Pbx - Announced Transfer Problem
OS : Windows 2000 sp 2
VoiceGuide : 5.2.1 Trial
Dialogic : D/4PCI
PBX : Siemens Hicom 300
I am having a problem when once the announced transfer has been initiated, the person at the extention transfered to picks up hear the nice lady voice but when the key 1 pressed the call disconnected.
Log File :
76187 8 tapie linedevstate 2048 0 0
76187 8 tapie callstate OFFERING 65999 0 4
76203 8 tapie callinfo CALLEDID
76203 8 tapie callinfo ORIGIN
76203 8 tapie ring 0
76203 8 Answer the call
76203 8 lineAnswer(65999) => 66051
76750 8 tapie callstate CONNECTED 65999,1,0
76750 8 WorkingModeTAPI=
76750 8 WorkingModeScript=
76781 8 Inband detection not enabled
76781 8 tapi Reply 66051 0
76796 8 [WaitMessage] Playing
76796 8 [WaitMessage] Playing (C:\CallCenter\IVR\Wav\A010.wav)
76937 8 PlaySoundStart ok [C:\CallCenter\IVR\Wav\A010.wav]
76937 8 RunModule PLAY end
77484 8 tapie monitordigits 49 2
77500 8 LsPlayMsg [1]
79046 8 Play End line[8] (id=876812)
79046 8 LsPlayMsg EV_PLAY_FINISHED
81703 8 tapie monitordigits 35 2
81703 8 LsPlayMsgFinished [#]
82093 8 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
82093 8 [Transfer To 223] Announced Transfer to 223 (Generate)
82109 8 tapic lineGenerateDigits(65999,!) => 0
82796 8 tapie generate LINEGENERATETERM_DONE
83859 8 LsXferStart EV_TAPI_GENERATE
84953 8 LsXferPlayVts EV_HOOKFLASHFINISHED
84953 8 tapic lineGenerateDigits(65999,223) => 0
85406 8 tapie generate LINEGENERATETERM_DONE
86484 8 LsXferPlayVts EV_TAPI_GENERATE
86500 8 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, , Digits
86531 8 twcal PlaySayNumber C:\Program Files\VoiceGuide\system\voicedlgc\TsfrCallFrom.wav, C:\Program Files\VoiceGuide\system\voicedlgc\TsfrAskAccept.wav, , , 1
86546 8 PlaySoundStartNumbers ok
90984 8 tapie monitordigits 49 2
90984 8 LsXferPlayAnn [1]
91046 8 PlaySoundStop ok
92031 8 LsXferPlayAnn EV_PLAY_FINISHED
92031 8 LsXferPlayAnn EV_TAPI_GENERATE
92031 8 PlayFinishCause=CallAccepted
92031 8 Success path not defined - hanging up (iXferType=1)
93125 8 LsXferPlayAnn EV_TIMEOUT_HANGUP
93125 8 PlaySoundStop ok
93125 8 HangupCall called from []
93125 8 Hanging up call...
93125 8 fnHangupCall end
93171 8 tapie linedevstate 2048 0 0
93171 8 tapie callstate IDLE 65999 0 0
93171 8 WorkingMode@Idle=
93265 8 set EV_TIMEOUT_TIMETOREINITLINE 2
93265 8 tapi Reply 65761 0
94281 8 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
94281 8 ReinitTelephony due to IDLE start
94281 8 tapic lineDeallocateCall(MainCall:65999) 0
94421 8 lineOpen(8) => 0
94421 8 Waiting for a call...
94421 8 lineOpen(8)LineHandle=65744
VG.ini :
[LineConfig]
TapiDeviceCount=1
[TapiDevice1]
Id=8
Name=Ext 224
Script=C:\Program Files\VoiceGuide\Scripts\Test4.vgs
RingsBeforeAnswer=1
PopupCallerId=1
DialoutOK=1
[TapiDevice2]
Id=8
Name=Analog Line 4(dxxxB1C4)
Script=C:\CallCenter\First.vgs
RingsBeforeAnswer=1
PopupCallerId=1
DialoutOK=1
[TapiDevice3]
ID=
Name=
Script=
RingsBeforeAnswer=2
PopupCallerId=
DialoutOK=
[TapiDevice4]
ID=
Name=
Script=
RingsBeforeAnswer=2
PopupCallerId=
DialoutOK=
[PlayRecordConfig]
RecEditor=SNDREC32.EXE
RecCutIfHangupBytes=48000
RecCutIfDtmfStopBytes=5000
RecLengthMin=1
RecLengthMax=30
PlayEndPauseDialogic=0
;PlayVolume can be set from 1 (very quiet) to 100 (loudest).
;a setting of 0 disables explicit setting of the volume, keeping the default setting.
PlayVolume=100
;SilenceDetectLength: 40 = 4 seconds
SilenceDetectLength=40
;SilenceDetectLevel: range: 0-100.
;0 - don't detect silence, 100 - detect loud background noise as silence.
SilenceDetectLevel=10
[Voicemail]
RecLengthMin=1
RecLengthMax=30
ForwardPhoneRetries=2
ForwardPhoneWait=1
ForwardPhoneAcceptPrompt=VmbForwardAskAccept.wav
ForwardEmailSubject=Voicemail recieved from $RV_CIDNAME, $RV_CIDNUMBER at $RV_HOUR:$RV_MINUTE $RV_DATE/$RV_MONTH
ForwardEmailBody=Voicemail recieved from $RV_CIDNAME, $RV_CIDNUMBER at $RV_HOUR:$RV_MINUTE $RV_DATE/$RV_MONTH
ForwardEmailMechanism=MAPI
ForwardEmailSmtpServer=smtp.yourdomain.com
ForwardEmailSmtpEmailAddress=you@yourdomain.com
ForwardVmEmailSmtpSendersName=VoiceGuide Voicemail
RunCommandAfterRec=
[PBX]
;Maximum time the system will wait for the extension to be answered. In seconds.
