Bridge Two Lines
Hello, is it possible to bridge two different lines ? If so, can you show me the sample scripts. I am not talking about 3 way conference, because two lines have different pricing. For example, dial in Line A and prompt to enter another outgoing number, then using Line B to dial out this number and talk with the other party. This will be very useful when set up a server at remote location, where bridge one Voip line and one PSTN line to make remote local calls. Thank you very much.
Bridging two lines is not supported at this stage - this feature has been asked for quite often and katalina is looking into adding this feature in upcoming versions of VoiceGuide. It is at least 4-6 months away.
Yes. It's available in v5.0 of VG in the "Call Transfer" module - and a bug fix for it is in v5.1 Beta2 out right now - please download v5.1 Beta2 (or later) and you will be able to use this feature.
Please note that "Dialout and Conference" can only be done with these Dialogic cards: D/41EPCI, D/41ESC, D/41JCTLS, D/120JCTLS, D/160SC-LS and all digital cards: D/240SC, D/300SC etc
No. Only with cards listed in the post above.
The card has to support "SC Bus" or "CT Bus" in order for it to be capable of bridging calls.
So it is not possible bridging two modems or transfert call from a modem to another modem inside the same computer?
Is that possible in future version?
Rina
No, it's not possible. Voice modems are just incapable of supporting this functionality.
I would like to know what Brooktrout card would be able to do this so called bridging?
Thanks!
D/160SC-LS
Dialogic D/160SC-LS-HIZ Rev.2 is this the same board as you describe that will work with call bridging? or does it need to be Rev 3?
david
The "HIZ" bit means that this is a high impedance board - used for call recording applications only.
