Length Of Call Calculation
I need to get voice guide to write the length of the call to file. The problem is with my system is that the caller may hangup at any time. How can i get a run program module to execute as soon as VG detects the user has hung up?
Is their another way?
Th call log is great but only displays the call start and end, can you update the call log to display the total length?
Thanks for your help.
Regards
Dan
VoiceGuide can be instructed to run a separate script when the call has finished using the "Script Properties" option from the "Edit" menu in the Graphical Design Environment.
You can then write the call length information from that script into the log file.
See the "Call Finish" section of VG Help file. Online copy of the relevant page is here: http://www.voiceguide.com/vghelp/html/Call...ll%20Finish.htm