AnnouncedTransfersMaxWaitTime=30
;Inband signalling configuration file eg: InbandSignaling_SiemensHiPath3000_v1.2.txt
InbandSignalConfig=
;time for PBX to react to the hookflsh. In 100ms units, eg: 10=1 second
PauseAfterHookflash=10
;"TAPI" : TAPI functions calls are made to driver to action transfers and conferences.
;"Generate" : exlilicit tones and signals are generated using TAPI calls
;"AT" : modem AT commands are used
TransferControl_Modem=Generate
TransferControl_TelBoards=Generate
;TransferControl_TelBoards=TAPI
;*** "Generate" is selected for Transfer Control
;generated before playing the destination extension. (Blind and Announced transfers)
Transfer_Prefix=!
;generated after the call transfer is accepted.
;after playing this signal VoiceGuide will hang up the call.
;generated after the call is declined.
;This signal is used to hangup the extension leg of the call and retrieve the call,
Transfer_AnnounceDecline=!
;generated before playing the destination extension. (Blind and Announced conferences)
Conference_Prefix=!
;generated immediately after playing the destination extension
Conference_BlindSuffix=!3
;generated after the call confenrence is accepted.
;after playing this signal VoiceGuide will stay on the line.
Conference_AnnounceAccept=!3
;generated after the call confenrence is declined.
Conference_AnnounceDecline=!
;*** "AT" is selected for Transfer Control
ModemTransferInit1=AT#VBT=1
ModemTransferHookflash=AT#VTS=!
;ModemTransferDialNumber: this command is suffixed with the destination number separated by commas
ModemTransferDialNumber=AT#VTS=
ModemTransferComplete=AT#VTS=!
;Commands issued to the modem duting a 3-way conference setup
Modem3WayInit1=AT#VBT=1
Modem3WayHookflash=AT#VTS=!
;pause time after sending hookflash to allow PBX enough
;Modem3WayDialNumber : this command is suffixed with the destination number separated by commas
Modem3WayDialNumber=AT#VTS=
Modem3WayComplete=AT#VTS=!
;*** "TAPI" is selected for Transfer Control
;set to 1 if lineComplete transfer is not to be called upon announced call transfer being accepted.
;if set to 0 then LineCompleteTransfer will be issued after call transfer is accepted, then call will be hung up.
;if set to 1 then the call will be just hung up after call transfer is accepted.
OnTransferAccept_NoLineCompleteTransfer=1
;3WayMaxTalkTime is in 1 second units, rg: 1800 = 30 minutes
3WayMaxTalkTime=1800
[VGDialer]
;set it to MM/DD/YY or DD/MM/YY
DateFormat=DD/MM/YY
;Dialout announcement replay maximum count.
AnnReplay=3
;How long before another call can go out on the same line (sec)
AfterIdleWait=5
;Silence detection is used to judge when the answering machine
;message has stopped talking:
;AnswerMachine Silence detect length. In 100ms units (20 = 2 seconds)
AM_SilenceDetectLength=20
;AnswerMachine SilenceDetectLevel: range: 0-100.
AM_SilenceDetectLevel=10
[VBScript]
UseSafeSubset=1
ShellHandler=wscript
[DatabaseWorkspace]
WorkspaceJetUser=admin
WorkspaceJetPassword=
WorkspaceOdbcUser=admin
WorkspaceOdbcPassword=
[VgGsd]
DesignAreaHeight=5000
DesignAreaWidth=5000
[VGsys]
;Used only for CT-Media systems
;AssistingApp=VgControl.exe
;Fax Handoff settings:
HandoffProgramFax=
[OnError]
;OnError_Unavailable possible settings:
;RESTART_TAPI, RESTART_VOICEGUIDE, RESTART_PC
OnError_Unavailable=
[Callflow]
;OnGetNumbersRxDigit=PlayStop_False
[CTMedia]
DefaultScript=
WatchedService=
WatchedFile=
LoadScript1=
LoadScript2=
LoadScript3=
LoadScript4=
LoadScript5=
LoadScript6=
LoadScript7=
LoadScript8=
LoadScript9=
LoadScript10=
[TraceLog]
LogDebugToFile=0
Thx
Anton
Enseval
Can you tell us step-by-step how do you usually transfer calls manually on this system?
In order to tranfer a call by telephone I simply press the "R" key on the telephone (it is a hookflash) and then I digit the number of the destination telephone.
After the first ring of the destination phone then I hangup my phone and the transfer is made.
That is a description for a blind transfer - how about an announced transfer?
If transferring the call manually can you hangup after the recipient of the transfer has picked up handset and the call will then be transferred OK?
This is basically what VG is doing, you can see in the trace:
No, if I wait until the recipient of the transfer has picked up handset, the transfer will be closed, so I have to hangup the phone after I hear the ring and hang up immediatelly before the recipient picked up the phone
Well that pretty much explains it...
You should use the "Blind Transfer" option on your system.
To ensure that the destination extension starts ringing before VoiceGuide hangs up after dialing the number you should add a few commas at the end of the number to be dialed.
The comma is used to indicate a pause. Usually each comma indicates a two second pause, but you can change this by editing Dialogic TSP configuration.
One or two commas should usually be long enough to ensure that the destination extension starts ringing without making the pause so long that the destination handset gets picked up before the pause finshes - which is what is needed on your system.
Try changing the destination number in the transfer module from:
223
to:
223,
and select "Blind Transfer"
