Email Module - Sending Email
In using VoiceGuide to allow clients to listen to and approve their radio commercials, I have run into one thing that I can't figure out.
I want the caller to enter a 4-digit number to hear their commercial. The commercial plays using a play module. Then the caller can press "1" to approve it or leave a message asking for changes. If the caller leaves a message, it gets sent to the owner of the mailbox, namely the salesperson.
BUT if the caller presses "1" to approve the commercial, I want the system to email the salesperson and sales managers a message saying "The commercial with 4-digit code number $RVwelcome (it should insert the mailbox number here) has been approved."
In order to do this, the script needs a variable for the mailbox owner's email address since I have so many salespeople. How can I pull the email address for a box owner and insert it into the to: field in the email send module?
Thanks,
Steve
I think I found my answer in a previous post which I had overlooked. Here it is.. But when I implemented it, I got this:
125929.23  0 cl    Vm_VmbConfig_Get 0001, EmailForward
125929.23  0 cl    Script_Return [RetrievedEmailAddress]{my_email_address}
125929.23  0 COM interface not supported in this version.
It retreived my email address just fine. What is wrong with my version?
Steve
Are you running a registered version of VoiceGuide? What is the license type?
Only Evaluation and Enterprise versions of VG will allow use of COM interface, see: http://www.voiceguide.com/vgFeatures.htm
Vm_VmbConfig_Get and Vm_VmbConfig_Set are exceptions - they can be used from Pro version as well...
I get errors when I run the code referenced above and no email is sent:
Script is attached.
111609.89 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\Spots\0001.wav]
111609.89 7 TimeoutClear
111609.89 7 RunModule PLAY end
111609.89 7 wa(17285,32069400)
111627.34 7 Play End line[7] (id=320694)
111627.34 7 ScriptEventCode 8001 iLineState=1100
111627.34 7 LsPlayMsg EV_PLAY_FINISHED
111627.34 7 TimeoutSet 10 EV_TIMEOUT_HANGUP
111627.34 7 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
111627.34 7 ScriptEventCode 9002 iLineState=1101
111627.34 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
111627.34 7 TimeoutClear
111627.34 7 [Run VB Script] Running VB Script...
111627.34 7 RVreplace start: [set vg = CreateObject("VoiceGuide.CommandLink")
sEmailAddr = vg.Vm_VmbConfig_Get("$RV[Welcome]", "EmailForward")
vg.Script_Return iLineId, "[RetrievedEmailAddress]{" & sEmailAddr & "}"
set vg = Nothing
111627.34 7 RVns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{3/24/2004 11:16:00 AM}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Welcome]{0001}[Welcome_PathTaken]{success}
111627.36 7 VBScript Run continuing...
111627.36 7 TimeoutClear
111627.36 7 [PlayApproveReq] Playing
111627.36 7 [PlayApproveReq] Playing (SPOTMAIL VO-options 4 beep.wav)
111627.91 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\SpotMail\SPOTMAIL VO-options 4 beep.wav]
111627.91 7 TimeoutClear
111627.91 7 RunModule PLAY end
111627.91 7 wa(11062,33872000)
111627.93 0 cl Vm_VmbConfig_Get 0001, EmailForward
111627.93 0 cl Script_Return [RetrievedEmailAddress]{swalker@radio-one.com}
111627.93 0 cl no active call on line.
