Recording Stoping
I have been trying to record and during the recoding I hear beeps and then it appears to start recording from scratch
this is the output from the logs (from what I can tell not timeout is set in the script
184131.11 5 ScriptEventCode 8001 iLineState=1200
184131.11 5 LsRecPlayBeep EV_PLAY_FINISHED
184131.11 5 RVreplace start: [D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\$RV[get_propid].wav]
184131.13 5 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{30/03/2004 6:40:47 PM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[intro]{1}[get_propid]{99977}[get_propid_PathTaken]{success}
record_vo]{D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\99977.wav}[record_vo_RecLen100ms]{108}[record_vo_EndRecCause]{timeout}[reco
184131.13 5 RVreplace end: [D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\99977.wav]
184131.14 5 rv add [record_vo]{D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\99977.wav}
184131.16 5 RecSoundStart file[D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\99977.wav] ok
184131.17 5 RecFile[D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\99977.wav]
184131.17 5 TimeoutSet 10 EV_TIMEOUT_GOTOMODULE
184142.02 5 Timer fired EV_TIMEOUT_GOTOMODULE
184142.02 5 ScriptEventCode 9002 iLineState=1201
184142.03 5 LsRecRecording EV_TIMEOUT_GOTOMODULE
184142.09 5 RecSoundStop ok
184142.13 5 rec length RV: record_vo_RecLen100ms = 108
184142.13 5 rv add [record_vo_RecLen100ms]{108}
184142.16 5 rv add [record_vo_EndRecCause]{timeout}
184142.17 5 ScriptEventCode 8003 iLineState=5900
184142.17 5 TimeoutClear
184142.19 5 [record_vo] Recording
184142.22 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\beep1.wav]
184142.22 5 TimeoutClear
184142.23 5 wa(186,38510900)
184142.25 5 callinfo MONITORMODES
184142.47 5 wb(38510900)
184142.48 5 Play End line[5] (id=385109)
184142.48 5 ScriptEventCode 8001 iLineState=1200
184142.50 5 LsRecPlayBeep EV_PLAY_FINISHED
184142.50 5 RVreplace start: [D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\$RV[get_propid].wav]
184142.50 5 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{30/03/2004 6:40:47 PM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[intro]{1}[get_propid]{99977}[get_propid_PathTaken]{success}
184142.52 5 RVreplace end: [D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\99977.wav]
184142.52 5 rv add [record_vo]{D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\99977.wav}
184142.55 5 RecSoundStart file[D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\99977.wav] ok
184142.55 5 RecFile[D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\99977.wav]
184142.56 5 TimeoutSet 10 EV_TIMEOUT_GOTOMODULE
184150.66 5 dtmf # (66343,35,2)
184150.67 5 ScriptEventCode 35 iLineState=1201
184150.67 5 LsRecRecording #
184150.73 5 RecSoundStopTruncBytes ok
184150.75 5 rec length RV: record_vo_RecLen100ms = 81
184150.75 5 rv add [record_vo_RecLen100ms]{81}
184150.75 5 rv add [record_vo_EndRecCause]{#}
184150.77 5 ScriptEventCode 8003 iLineState=5900
184150.78 5 TimeoutClear
184150.80 5 [replay recording] Playing
184150.80 5 RVreplace start: [D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\$RV[get_propid].wav]
184150.81 5 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{30/03/2004 6:40:47 PM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[intro]{1}[get_propid]{99977}[get_propid_PathTaken]{success}
d_vo]{D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\99977.wav}[record_vo_RecLen100ms]{81}[record_vo_EndRecCause]{#}
184150.81 5 RVreplace end: [D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\99977.wav]
184150.83 5 [replay recording] Playing (D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\99977.wav)
184150.86 5 PlaySoundStart ok [D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\99977.wav]
184150.86 5 TimeoutClear
184150.88 5 RunModule PLAY end
184150.88 5 wa(7718,39375000)
