Voicemail Box Manager Issues
With each version deleting the mailbox setting I am getting a workout recreating the mailboxes.
Some small issues with the interface.
1. When entering the info, the tabs jump all over. Enter will not move you.
2. You type in all the info and press the ADD button. There is no indication that the record was saved and the form is not being cleared ready for the next new record.
Thanks.
To back up the VG Voicemail Mailbox config, the file VmBoxList.xml in VoiceGuide's \data\ subdirectory should be saved before uninstalling VG. Then after installing new version of VG to restore the voicemail config that file should be copied back into the \data\ subdirectory.
There are plans to make the uninstall a bit smarter - asking user explicitly if they would like to backup their scripts and voicemail configuration.
Thanks for the comment on usability of Voicemail manager interface - we'll look into these issues.
