Play Msg Before Initiating Blind Transfer
On our PBX, there is a several second delay when a caller selects a blind transfer and any call progress indication. If the line is picked up within 2 rings, the initial caller does not even hear any "ring" tones (they seem to begin at 2+ rings)
I'd like to play a short message "Please wait while your call is transferred" before initiating the blind transfer. It seems simple enough, but I have not been able to make it work.
Try 1: Insert a play module between the GET NUMBERS module and the TRANSFER module - issue is how to path from the play module to the TRANSFER module without requiring additional keys from the caller.
Try 2: Replace TRANSFER module with PLAY module, attempting to play first the msg then the hookflash sequence separated by commas - syntax issue - can both occur in the same play command?
It's my first VG app, so forgive my ignorance if this is really obvious. I searched the forum and didn't find any similar questions.
-Rick
This is the correct approach.
You should use a "on {Timeout 0} goto ..." type path.
See the "Paths" section in the "Script Design" chapter of VG help file.
Your solution worked perfectly, thanks for the lightning fast reply.
/rick
