Send Emails
I have set up the email to be sent, but I was wondering how the "retries" works. Is this only if they haven't been sent or what. I have it set at the default of 3 and even though it has sent the email, it continues to send it another 2 times. If I set this to 0 then would this stop...but if the server was down, then it wouldn't send it again when it was up, would it....Totally confused now!
"retries" is the max number of times VG will try to send the email message.
Once the email message has been sent successfully then it is not sent again.
Maybe your SMTP server after accepting the email is not acknowledging back to VG that it has received email successfully and that is causing VG to send email up to "retries" number of time?
Maybe you have the same recipient mentioned again in CC or BCC fields?
Which version of VG are you using?
Could you please post us the trace file MMDDes.txt which should be getting created in VoiceGuide's \log\ subdirectory, this will let us see what is happening when VG sends the email.
Here are the traces from a test we done with v5.1.8 on our system just now, confirming that only one email gets sent:
\log\MMDDvgm.txt file:
145426.52  9 [send Email 2] Send Email
145426.52  9 AddRVall [send Email 2]{emailtest@katalina.com.au}
145426.52  9 AddRVall [send Email 2_Subject]{test}
145426.52  9 AddRVall [send Email 2_Message]{test}
145426.52  9 AddRVall [send Email 2_Attachment]{}
145426.52  9 AddRVall [send Email 2_Cc]{}
145426.52  9 AddRVall [send Email 2_Bcc]{}
145426.52  9 Que email to: emailtest@katalina.com.au
\log\MMDDes.txt file:
145427.16  0 eng   prog start 14:54:27 26 Feb
145427.27  0 que   found 1/1
145427.31  0 smtp  Status Connecting to SMTP Server ( ... deleted... )...
145428.42  0 smtp  Status Initializing Communications...
145428.45  0 eng   smtp send start To:emailtest@katalina.com.au, Cc:, Bcc:
145428.45  0 smtp  Status Sending Sender Information...
145428.45  0 smtp  Progress 13%
145428.50  0 smtp  Status Sending Recipient Information...
145428.50  0 smtp  Progress 25%
145428.53  0 smtp  Status Sending Message...
145428.53  0 smtp  Progress 27%
145428.58  0 smtp  Progress 100%
145428.86  0 smtp  Progress 100%
145428.86  0 smtp  Status Transmission Complete...
145428.86  0 smtp  SendSuccesful
145428.86  0 que   delete ID=2
145428.86  0 eng   smtp send end
145428.86  0 smtp  Status Closing Connection...
145428.89  0 eng   send attempt 1 result = success
145429.00  0 eng   prog end   14:54:29 26 Feb
I am using a MAPI connection as the server is using Microsoft Mail rather than Exchange. I will check the code and post it tomorrow.
Does using MAPI make a difference?
It shouldn't, but lets see what the trace shows.
Are you using v5.1.8 of VoiceGuide?
I am using version 5.1.8 and here is the event log from the Send email module. This has sent two copies to me, and if it goes on previous form, it will send at least another.
Any help would be appreciated.
53555.55 7 [send Email test] Send Email
153555.55 7 RVreplace start: [test message for TEST SESSION - DINO New Recruit $RV[GetStudyId_1_1]]
153555.55 7 RVreplace end: [test message for TEST SESSION - DINO New Recruit 612349]
153555.55 7 RVreplace start: [This is an automatic message generated when VoiceGuide has randomised a woman into the DINO Trial - $RV[GetStudyId_1_1]
Hospital Code = $RV[Enter Hospital Code]
Patient UR = $RV[EnterUR]
Mother's DOB = $RV[MDOB_DAY]/$RV[MDOB_MONTH]/$RV[MDOB_YEAR]
Multiple Birth = $RV[MultipleBirth]
BirthWeight (1 = <1250gms, 2 = >=1250gms) = $RV[birthWeight]
Strata = $RV[GetStrata_1_1]
DateRand = $RV[Date]
Time Rand = $RV[Time]
StudyID = $RV[GetStudyId_1_1]
AllocGroup = $RV[GetStudyId_2_1]
153555.56 7 Que email to: cnrctrials@mail.wch.sa.gov.au
153555.56 7 [Log results] Running VB Script...
