License Policy Is Not Able To Understand
I am not clear with the license policy. I am looking for Professional license and my requirement is to create an application in which I will get an incoming call and based on the DTMF response, I need to forward the call to any of the outside number (Not the extension). I am planning to use Dialogic D4PCI card as hardware device. Can I try the same application using a voice modem as a demo before going for the Dialogic Card??
If this is the case, is it enough if I buy one Professional Voice Guide license and one VG Dialer license? If the above number of license is not enough to run my application, advice me the number of licenses I need to buy and also I request you to give the estimation for the same.
Regards
Gnani.
If you just want to use the "Blind Transfer" or "Announced Transfer" then just the Pro license will be sufficient.
If you want to use the "Dial and Conference" option then you will need the Pro+Dialer license, but you will also need a D/41JCT card.
All this info is in VoiceGuide Help file's section on the Transfer Call module.
