Automation Error
Hi, I keep getting an automation error. when running my TTS.
Matt
145533.91  6 [Confirm] Playing
145533.91  6 RVreplace start: [The calls you want to schedule require $RV[CreditsNeeded] credits.Please press one on your phone key pad to confirm you wish to continue Or, press 2 on your phone key pad]
145533.92  6 tts generate start[The calls you want to schedule require 3 credits.Please press one on your phone key pad to confirm you wish to continue Or, press 2 on your phone key pad]
145533.92  6 ERROR 5.2.1011 RunModule:0:-2147417848:Automation error
The object invoked has disconnected from its clients. :VoiceGuide
145533.92  6 rv    add [Hangup Time]{12/04/2004 14:55:33}
145533.93  6 Hanging up call... [RunModule Error]
145533.93  6 RecSoundStop ok
145533.93  6 PlaySoundStop err=0
145533.93  6 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
145533.94  6 fnHangupCall end
145534.02  6 linedevstate 2048 0 0
145534.02  6 callstate IDLE 65963 0 0
145534.02  6 WorkingMode@Idle=
145534.02  6 TimeoutClear
145534.03  6 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
145534.03  6 tapi  Reply (LineEvReply) ok 65997 0
145534.96  6 Timer fired EV_TIMEOUT_TIMETOREINITLINE
145534.96  6 ScriptEventCode 9008 iLineState=900
145534.96  6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
145534.97  6 ReinitTelephony due to IDLE
145535.01  6 tapic lineDeallocateCall(MainCall:65963) 0
145535.28  6 lineOpen(6)=>
145535.28  6 Waiting for a call...
145535.28  6 LineHandle=66031
145535.28  6 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
145535.28  6 tts   generate finish
145535.28  6 tts   play abort as no call on line
145538.28  6 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
145538.28  6 ScriptEventCode 9013 iLineState=900
Please post the MMDDsw.txt log which captures this problems as well. MMDDsw.txt log shows what was returned from the SAPI TTS engine - where it looks like the problem is occurring.
i searched all the hard drive and this file was not found?
Anymore help will be appreicated.
Created in VoiceGuide's \log\ subdirectory - where all other log files are placed.
May want to make sure that in VG.INI's file section [Log] the SapiWrapOcx setting is set to 10.
also, the "MM" and "DD" in "MMDDsw.txt" are placeholders for "month" and "day"...
