Manipulate Numbers From Get Number Module
CHUCHU79 wrote:
In there any way to manipulate every single number obtained in the get number module?. I need to route every phone call according to the area code the caller wants to call. I tried with $RV[getnumbers's module title_1_3 or _3_1] to get just a number to start, and it didn't work.
If not, is there at least the possibility of comparing the number to a pattern using the logical 'x' which means don't care?. in other words, can I put in the evaluate expression module the $RV_[getnumber module title] and then in the paths section:
On 305xxxxxxx GOTO Module n
On 786xxxxxxx GOTO Module m
I know it doesn't work too, but my question is if there is a way to solve this problem. I hope you could help me. Thanks
You can use function "left()" in an Evaluate Expression module to just get the first 3 digits of the entered number and then branch to different module based on that result.
in the Evaluate Expression module you would just specify:
left("$RV[getnumbers's module title]", 3)
and then the paths in that module can be:
On {305} GOTO [Module x]
On {786} GOTO [Module y]
Any VB Script type expression can be evaluated using the Evaluate Expression module. The full list of functions/operators/constants/keywords etc which can be used can be found at:
http://msdn.microsoft.com/library/en-us/sc...vbscripttoc.asp
List of functions which can be used in the Evaluate Expression module:
Abs
Array
Asc
Atn
CBool
CByte
CCur
CDate
CDbl
Chr
CInt
CLng
Cos
CreateObject
CSng
CStr
Date
DateAdd
DateDiff
DatePart
DateSerial
DateValue
Day
Eval
Exp
Filter
Fix
FormatCurrency
FormatDateTime
FormatNumber
FormatPercent
GetObject
GetRef
Hex
Hour
InputBox
InStr
InStrRev
Int
IsArray
IsDate
IsEmpty
IsNull
IsNumeric
IsObject
Join
LBound
LCase
Left
Len
Log
LTrim
Mid
Minute
Month
MonthName
MsgBox
Now
Oct
Replace
RGB
Right
Rnd
Round
RTrim
Second
Sgn
Sin
Space
Split
Sqr
StrComp
String
StrReverse
Tan
Time
Timer
TimeSerial
TimeValue
Trim
TypeName
UBound
UCase
VarType
Weekday
WeekdayName
Year
Operators which can be used in Evalute Module's expressions:
Addition (+)
And
Assignment (=)
Concatenation (&)
Division (/)
Eqv
Exponentiation (^)
Imp
Integer Division (\)
Is
Mod
Multiplication (*)
Negation (-)
Not
Or
Subtraction (-)
Xor
CHUCHU79 wrote:
Thanks for the "left" fuction. I have one more question. What if I need to analize also some middle numbers. For example, the entered number is 3057863557, I can compare the 305 with the
Left([fghdkgjkh],3). What about the 786?. I know I can use two modules, but according to my program, this 786 could be at times 2 numbers or one only. Thank you.
You can use the "mid" function for that.
To extract the 3 digits starting with the 4th digit onwards you would use:
mid("$RV[getnumbers's module title]", 4, 3)
