Vg Stops In Mid-script
It plays the closed message, then should move on to an evaluation function to find out if the particular line should accept a voicemail message. It uses a timout 0 to move from [Play Closed_2] to [Voicemail Eval]. Instead of moving to the eval, it waits several seconds then hangs up.
212110.44 6 [Play Closed_2] Playing (c:\sounds\corpimage\closed2.wav)
212110.53 6 PlaySoundStart ok [c:\sounds\corpimage\closed2.wav]
212110.53 6 TimeoutClear
212110.55 6 RunModule PLAY end
212110.56 6 wa(11389,88335900)
212110.56 6 callinfo MONITORMODES
212121.97 6 wb(88335900)
212122.03 6 Play End line[6] (id=883359)
212122.05 6 ScriptEventCode 8001 iLineState=1100
212122.06 6 LsPlayMsg EV_PLAY_FINISHED
212122.06 6 TimeoutSet 10 EV_TIMEOUT_HANGUP
212122.08 6 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
212122.08 6 ScriptEventCode 9002 iLineState=1101
212122.09 6 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
212132.97 6 Timer fired EV_TIMEOUT_HANGUP
212132.97 6 ScriptEventCode 9001 iLineState=1101
212132.98 6 LsPlayMsgFinished EV_TIMEOUT_HANGUP
212132.98 6 rv add [Hangup Time]{3/31/2004 9:21:32 PM}
212132.00 6 Hanging up call...
Could you please post a script which demonstratates the problem.
Which version of VoiceGuide is running on the system?
I fixed the problem by renaming the second module from "Voicemail Eval" to "Eval Voicemail" on the hunch that perhaps VG was trying to invoke some kind of voicemail function.
