [bID]{182}[bAttempt]{1317}[Offset](-10}, 0, 0, 0, C:\BookingAngel\NoConnect.vgs,
145602.69 0 DialListDB_AddCall '93318320', 0, 0, 0, MoTuWeThFrSaSu, , 1, C:\BookingAngel\AcceptAutoCall.wav, C:\BookingAngel\Main.vgs, C:\BookingAngel\Callback.vgs, [bID]{182}[bAttempt]{1317}[Offset](-10}, 0, 0, 0, C:\BookingAngel\NoConnect.vgs ESCALATION:
145602.95 5 dial [195,93318320,0,0,2359,MoTuWeThFrSaSu,,,,1,C:\BookingAngel\AcceptAutoCall.wav,C:\BookingAngel\Main.vgs,C:\BookingAngel\Callback.vgs,[bID]{182}[bAttempt]{1317}[Offset](-10},60,0,0,C:\BookingAngel\NoConnect.vgs,none]
145602.95 0 dial callque update id=195 next call time 0404191458
145602.95 0 dial callque DB update returned
145602.95 5 dial found entry: tel[93318320] ann[C:\BookingAngel\AcceptAutoCall.wav] vgs[C:\BookingAngel\Main.vgs] am[C:\BookingAngel\Callback.vgs]
145602.95 5 Dialing: 93318320
145602.95 5 MakeCall => 66411
145602.95 5 TimeoutSet 60 EV_TIMEOUT_MAKECALL_NORESPONSE
145602.95 5 TapiCbTrigSet 66411 7002
145603.50 5 tapi Reply (LineEvReply) ok 66411 0
145603.50 5 TapiCbTrigClear
145603.50 5 linedevstate 2048 0 0
145603.50 5 callstate DIALTONE 65659 0 0
145603.50 5 callstate DIALING 65659 0 0
145603.50 5 callstate PROCEEDING 65659 0 0
145603.50 5 callinfo CALLEDID
145603.50 5 callinfo REASON
145603.50 5 Lev_CallerID [0000,]
145603.50 5 callinfo ORIGIN
145610.17 5 callstate CONNECTED 65659,1,0
145610.17 5 WorkingModeTAPI@Connected=
145610.17 5 WorkingModeScript@Connected=
145610.17 5 rv add [bID]{182}
145610.17 5 rv add [bAttempt]{1317}
145610.17 5 rv add [Offset]{0}
145610.17 5 rv add [$RV_STARTTIME]{19/04/2004 2:56:10 PM}
145610.17 5 rv add [$RV_DEVICEID]{5}
145610.17 5 rv add [$RV_CIDNAME]{}
145610.17 5 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
145610.17 5 rv add [$RV_CALLEDNUMBER]{93318320}
145610.19 0 dial callque delete id=195
145610.19 5 AddRVns [OutDial_Result]{Contacted_Human}
145610.19 5 Live person answered, starting C:\BookingAngel\Main.vgs
145610.19 2 tr NewVgsVgm_Goto C:\BookingAngel\Main.vgs,,,,,0
145610.19 5 rv add [scriptEnd_Time]{19/04/2004 2:56:10 PM}
145610.19 5 rv add [scriptEnd_Goto_Script]{C:\BookingAngel\Main.vgs}
145610.19 5 rv add [scriptEnd_Goto_Module]{}
145610.19 5 rv add [scriptStart_Time]{19/04/2004 2:56:10 PM}
145610.19 5 rv add [scriptStart_CalledFrom_Module]{Hangup}
145610.19 0 LoadedVgs_Find C:\BookingAngel\Main.vgs at idx=3
145610.19 5 AddRVns [scriptsPath]{C:\BookingAngel\}
145610.19 5 cl NewVgsVgm_RunModule module not found:
145610.19 2 tr NewVgsVgm_Goto 1
145610.19 2 tr NewVgsVgm_Goto 2
145610.19 5 TimeoutClear
145610.19 5 [before Booking] Playing
145610.19 5 tts generate start[Hi , This is booking angel. You have a new booking. Press 1 to hear the details]
145610.20 5 tts generate wait
145610.20 5 RunModule PLAY end
145610.20 2 tr NewVgsVgm_Goto end
145610.28 5 tts generate finish
145610.28 5 [before Booking] Playing (C:\Program Files\VoiceGuide\data\tts5.wav)
145610.30 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\tts5.wav]
145610.30 5 TimeoutClear
145610.30 5 wa(6087,19100000)
145610.30 5 callinfo MONITORMODES