184150.94 5 callinfo MONITORMODES
184158.66 5 Play End line[5] (id=393750)
184158.66 5 ScriptEventCode 8001 iLineState=1100
184158.66 5 LsPlayMsg EV_PLAY_FINISHED
184158.67 5 TimeoutSet 10 EV_TIMEOUT_HANGUP
184158.67 5 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
184158.69 5 ScriptEventCode 9002 iLineState=1101
184158.69 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
Trace shows that script started recording in module [record_vo] :
then 8 seconds later if was reported to VG that DTMF tone "#" was heard :
Which caused VG to stop recording and go to module [replay recording] :
that might not have been the best trace to send this is another one. in this one the # key was never pressed, but it did go beep midway thru the resording
PM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[intro]{1}[get_propid]{4564}[get_propid_PathTaken]{success}[
ecord_vo]{D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\4564.wav}[record_vo_RecLen100ms]{108}[record_vo_EndRecCause]{timeout}[recor
124716.20 5 RVreplace end: [D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\4564.wav]
124716.20 5 rv add [record_vo]{D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\4564.wav}
124716.23 5 RecSoundStart file[D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\4564.wav] ok
124716.23 5 RecFile[D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\4564.wav]
124716.25 5 TimeoutSet 10 EV_TIMEOUT_GOTOMODULE
124727.31 5 Timer fired EV_TIMEOUT_GOTOMODULE
124727.31 5 ScriptEventCode 9002 iLineState=1201
124727.33 5 LsRecRecording EV_TIMEOUT_GOTOMODULE
124727.39 5 RecSoundStop ok
124727.39 5 rec length RV: record_vo_RecLen100ms = 110
124727.42 5 rv add [record_vo_RecLen100ms]{110}
124727.45 5 rv add [record_vo_EndRecCause]{timeout}
124727.47 5 ScriptEventCode 8003 iLineState=5900
124727.55 5 TimeoutClear
124727.56 5 [record_vo] Recording
124727.61 5 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\beep1.wav]
124727.61 5 TimeoutClear
124727.63 5 wa(186,53050000)
124727.64 5 callinfo MONITORMODES
124727.84 5 wb(53050000)
124727.92 5 Play End line[5] (id=530500)
124727.95 5 ScriptEventCode 8001 iLineState=1200
124727.97 5 LsRecPlayBeep EV_PLAY_FINISHED
124727.98 5 RVreplace start: [D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\$RV[get_propid].wav]
124727.98 5 RVns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{31/03/2004 12:46:37 PM}[$RV_DEVICEID]{5}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[intro]{1}[get_propid]{4564}[get_propid_PathTaken]{success}[
_vo]{D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\4564.wav}[record_vo_RecLen100ms]{110}[record_vo_EndRecCause]{timeout}
124728.00 5 RVreplace end: [D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\4564.wav]
124728.00 5 rv add [record_vo]{D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\4564.wav}
124728.03 5 RecSoundStart file[D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\4564.wav] ok
124728.05 5 RecFile[D:\inetpub\wwwroot\pphost\storage\rawPhoneMp3\4564.wav]
124728.05 5 TimeoutSet 10 EV_TIMEOUT_GOTOMODULE
Trace shows that the module [record_vo] stopped recording after around 10 seconds due to a timeout path that is defined in that module:
It looks like you have a timeout path in module [record_vo] that points back to itself...
this is the only entry under the record script module
on {#} goto [replay recording]
on {1} goto [replay recording]
OK, we'll look into this script.
In the meantime could you please try using a Timeout path in the Record modules (it is a good idea to set a max time limit on recording and indicate what VG should do when this limit is reached) and see if that makes any difference.
Eg: you can set a timeout of 10 minutes by using a path like this:
on {Timeout 600} goto ...
where ... is the module to go to.
Please try using timeout paths in the record modules in this script and see if this changes anything.
