Guest william Report post Posted 03/10/2003 04:12 PM Hello, is it possible to bridge two different lines ? If so, can you show me the sample scripts. I am not talking about 3 way conference, because two lines have different pricing. For example, dial in Line A and prompt to enter another outgoing number, then using Line B to dial out this number and talk with the other party. This will be very useful when set up a server at remote location, where bridge one Voip line and one PSTN line to make remote local calls. Thank you very much. Share this post Link to post
SupportTeam Report post Posted 03/10/2003 10:02 PM Bridging two lines is not supported at this stage - this feature has been asked for quite often and katalina is looking into adding this feature in upcoming versions of VoiceGuide. It is at least 4-6 months away. Share this post Link to post
Guest joe paiva Report post Posted 09/22/2003 12:28 AM Did this feature ever get added? Share this post Link to post
SupportTeam Report post Posted 09/22/2003 04:49 AM Yes. It's available in v5.0 of VG in the "Call Transfer" module - and a bug fix for it is in v5.1 Beta2 out right now - please download v5.1 Beta2 (or later) and you will be able to use this feature. Please note that "Dialout and Conference" can only be done with these Dialogic cards: D/41EPCI, D/41ESC, D/41JCTLS, D/120JCTLS, D/160SC-LS and all digital cards: D/240SC, D/300SC etc Share this post Link to post
qc04447 Report post Posted 10/31/2003 06:27 PM Does this work with D4/PCI? Share this post Link to post
SupportTeam Report post Posted 10/31/2003 10:35 PM No. Only with cards listed in the post above. The card has to support "SC Bus" or "CT Bus" in order for it to be capable of bridging calls. Share this post Link to post
Guest Ralison Report post Posted 12/01/2003 12:35 PM So it is not possible bridging two modems or transfert call from a modem to another modem inside the same computer? Is that possible in future version? Thanks Rina Share this post Link to post
SupportTeam Report post Posted 12/01/2003 12:52 PM So it is not possible bridging two modems or transfert call from a modem to another modem inside the same computer? No, it's not possible. Voice modems are just incapable of supporting this functionality. Share this post Link to post
Guest RickyMartin Report post Posted 10/13/2004 10:27 PM I would like to know what Brooktrout card would be able to do this so called bridging? Thanks! Share this post Link to post
Guest Guest Report post Posted 10/14/2004 02:27 AM D/160SC-LS Dialogic D/160SC-LS-HIZ Rev.2 is this the same board as you describe that will work with call bridging? or does it need to be Rev 3? david Share this post Link to post
SupportTeam Report post Posted 10/14/2004 05:03 AM The "HIZ" bit means that this is a high impedance board - used for call recording applications only. Share this post Link to post