153555.56 7 RVreplace start (strlen>500)
153555.59 7 Run Script waiting... (shellid=1884, process=1496)
153556.70 7 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
153556.70 7 task completed (shellid=1884, process=1496)
153556.70 7 No information returned from program to VG (no VGRUNRESULT_7.TXT or SHLRESLT.TXT)
153556.70 7 Hanging up call... [WaitTillFinished - next module not specified]
153556.72 7 HangupCall_Common Mode=AfterHangupRun
153556.72 7 ReinitTelephony due to IDLE
153556.73 7 tapic lineDeallocateCall(MainCall:65587) 0
153556.89 7 lineOpen(7) => 0
153556.89 7 Waiting for a call...
153556.89 7 LineHandle=65536
154046.64 0 Script Load C:\Program Files\VoiceGuide\Randomisation\RandomisationDINO.vgs
154046.70 0 Loaded Script Id 2: C:\Program Files\VoiceGuide\Randomisation\RandomisationDINO.vgs
154046.72 0 Erasing Script (new loaded) Id 1
154416.02 0 sys cleanup Start
154416.02 0 sys cleanup End
(Do you have an SMTP server set up anywhere they you can let VG connect to directly instead of having VG use MAPI and Outlook to send the emails?)
MMDDes.txt is not being created anywhere.
Also, I believe the company that I am writing this for, only has Microsoft Mail server, and as such does not have a SMTP address. (am I correct in assuming no SMTP if only using Microsoft Mail)
In VG.INI file please check that in the section [EmailSender] the TraceLevel entry is set to 5 or higher.
If that does not help:
Can you please update to v5.2 and then make sure that in VG.INI file, in section [Log] the EmailSender entry is set to 10.
The log file will then be created.
Well I have uninstalled the previous version and installed v5.2 and now I get the following error message and the script stops.
121701.38 7 RVreplace end: [sELECT Strata FROM tblStrata WHERE (BirthWt = 2 and Gender = 2)]
121701.38 7 db About to execute a Retrieve type operation [sELECT Strata FROM tblStrata WHERE (BirthWt = 2 and Gender = 2)]
121701.38 7 db DBEngine.Error 3021:No current record.:DAO.Recordset
121701.38 7 db [GetStrata] row count=1
121701.39 7 rv add [GetStrata_RowCount]{1}
121701.39 7 ERROR 5.2.1005 RunModule:0:3001:Invalid argument.:DAO.Recordset
121701.41 7 rv add [Hangup Time]{09/03/2004 12:17:01}
121701.41 7 Hanging up call... [RunModule Error]
Can you please tell me what is going on here, and how I can fix it. Obviously something is happening in this new version that didn't in the previous.
This is quite urgent now, as I thought it was all ready to finalize and now I feel like I have taken a step backwards.
Sarah
This is a copy of what is in the vg.ini file relating to emailsend
[Log]
;Automated "log-to-file" logging.
;To turn OFF logging for a particular application set it's entry to 0
;To turn ON all logging for a particular application set it's entry to 10
;all log files are saved in VoiceGuide's \log\ subdirectory
;log files are names as following:
;VoiceGuide: MMDDvgm.txt
;NumberLoader: MMDDtnl.txt
;EmailSender: MMSSes.txt
;TapiWrapOcx: MMDDtw.txt
;SapiWrapOcx: MMDDsw.txt
VoiceGuide=0
NumberLoader=0
EmailSender=10
TapiWrapOcx=0
SapiWrapOcx=0
As you can see the emailsender is now called MMSSes.txt
However, this is not being created even though I have set the EmailSender to 10.
Do I need to do any other settings?
Here is the text from the 0309es.txt file (I just worked out that MMDD must stand for month and day!)