145616.45 5 Play End line[5] (id=191000)
145616.45 5 ScriptEventCode 8001 iLineState=1100
145616.45 5 LsPlayMsg EV_PLAY_FINISHED
145616.45 5 TimeoutSet 1 EV_TIMEOUT_REPLAYMSG
145617.53 5 Timer fired EV_TIMEOUT_REPLAYMSG
145617.53 5 ScriptEventCode 9005 iLineState=1101
145617.53 5 LsPlayMsgFinished EV_TIMEOUT_REPLAYMSG
145617.53 5 tts generate reuse
145617.53 5 [before Booking] Playing (C:\Program Files\VoiceGuide\data\tts5.wav)
145617.53 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\tts5.wav]
145617.53 5 TimeoutClear
145617.53 5 wa(6087,19825000)
145617.53 5 callinfo MONITORMODES
145622.27 0 btn Hangup on line 5
145622.27 5 ScriptEventCode 9001 iLineState=1100
145622.27 5 LsPlayMsg EV_TIMEOUT_HANGUP
145622.27 5 rv add [Hangup Time]{19/04/2004 2:56:22 PM}
145622.27 5 Hanging up call...
145622.27 5 RecSoundStop ok
145622.33 5 PlaySoundStop err=0
145622.33 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
145622.33 5 fnHangupCall end
145622.38 5 linedevstate 2048 0 0
145622.38 5 callstate IDLE 65659 0 0
145622.38 5 WorkingMode@Idle=
145622.38 5 TimeoutClear
145622.38 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
145622.38 5 tapi Reply (LineEvReply) ok 66103 0
145623.44 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE
145623.44 5 ScriptEventCode 9008 iLineState=900
145623.44 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
145623.44 5 ReinitTelephony due to IDLE
145623.44 5 tapic lineDeallocateCall(MainCall:65659) 0
145623.53 5 lineOpen(5)=>
145623.53 5 Waiting for a call...
145623.53 5 LineHandle=65676
145623.53 5 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
145626.81 5 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
145626.81 5 ScriptEventCode 9013 iLineState=900
145837.89 0 cl Dialer_OutDialQueAdd 93318320, 0, 0, 0, , , 1, C:\BookingAngel\AcceptAutoCall.wav, C:\BookingAngel\Main.vgs, C:\BookingAngel\Callback.vgs, [bID]{183}[bAttempt]{1318}[Offset](-10}, 0, 0, 0, C:\BookingAngel\NoConnect.vgs,
145837.89 0 DialListDB_AddCall '93318320', 0, 0, 0, MoTuWeThFrSaSu, , 1, C:\BookingAngel\AcceptAutoCall.wav, C:\BookingAngel\Main.vgs, C:\BookingAngel\Callback.vgs, [bID]{183}[bAttempt]{1318}[Offset](-10}, 0, 0, 0, C:\BookingAngel\NoConnect.vgs ESCALATION:
145838.02 5 dial [196,93318320,0,0,2359,MoTuWeThFrSaSu,,,,1,C:\BookingAngel\AcceptAutoCall.wav,C:\BookingAngel\Main.vgs,C:\BookingAngel\Callback.vgs,[bID]{183}[bAttempt]{1318}[Offset](-10},60,0,0,C:\BookingAngel\NoConnect.vgs,none]
145838.02 0 dial callque update id=196 next call time 0404191500
145838.02 0 dial callque DB update returned
145838.02 5 dial found entry: tel[93318320] ann[C:\BookingAngel\AcceptAutoCall.wav] vgs[C:\BookingAngel\Main.vgs] am[C:\BookingAngel\Callback.vgs]
145838.02 5 Dialing: 93318320
145838.02 5 MakeCall => 66036
145838.02 5 TimeoutSet 60 EV_TIMEOUT_MAKECALL_NORESPONSE
145838.02 5 TapiCbTrigSet 66036 7002
145838.56 5 tapi Reply (LineEvReply) ok 66036 0
145838.56 5 TapiCbTrigClear
145838.56 5 linedevstate 2048 0 0
145838.56 5 callstate DIALTONE 66275 0 0
145838.56 5 callstate DIALING 66275 0 0