111639.15 7 Play End line[7] (id=338720)
111639.15 7 ScriptEventCode 8001 iLineState=1100
111639.15 7 LsPlayMsg EV_PLAY_FINISHED
111639.15 7 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG
111641.61 7 dtmf 1 (65539,49,2)
111641.61 7 ScriptEventCode 49 iLineState=1101
111641.61 7 LsPlayMsgFinished 1
111641.61 7 RVreplace start: [on {2} goto [Voicemail Box $rv[welcome]]
on {3} goto [PlaySpot]
on {timeout 0} goto [Welcome]
on {1} goto [send Email]
111641.61 7 RVns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{3/24/2004 11:16:00 AM}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Welcome]{0001}[Welcome_PathTaken]{success}
111641.61 7 rv add [PlayApproveReq]{1}
111641.61 7 TimeoutClear
111641.61 7 [send Email] Send Email
111641.63 7 RVreplace start: [$RV[RetrievedEmailAddress]]
111641.63 7 RVns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{3/24/2004 11:16:00 AM}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Welcome]{0001}[Welcome_PathTaken]{success}[PlayApproveReq]{
111641.63 7 RVreplace end: []
111641.63 7 RVreplace start: [spot $rv[welcome] has been approved]
111641.63 7 RVreplace end: [spot 0001 has been approved]
111641.63 7 rv add [send Email]{}
111641.63 7 rv add [send Email_Subject]{Spot 0001 has been approved}
111641.63 7 rv add [send Email_Message]{Spot 0001 has been approved}
111641.63 7 rv add [send Email_Attachment]{}
111641.63 7 rv add [send Email_Cc]{}
111641.63 7 rv add [send Email_Bcc]{}
111641.64 7 Que email to:
111641.64 7 rv add [send Email_SendResult]{OK}
111641.64 7 TimeoutClear
111641.64 7 [Ack Approval] Playing
111641.64 7 [Ack Approval] Playing (SPOTMAIL VO-approve -end.wav)
111642.18 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\SpotMail\SPOTMAIL VO-approve -end.wav]
111642.18 7 TimeoutClear
111642.18 7 RunModule PLAY end
111642.18 7 wa(3544,35299000)
111645.90 7 Play End line[7] (id=352990)
111645.90 7 ScriptEventCode 8001 iLineState=1100
111645.90 7 LsPlayMsg EV_PLAY_FINISHED
111645.90 7 TimeoutSet 10 EV_TIMEOUT_HANGUP
111645.90 7 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
111645.90 7 ScriptEventCode 9002 iLineState=1101
111645.90 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
111645.90 7 TimeoutClear
111645.90 7 rv add [Hangup Time]{3/24/2004 11:16:45 AM}
111645.90 7 Hanging up call... [Hangup Module]
The problem is with the VB Script not returning the information to the same line..
In:
set vg = Nothing
the:
should be:
vg.Script_Return $RV_LINEID, "[RetrievedEmailAddress]{" & sEmailAddr & "}"
(or you should set iLineId=$RV_LINEID )
otherwise you can see in the trace that the result is being returned to an unknown line:
and not to the correct line, resulting in $RV[RetrievedEmailAddress] being undefined on that line :
Well, I suppose it's returning it to the correct line now, but ths VB script is failing.
I have a scaled-down version of the vgs script to facilitate troubleshooting and it is attached. Since it is returning the email address, I have set it to go to the Send Email module whether the VB Script succeeds, fails or times out. However, it hangs up instead. Return from VB Script fails due to empty stack. See below:
094034.57  0 sys  cleanup Start
094034.57  0 sys  cleanup End
094037.72  7 callstate OFFERING 65900 0 4
094037.72  7 Answer the call at 3/25/2004 9:40:37 AM
094037.72  7 lineAnswer(65900) => 66037
094037.75  7 ring 1
094037.75  7 callstate ACCEPTED 65900 0 0
094041.11  7 tapi  Reply (LineEvReply) ok 66037 0
094041.11  7 callstate CONNECTED 65900,0,0
094041.11  7 WorkingModeTAPI@Connected=
094041.11  7 WorkingModeScript@Connected=
094041.11  7 Inband detection not enabled
094041.11  7 StartLoadedVgs at 3/25/2004 9:40:41 AM
094041.11  7 rv    add [$RV_STARTTIME]{3/25/2004 9:40:41 AM}
094041.11  7 rv    add [$RV_DEVICEID]{7}
094041.11  7 rv    add [$RV_CIDNAME]{}
094041.11  7 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
094041.11  7 rv    add [$RV_CIDNUMBER]{}
094041.11  7 TimeoutClear
094041.11  7 [Welcome] Number Input
094041.12  7 [Welcome] Playing (SPOTMAIL VO-begin-intro.wav)
094041.67  7 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\SpotMail\SPOTMAIL VO-begin-intro.wav]
094041.67  7 TimeoutClear
094041.67  7 wa(6953,99247400)
094048.79  7 Play End line[7] (id=992474)
094048.79  7 ScriptEventCode 8001 iLineState=1300
094048.79  7 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
094048.79  7 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG
094049.49  7 dtmf 0  (65900,48,2)
094049.49  7 ScriptEventCode 48 iLineState=1301
094049.49  7 LsGetNbrsRxDigits 0
094049.49  7 [Welcome] Number Input 0