114140.45 0 eng prog start 11:41:40 09 Mar
114140.56 0 que found 1/30
114140.58 0 SendEmailMapi 2
114140.58 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
114140.83 0 SendEmailMapi returned
114140.83 0 eng send attempt 1 result = success
114140.95 0 eng prog end 11:41:40 09 Mar
114142.50 0 eng prog start 11:41:42 09 Mar
114142.61 0 eng prog end 11:41:42 09 Mar
114430.77 0 eng prog start 11:44:30 09 Mar
114430.88 0 que found 1/30
114430.88 0 SendEmailMapi 2
114430.89 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
114431.14 0 SendEmailMapi returned
114431.16 0 eng send attempt 1 result = success
114431.27 0 eng prog end 11:44:31 09 Mar
114555.03 0 eng prog start 11:45:55 09 Mar
114555.14 0 que found 1/30
114555.16 0 SendEmailMapi 2
114555.16 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
114555.28 0 SendEmailMapi returned
114555.28 0 eng send attempt 1 result = success
114555.39 0 eng prog end 11:45:55 09 Mar
114557.08 0 eng prog start 11:45:57 09 Mar
114557.19 0 eng prog end 11:45:57 09 Mar
114813.25 0 eng prog start 11:48:13 09 Mar
114813.36 0 que found 1/30
114813.38 0 SendEmailMapi 2
114813.38 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
114813.69 0 SendEmailMapi returned
114813.70 0 eng send attempt 1 result = success
114813.81 0 eng prog end 11:48:13 09 Mar
114815.30 0 eng prog start 11:48:15 09 Mar
114815.41 0 eng prog end 11:48:15 09 Mar
114817.34 0 eng prog start 11:48:17 09 Mar
114817.47 0 eng prog end 11:48:17 09 Mar
115015.92 0 eng prog start 11:50:15 09 Mar
115016.05 0 que found 1/30
115016.06 0 SendEmailMapi 2
115016.06 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
115016.33 0 SendEmailMapi returned
115016.33 0 eng send attempt 1 result = success
115016.45 0 eng prog end 11:50:16 09 Mar
115102.06 0 eng prog start 11:51:02 09 Mar
115102.19 0 que found 1/30
115102.20 0 SendEmailMapi 2
115102.20 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
115102.56 0 SendEmailMapi returned
115102.56 0 eng send attempt 1 result = success
115102.67 0 eng prog end 11:51:02 09 Mar
115104.13 0 eng prog start 11:51:04 09 Mar
115104.25 0 eng prog end 11:51:04 09 Mar
115106.20 0 eng prog start 11:51:06 09 Mar
115106.31 0 eng prog end 11:51:06 09 Mar
115146.77 0 eng prog start 11:51:46 09 Mar
115146.88 0 que found 1/30
115146.89 0 SendEmailMapi 2
115146.89 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
115147.08 0 SendEmailMapi returned
115147.08 0 eng send attempt 1 result = success
115147.19 0 eng prog end 11:51:47 09 Mar
115315.33 0 eng prog start 11:53:15 09 Mar
115315.44 0 que found 1/30
115315.45 0 SendEmailMapi 2
115315.45 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
115315.63 0 SendEmailMapi returned
115315.63 0 eng send attempt 1 result = success
115315.73 0 eng prog end 11:53:15 09 Mar
115317.38 0 eng prog start 11:53:17 09 Mar
115317.48 0 eng prog end 11:53:17 09 Mar
115401.45 0 eng prog start 11:54:01 09 Mar
115401.56 0 que found 1/30
115401.56 0 SendEmailMapi 2
115401.56 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
115401.89 0 SendEmailMapi returned
115401.89 0 eng send attempt 1 result = success
115402.00 0 eng prog end 11:54:02 09 Mar
115501.89 0 eng prog start 11:55:01 09 Mar
115502.00 0 que found 1/30
115502.02 0 SendEmailMapi 2
115502.02 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
115502.14 0 SendEmailMapi returned
115502.14 0 eng send attempt 1 result = success
115502.25 0 eng prog end 11:55:02 09 Mar
115507.95 0 eng prog start 11:55:07 09 Mar
115508.06 0 que found 1/30
115508.06 0 SendEmailMapi 2
115508.08 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
115508.14 0 SendEmailMapi returned
115508.14 0 eng send attempt 1 result = success
115508.25 0 eng prog end 11:55:08 09 Mar
115510.00 0 eng prog start 11:55:10 09 Mar
115510.11 0 eng prog end 11:55:10 09 Mar
115512.09 0 eng prog start 11:55:12 09 Mar
115512.22 0 eng prog end 11:55:12 09 Mar
115642.31 0 eng prog start 11:56:42 09 Mar
115642.42 0 que found 1/30
115642.44 0 SendEmailMapi 2
115642.44 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
115642.64 0 SendEmailMapi returned
115642.64 0 eng send attempt 1 result = success
