Vbs Fade In, Fade Out
Is available function fade in and fade out for Play vbs command (vg.Play_Stop $RV_LINEID)?
Fade in/out functionality is not supported right now. The system will play the sound data as it is in the sound file.
You could use sound editor software to adjust the sound file to have the fade in/out effects. It is possible that such processing could be done from the command line.
It may also be possible to add this functionality to VoiceGuide itself. Please contact sales@voiceguide.com with your requirements.