145838.56 5 callstate PROCEEDING 66275 0 0
145838.56 5 callinfo CALLEDID
145838.56 5 callinfo REASON
145838.56 5 Lev_CallerID [0000,]
145838.56 5 callinfo ORIGIN
145846.69 0 btn Hangup on line 5
145846.69 5 ScriptEventCode 9001 iLineState=5200
145846.69 5 LsWaitAfterDialingOut EV_TIMEOUT_HANGUP
145846.69 5 rv add [Hangup Time]{19/04/2004 2:58:46 PM}
145846.69 5 Hanging up call... [LsWaitAfterDialingOut]
145846.69 5 RecSoundStop ok
145846.69 5 PlaySoundStop err=0
145846.70 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
145846.70 5 Waiting for a call...
145846.70 5 fnHangupCall end
145846.75 5 linedevstate 2048 0 0
145846.75 5 callstate IDLE 66275 0 0
145846.75 5 WorkingMode@Idle=
145846.75 5 TimeoutClear
145846.75 5 LineState(iLineId).iVgsIdx = 0
145846.75 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
145846.75 5 tapi Reply (LineEvReply) ok 66479 0
145847.80 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE
145847.80 5 ScriptEventCode 9008 iLineState=900
145847.80 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
145847.80 5 ReinitTelephony due to IDLE
145847.80 5 tapic lineDeallocateCall(MainCall:66275) 0
145847.89 5 lineOpen(5)=>
145847.89 5 Waiting for a call...
145847.89 5 LineHandle=65881
145847.89 5 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
145851.17 5 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
145851.17 5 ScriptEventCode 9013 iLineState=900
In the 24 seconds that the message
"Hi, This was just Booking Angel trying to make a reservation. we have detected this call was answered by a machine. If this is an error press 1 to hear your reservation now. Otherwise call our Booking Angels on 1,3, hundred, 3,6,7,1,4,8. Thank you, We hope to speak to you soon."
was playing no reports of any DTMF keypresses were reported to VoiceGuide:
BTW: we can see from:
that the TTS system took 250ms to generate a 24 second message - that's pretty good - what TTS engine/voice are you using and how fast is your computer?
I definitely was hitting 1 on the phone... just to make sure I had the system call a different phone and also got somebody on a completely different phone line who experienced the same problem. The DTMF tones were not being recognised. I retried the call again and tried pressing every key on the phone pad with no response
The logs of this are pasted below... any ideas on what might be the problem,
By the way we are using the AT& T US female voice (crystal I think) and a Asus PC-DL Deluxe i82875 Dual Xeon Motherboard + 2 x Xeon 2.6/533 CPU Bundle (so it says on the specs) Its a custom built machine designed by one of the engineers working on the project (obviously not me)
205254.77 0 cl Dialer_OutDialQueAdd 93318320, 0, 0, 0, , , 1, C:\BookingAngel\AcceptAutoCall.wav, C:\BookingAngel\Main.vgs, C:\BookingAngel\Callback.vgs, [bID]{187}[bAttempt]{1324}[Offset](-10}, 0, 0, 0, C:\BookingAngel\NoConnect.vgs,
205254.78 0 DialListDB_AddCall '93318320', 0, 0, 0, MoTuWeThFrSaSu, , 1, C:\BookingAngel\AcceptAutoCall.wav, C:\BookingAngel\Main.vgs, C:\BookingAngel\Callback.vgs, [bID]{187}[bAttempt]{1324}[Offset](-10}, 0, 0, 0, C:\BookingAngel\NoConnect.vgs ESCALATION:
205255.31 5 dial [202,93318320,0,0,2359,MoTuWeThFrSaSu,,,,1,C:\BookingAngel\AcceptAutoCall.wav,C:\BookingAngel\Main.vgs,C:\BookingAngel\Callback.vgs,[bID]{187}[bAttempt]{1324}[Offset](-10},60,0,0,C:\BookingAngel\NoConnect.vgs,none]
205255.31 0 dial callque update id=202 next call time 0404192054
205255.31 0 dial callque DB update returned
205255.31 5 dial found entry: tel[93318320] ann[C:\BookingAngel\AcceptAutoCall.wav] vgs[C:\BookingAngel\Main.vgs] am[C:\BookingAngel\Callback.vgs]
205255.31 5 Dialing: 93318320
205255.31 5 MakeCall => 66037
205255.31 5 TimeoutSet 60 EV_TIMEOUT_MAKECALL_NORESPONSE
205255.31 5 TapiCbTrigSet 66037 7002
205255.86 5 tapi Reply (LineEvReply) ok 66037 0
205255.86 5 TapiCbTrigClear
205255.86 5 linedevstate 2048 0 0
205255.86 5 callstate DIALTONE 65832 0 0
205255.86 5 callstate DIALING 65832 0 0
205255.86 5 callstate PROCEEDING 65832 0 0
205255.86 5 callinfo CALLEDID
205255.86 5 callinfo REASON
205255.86 5 Lev_CallerID [0000,]
205255.86 5 callinfo ORIGIN
205301.97 5 callstate DISCONNECTED 65832,16,0
205301.97 5 ScriptEventCode 9250 iLineState=5200
205301.97 5 LsWaitAfterDialingOut EV_REMOTEPARTY_DISCONNECT
205301.97 0 dial callque delete id=202
205301.97 5 AddRVns [OutDial_Result]{Contacted_AM}
205301.97 5 AM - wait for end of welcome message...
205301.97 5 dial awaiting end of answering machine message (lvl:10 for 20)
205301.97 5 RecSoundStart file[C:\Program Files\VoiceGuide\data\RecAm_5.wav] ok
205301.97 5 TimeoutSet 120 EV_TIMEOUT_HANGUP
205305.06 5 ScriptEventCode 9300 iLineState=1152
205305.06 5 LsDialoutRecAnswerMachineWelcMsg EV_SILENCE_DETECTED
205305.13 5 RecSoundStop ok
205305.13 5 TimeoutSet 1 EV_REC_FINISHED
205305.13 5 ScriptEventCode 8003 iLineState=1152
205305.13 5 LsDialoutRecAnswerMachineWelcMsg EV_REC_FINISHED
205305.13 5 RVreplace start: [$RV[AmWelcMsg_RecLen100ms]]
205305.13 5 RVns [bID]{187}[bAttempt]{1324}[Offset](-10}[OutDial_RetriesLeft]{0}
205305.13 5 RVreplace end: []
205305.13 5 am msglen=0, minrequired=10
205305.13 5 Run Answer Machine script [C:\BookingAngel\Callback.vgs]
205305.13 2 tr NewVgsVgm_Goto C:\BookingAngel\Callback.vgs,,,,,0
205305.13 5 rv add [scriptEnd_Time]{19/04/2004 8:53:05 PM}
205305.13 5 rv add [scriptEnd_Goto_Script]{C:\BookingAngel\Callback.vgs}
205305.13 5 rv add [scriptEnd_Goto_Module]{}
205305.13 5 rv add [scriptStart_Time]{19/04/2004 8:53:05 PM}
205305.13 5 rv add [scriptStart_CalledFrom_Module]{Hangup}
205305.13 0 LoadedVgs_Find C:\BookingAngel\Callback.vgs at idx=2
205305.13 5 AddRVns [scriptsPath]{C:\BookingAngel\}
205305.14 5 cl NewVgsVgm_RunModule module not found:
205305.14 2 tr NewVgsVgm_Goto 1
205305.14 2 tr NewVgsVgm_Goto 2
205305.14 5 TimeoutClear
205305.14 5 [Answer Machine] Playing
205305.14 5 tts generate start[Hi, This was just Booking Angel trying to make a reservation. we have detected this call was answered by a machine. If this is an error press 1 to hear your reservation now. Otherwise call our Booking Angels on 1,3, hundred, 3,6,7,1,4,8. Thankyou, We hope to speak to you soon.]