115642.75 0 eng prog end 11:56:42 09 Mar
115644.36 0 eng prog start 11:56:44 09 Mar
115644.47 0 eng prog end 11:56:44 09 Mar
115646.41 0 eng prog start 11:56:46 09 Mar
115646.52 0 eng prog end 11:56:46 09 Mar
115800.47 0 eng prog start 11:58:00 09 Mar
115800.58 0 que found 1/30
115800.58 0 SendEmailMapi 2
115800.59 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
115800.91 0 SendEmailMapi returned
115800.91 0 eng send attempt 1 result = success
115801.03 0 eng prog end 11:58:01 09 Mar
115802.52 0 eng prog start 11:58:02 09 Mar
115802.66 0 eng prog end 11:58:02 09 Mar
115854.66 0 eng prog start 11:58:54 09 Mar
115854.78 0 que found 1/30
115854.80 0 SendEmailMapi 2
115854.80 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
115854.91 0 SendEmailMapi returned
115854.91 0 eng send attempt 1 result = success
115855.02 0 eng prog end 11:58:55 09 Mar
115856.73 0 eng prog start 11:58:56 09 Mar
115856.84 0 eng prog end 11:58:56 09 Mar
120000.92 0 eng prog start 12:00:00 09 Mar
120001.03 0 que found 1/30
120001.05 0 SendEmailMapi 2
120001.05 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
120001.66 0 SendEmailMapi returned
120001.66 0 eng send attempt 1 result = success
120001.77 0 eng prog end 12:00:01 09 Mar
120029.05 0 eng prog start 12:00:29 09 Mar
120029.16 0 que found 1/30
120029.17 0 SendEmailMapi 2
120029.17 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
120029.41 0 SendEmailMapi returned
120029.42 0 eng send attempt 1 result = success
120029.53 0 eng prog end 12:00:29 09 Mar
120031.13 0 eng prog start 12:00:31 09 Mar
120031.23 0 eng prog end 12:00:31 09 Mar
120101.17 0 eng prog start 12:01:01 09 Mar
120101.28 0 que found 2/31
120101.28 0 SendEmailMapi 2
120101.30 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
120101.42 0 SendEmailMapi returned
120101.42 0 eng send attempt 1 result = success
120101.53 0 que found 1/30
120101.53 0 SendEmailMapi 2
120101.53 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
120101.67 0 SendEmailMapi returned
120101.67 0 eng send attempt 1 result = success
120101.78 0 eng prog end 12:01:01 09 Mar
121702.30 0 eng prog start 12:17:02 09 Mar
121702.41 0 que found 1/30
121702.42 0 SendEmailMapi 2
121702.42 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
121702.58 0 SendEmailMapi returned
121702.58 0 eng send attempt 1 result = success
121702.69 0 eng prog end 12:17:02 09 Mar
121900.38 0 eng prog start 12:19:00 09 Mar
121900.48 0 que found 5/34
121900.48 0 SendEmailMapi 2
121900.50 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
121900.77 0 SendEmailMapi returned
121900.77 0 eng send attempt 1 result = success
121900.88 0 que found 4/33
121900.88 0 SendEmailMapi 2
121900.88 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
121901.02 0 SendEmailMapi returned
121901.02 0 eng send attempt 1 result = success
121901.13 0 que found 3/32
121901.13 0 SendEmailMapi 2
121901.14 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
121901.27 0 SendEmailMapi returned
121901.27 0 eng send attempt 1 result = success
121901.38 0 que found 2/31
121901.38 0 SendEmailMapi 2
121901.38 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
121901.52 0 SendEmailMapi returned
121901.52 0 eng send attempt 1 result = success
121901.63 0 que found 1/30
121901.63 0 SendEmailMapi 2
121901.63 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
121901.77 0 SendEmailMapi returned
121901.77 0 eng send attempt 1 result = success
121901.88 0 eng prog end 12:19:01 09 Mar
121902.42 0 eng prog start 12:19:02 09 Mar
121902.53 0 eng prog end 12:19:02 09 Mar
122000.47 0 eng prog start 12:20:00 09 Mar
122000.58 0 que found 4/33
122000.59 0 SendEmailMapi 2
122000.59 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
122000.77 0 SendEmailMapi returned
122000.77 0 eng send attempt 1 result = success
122000.88 0 que found 3/32
122000.88 0 SendEmailMapi 2
122000.89 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
122001.02 0 SendEmailMapi returned
122001.02 0 eng send attempt 1 result = success
122001.13 0 que found 2/31
122001.13 0 SendEmailMapi 2
122001.13 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
