Vgs Script From Vg6 To Vg7
I am unable to execute correctly the same vgs script after conversion from vg6 to vg7 voip: after the ring the script goes to answer machine but nothing left on answering machine nor anything reaching the phone.
Please see logs attached.
There were many traces attached, but looking at the latest CallEvents log (0310_CallEvents.txt) we can see that over 20 outgoing calls were made, with they all apparently being answered, including 3 that were detected as being answered by an answering machine/voicemail:
"time_start": "2017-03-10 12:24:43"
"time_start": "2017-03-10 12:52:22"
"time_start": "2017-03-10 12:54:53"
The first one failed as:
122443.978|state|[EvaluateSite] Evaluate [$RV[ivrSite]]|||||0|0|0|0
122444.019|state|Hanging up... [Path {Fail} not defined.]|||||0|0|0|0
but the other two played a message to the machihe/voicemial:
    125240.096|state|Run Answer Machine script [C:\Program Files (x86)\VoiceGuide\Scripts\ReadPin\IvrPin_old.vgs]|||||0|0|0|0
    125240.098|state|[YourPinIs] tts generate start (len=16)|||||0|0|0|0
    125240.098|command|cmd_Tts2WavFile|This is your pin|C:\Program Files (x86)\VoiceGuide\temp\tts_3_1.wav||ulaw_8|0|0|0|0
    125510.521|state|Run Answer Machine script [C:\Program Files (x86)\VoiceGuide\Scripts\ReadPin\IvrPin_old.vgs]|||||0|0|0|0
    125510.523|state|[YourPinIs] tts generate start (len=16)|||||0|0|0|0
    125510.523|command|cmd_Tts2WavFile|This is your pin|C:\Program Files (x86)\VoiceGuide\temp\tts_3_1.wav||ulaw_8|0|0|0|0
did you refer to some other calls in the statement "nothing left on answering machine nor anything reaching the phone." ?
