Dialogic Call Transfer, And Flash Hook Length...
Hi
I am trying to do a call transfer through VG, using a dialogic D/4PCI on a Lucent Eurogenerisis PBX.
It seems that, as soon as the flash hook, gets executed, the caller gets dropped.
However, after the caller has been dropped, the extension that I was attempting to transfer to, would receive the call and there would be no-one on the other end, as the caller had been dropped.
I was informed by the telphone company, that the flash hook time should be set, between 80 and 120 milliseconds, which I tried, but I still get the same problem.
Is there any other possible cause for the problem?
75968 5 tapie linedevstate 2048 0 0
75968 5 tapie callstate OFFERING 66220 0 4
75984 5 tapie callinfo CALLEDID
75984 5 tapie callinfo ORIGIN
75984 5 tapie ring 0
75984 5 Answer the call
75984 5 lineAnswer(66220) => 66203
76515 5 tapie callstate CONNECTED 66220,1,0
76515 5 WorkingModeTAPI=
76515 5 WorkingModeScript=
76578 5 tapi Reply 66203 0
76578 5 tapie callinfo MONITORMODES
76578 5 TimeoutClear
76609 5 TimeoutSet 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
76937 5 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
76937 5 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
76937 5 TimeoutSet 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
76937 5 [Transfer Call 1] Blind Transfer to 1627 (Generate)
76968 5 tapic lineGenerateDigits(66220,!) => 0
77656 5 tapie generate LINEGENERATETERM_DONE
77656 5 TimeoutSet 1 EV_TAPI_GENERATE
78734 5 Timer fired EV_TAPI_GENERATE
78734 5 LsXferStart EV_TAPI_GENERATE
78734 5 TimeoutSet 1 EV_HOOKFLASHFINISHED
79828 5 Timer fired EV_HOOKFLASHFINISHED
79828 5 LsXferPlayVts EV_HOOKFLASHFINISHED
79828 5 tapic lineGenerateDigits(66220,1627) => 0
80421 5 tapie generate LINEGENERATETERM_DONE
80421 5 TimeoutSet 1 EV_TAPI_GENERATE
81468 5 Timer fired EV_TAPI_GENERATE
81468 5 LsXferPlayVts EV_TAPI_GENERATE
81468 5 TimeoutSet 1 EV_TIMEOUT_HANGUP
82562 5 Timer fired EV_TIMEOUT_HANGUP
82562 5 LsXferPlayVts EV_TIMEOUT_HANGUP
82562 5 PlaySoundStop ok
82562 5 Hanging up call...
82562 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
82562 5 fnHangupCall end
82593 5 tapie linedevstate 2048 0 0
82593 5 tapie callstate IDLE 66220 0 0
82609 5 WorkingMode@Idle=
82609 5 TimeoutClear
82656 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
82656 5 tapi Reply 65964 0
83656 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE
83656 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
83656 5 Initialise telephony (due to IDLE)
83656 5 tapic lineDeallocateCall(MainCall:66220) 0
83796 5 Waiting for a call...
83796 5 hLine=65981
83796 5 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT
89265 5 Timer fired EV_TIMOUT_ATERIDLE_ALLOWOUT
Hmm...
Not to worry. I solved the problem. UnInstalled and Re-Installed the Dialogic drivers, and now it works 100%.
Thanks Anyhew.
Did you restart the PC after making the hookflash timing changes?
This is sometimes needed to have the new hookflash settings read in...
if using WinXP the hookflash length is set in the .PRM file, changing:
# PARAM 52:(DECIMAL WORD) 50 # Hook Flash/earth recall duration
to:
PARAM 52:(DECIMAL WORD) 10 # Hook Flash/earth recall duration
if you need 100ms hookflash..
The .PRM file is the one you specify in the DCM's "Parameter File" setting, see the release notes which came with the D/4PCI for more info.
.PRM files are usually in C:\Program Files\Dialogic\DATA directory, and the ones used for D/4PCI are called xx_d4p.prm where xx is the country code.