094049.49  7 path {0} not found
094049.49  7 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
094049.82  7 dtmf 0  (65900,48,2)
094049.83  7 ScriptEventCode 48 iLineState=1301
094049.83  7 LsGetNbrsRxDigits 0
094049.83  7 [Welcome] Number Input 00
094049.83  7 path {00} not found
094049.83  7 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
094050.11  7 dtmf 0  (65900,48,2)
094050.11  7 ScriptEventCode 48 iLineState=1301
094050.11  7 LsGetNbrsRxDigits 0
094050.11  7 [Welcome] Number Input 000
094050.11  7 path {000} not found
094050.11  7 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
094050.37  7 dtmf 1  (65900,49,2)
094050.37  7 ScriptEventCode 49 iLineState=1301
094050.37  7 LsGetNbrsRxDigits 1
094050.37  7 [Welcome] Number Input 0001
094050.37  7 path {0001} not found
094050.37  7 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
094050.37  7 TimeoutClear
094050.37  7 rv    add [Welcome]{0001}
094050.37  7 AddRVns [Welcome_PathTaken]{success}
094050.37  7 [PlaySpot] Playing
094050.37  7 RVreplace start: [C:\Program Files\VoiceGuide\data\Spots\$RV[Welcome].wav]
094050.37  7 RVns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{3/25/2004 9:40:41 AM}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Welcome]{0001}[Welcome_PathTaken]{success}
094050.37  7 RVreplace end: [C:\Program Files\VoiceGuide\data\Spots\0001.wav]
094050.38  7 [PlaySpot] Playing (C:\Program Files\VoiceGuide\data\Spots\0001.wav)
094050.92  7 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\Spots\0001.wav]
094050.92  7 TimeoutClear
094050.93  7 RunModule PLAY end
094050.93  7 wa(17285,173700)
094108.39  7 Play End line[7] (id=1737)
094108.39  7 ScriptEventCode 8001 iLineState=1100
094108.39  7 LsPlayMsg EV_PLAY_FINISHED
094108.39  7 TimeoutSet 10 EV_TIMEOUT_HANGUP
094108.39  7 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
094108.39  7 ScriptEventCode 9002 iLineState=1101
094108.39  7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
094108.39  7 TimeoutClear
094108.39  7 [Run VB Script] Running VB Script...
094108.39  7 RVreplace start: [set vg = CreateObject("VoiceGuide.CommandLink")
set vg = Nothing
094108.39  7 RVns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{3/25/2004 9:40:41 AM}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Welcome]{0001}[Welcome_PathTaken]{success}
094108.41  7 Run Script waiting... (shellid=368, process=616)
094108.41  7 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE
094108.42  0 cl    Vm_VmbConfig_Get 0001, EmailForward
094108.43  7 cl    Script_Return [RetrievedEmailAddress]{swalker@radio-one.com}
094108.43  7 rv    add [Hangup Time]{3/25/2004 9:41:08 AM}
094108.43  7 Hanging up call... [scr  return from [Run VB Script] failed - stack empty.]
094108.43  7 RecSoundStop ok
094108.43  7 PlaySoundStop err=0
094108.43  7 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
094108.43  7 fnHangupCall end
094109.42  7 callstate DISCONNECTED 65900,1,0
094109.43  7 ScriptEventCode 9250 iLineState=900
094109.43  7 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
094109.43  7 rv    add [Hangup Time]{3/25/2004 9:41:09 AM}
094109.43  7 Hanging up call...
094109.43  7 RecSoundStop ok
094109.43  7 PlaySoundStop err=0
094109.43  7 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
094109.43  7 fnHangupCall end
094109.43  7 callstate IDLE 65900 0 0
094109.43  7 WorkingMode@Idle=
094109.43  7 TimeoutClear
094109.48  7 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
094109.48  7 tapi  Reply (LineEvReply) ok 65730 0
094109.48  7 tapi  Reply (LineEvReply) ok 65883 0
094110.39  7 Timer fired EV_TIMEOUT_TIMETOREINITLINE
094110.39  7 ScriptEventCode 9008 iLineState=900
094110.39  7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
094110.39  7 ReinitTelephony due to IDLE
094110.39  7 tapic lineDeallocateCall(MainCall:65900) 0
094110.46  7 lineOpen(7)=>
094110.46  7 Waiting for a call...
094110.46  7 LineHandle=66088
094110.46  7 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
094113.46  7 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
094113.46  7 ScriptEventCode 9013 iLineState=900
Spotmail.vgs
To return information form a VB Script back to VoiceGuide you should be using:
Run_ResultReturn
not Script_Return ...
(we should have picked up that you are using an incorrect function as well earlier, sorry...)
the Script_Goto, Script_Gosub and Script_Return functions are used to access the VoiceGuide "subscripting" features - they are not used for returning from a VB Script etc...
(I will now correct the other post which incorrectly suggested to use Script_Return)
