Pager Message
How do I use the pager block? I have a single block in my script, a 'send pager message' block. I entered a phone number and message, but when I run the script, nothing happens. I checked the 'start script without answering' checkbox in the script properties, and set the pager block to be the script start block. I tested the outbound dialing using the phone dialer, and they work OK. Ideas?
Mike.
Could you please post a copy of VoiceGuide's Debug Printout which captures the incoming call, this will allow us to see what is happening.