205305.16 5 tts generate wait
205305.16 5 RunModule PLAY end
205305.16 2 tr NewVgsVgm_Goto end
205305.41 5 tts generate finish
205305.41 5 [Answer Machine] Playing (C:\Program Files\VoiceGuide\data\tts5.wav)
205305.41 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\tts5.wav]
205305.41 5 TimeoutClear
205305.42 5 wa(23143,60612500)
205328.58 5 wb(60612500)
205328.63 5 Play End line[5] (id=606125)
205328.63 5 ScriptEventCode 8001 iLineState=1100
205328.63 5 LsPlayMsg EV_PLAY_FINISHED
205328.63 5 TimeoutSet 10 EV_TIMEOUT_HANGUP
205328.63 5 TimeoutSet 5 EV_TIMEOUT_GOTOMODULE
205334.05 5 Timer fired EV_TIMEOUT_GOTOMODULE
205334.05 5 ScriptEventCode 9002 iLineState=1101
205334.05 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
205334.05 5 TimeoutClear
205334.05 5 [VB Script] Running VB Script...
205334.05 5 RVreplace start (strlen>500)
205334.05 5 RVns [bID]{187}[bAttempt]{1324}[Offset](-10}[OutDial_RetriesLeft]{0}[scriptEnd_Time]{19/04/2004 8:53:05 PM}[scriptEnd_Goto_Script]{C:\BookingAngel\Callback.vgs}[scriptEnd_Goto_Module]{}[scriptStart_Time]{19/04/2004 8:53:05 PM}[scriptStart_CalledFrom_Module]{Hangup}[scriptsPath]{C:\BookingAngel\}
205334.06 5 Run Script waiting... (shellid=272, process=1848)
205334.06 5 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
205335.16 5 Timer fired EV_TIMEOUT_CHECKONSTATE
205335.16 5 ScriptEventCode 9007 iLineState=1501
205335.16 5 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
205335.16 5 task still running (shellid=272, process=1848)
205335.16 5 Terminating process (timeout reached).
205335.16 5 TimeoutClear
205335.16 5 rv add [Hangup Time]{19/04/2004 8:53:35 PM}
205335.16 5 Hanging up call... [Hangup Module]
It looks like there is an issue with DTMF detection in situations where the Dialoigc driver reports that outgoing call has been answered by an Answering Machine. It looks like the Dialogic TAPI driver disables DTMF detection in these cases for the remainder of the call...
The version of VoiceGuide which has been written for the Dialogic cards (ie: does not use the Dialogic's TAPI/Wave drivers) should not be affected by this problem.
This "Dialogic specific" version which can use Dialogic Analog cards should be available for general download in about 2 months...
I dont quite understand what you mean
you said
"The version of VoiceGuide which has been written for the Dialogic cards (ie: does not use the Dialogic's TAPI/Wave drivers) should not be affected by this problem. "
You were speaking in the past tense so how do I get a hold of a copy of the version of the software which is not affected by this. If your saying that I'm going to have to wait 2 months then how do I improve the accuracy of the dialogic's answering machine detection. Its getting it wrong about 1 in 6 times
The "Dialogic API" version for Dialogic Analog cards is not yet available for release. "2 months" is the best estimate I have although we should be able to supply you a Beta test version within a month or so.
1 in 6 times is a pretty high failure rate - it should not be anywhere near this high.
You may want to read some other peoples experiences with problematic answering machine detection and what was causing it how they resolved it:
http://voiceguide.com/forums/index.php?showtopic=1269
http://voiceguide.com/forums/index.php?showtopic=751
http://voiceguide.com/forums/index.php?showtopic=430
