Not Responding To # Key
Our system is no longer responding to the pound key.
We give the option to press a key for a department or press # for the voicemail system.
I have included the event trace file from a test.
I pressed # serveral times and then pressed 1 to show a working transfer.
0330vgm.txt
The trace shows that VG was advised while playing a message in module [store Open] that the # key was pressed by the caller:
142420.00 6 [store Open] Playing
142430.26 6 dtmf # (65997,35,2)
142431.79 6 dtmf # (65997,35,2)
We see in module [store Open] that the "on {#} ..." path points to a module named [VoiceMail 200] :
on {#} goto [VoiceMail 200]
could you please try naming the module something else - eg: "[VM 200]" the word "Voicemail" at the start of module name may be getting confused with the VoiceGuide Voicemail system destination paths - which are all beginning with a word "Voicemail"...
Thank you,
Changing it from "VoiceMail 200" to "VM 200" corrected it.
Must be a current version issue, this did work before.