122001.25 0 SendEmailMapi returned
122001.27 0 eng send attempt 1 result = success
122001.38 0 que found 1/30
122001.38 0 SendEmailMapi 2
122001.38 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
122001.52 0 SendEmailMapi returned
122001.53 0 eng send attempt 1 result = success
122001.64 0 eng prog end 12:20:01 09 Mar
122002.52 0 eng prog start 12:20:02 09 Mar
122002.63 0 eng prog end 12:20:02 09 Mar
122100.56 0 eng prog start 12:21:00 09 Mar
122100.69 0 que found 1/31
122100.69 0 SendEmailMapi 2
122100.70 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
122100.77 0 SendEmailMapi returned
122100.77 0 eng send attempt 1 result = success
122100.88 0 eng prog end 12:21:00 09 Mar
122102.63 0 eng prog start 12:21:02 09 Mar
122102.73 0 eng prog end 12:21:02 09 Mar
122700.81 0 eng prog start 12:27:00 09 Mar
122700.92 0 que found 1/31
122700.94 0 SendEmailMapi 2
122700.94 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
122701.19 0 SendEmailMapi returned
122701.19 0 eng send attempt 1 result = success
122701.30 0 eng prog end 12:27:01 09 Mar
122702.86 0 eng prog start 12:27:02 09 Mar
122702.97 0 eng prog end 12:27:02 09 Mar
122901.05 0 eng prog start 12:29:01 09 Mar
122901.16 0 que found 4/35
122901.17 0 SendEmailMapi 2
122901.17 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
122901.44 0 SendEmailMapi returned
122901.44 0 eng send attempt 1 result = success
122901.56 0 que found 3/34
122901.56 0 SendEmailMapi 2
122901.58 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
122901.69 0 SendEmailMapi returned
122901.69 0 eng send attempt 1 result = success
122901.81 0 que found 2/33
122901.81 0 SendEmailMapi 2
122901.81 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
122901.94 0 SendEmailMapi returned
122901.94 0 eng send attempt 1 result = success
122902.05 0 que found 1/32
122902.05 0 SendEmailMapi 2
122902.06 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
122902.20 0 SendEmailMapi returned
122902.20 0 eng send attempt 1 result = success
122902.34 0 eng prog end 12:29:02 09 Mar
123001.11 0 eng prog start 12:30:01 09 Mar
123001.22 0 que found 1/35
123001.22 0 SendEmailMapi 2
123001.22 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
123001.34 0 SendEmailMapi returned
123001.34 0 eng send attempt 1 result = success
123001.45 0 eng prog end 12:30:01 09 Mar
123701.55 0 eng prog start 12:37:01 09 Mar
123701.66 0 que found 1/36
123701.67 0 SendEmailMapi 2
123701.67 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
123701.86 0 SendEmailMapi returned
123701.86 0 eng send attempt 1 result = success
123701.97 0 eng prog end 12:37:01 09 Mar
124129.98 0 eng prog start 12:41:29 09 Mar
124130.09 0 que found 1/41
124130.11 0 SendEmailMapi 2
124130.11 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
124130.14 0 SendEmailMapi returned
124130.14 0 eng send attempt 1 result = MAPI_E_LOGIN_FAILURE
124130.14 0 SendEmailMapi 2
124130.14 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
124130.16 0 SendEmailMapi returned
124130.16 0 eng send attempt 2 result = MAPI_E_LOGIN_FAILURE
124130.27 0 eng prog end 12:41:30 09 Mar
124132.03 0 eng prog start 12:41:32 09 Mar
124132.14 0 eng prog end 12:41:32 09 Mar
124528.38 0 eng prog start 12:45:28 09 Mar
124528.50 0 que found 1/41
124528.52 0 SendEmailMapi 2
124528.52 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
124528.55 0 SendEmailMapi returned
124528.55 0 eng send attempt 1 result = MAPI_E_LOGIN_FAILURE
124528.55 0 SendEmailMapi 2
124528.55 0 SendEmailMapi about to send to cnrctrials@mail.wch.sa.gov.au
124528.56 0 SendEmailMapi returned
124528.56 0 eng send attempt 2 result = MAPI_E_LOGIN_FAILURE
124528.67 0 eng prog end 12:45:28 09 Mar
124530.44 0 eng prog start 12:45:30 09 Mar
124530.55 0 eng prog end 12:45:30 09 Mar
124532.48 0 eng prog start 12:45:32 09 Mar
124532.59 0 eng prog end 12:45:32 09 Mar
Please can you have a look at this and see if you can determine why the emails are being sent 4 times each in total (ie once plus 3 retries)
Thanks for the trace. Think we found why same email was sent multiple times if MAPI was used.
Please place attached .exe in VG's 5.2.1 directory and try again, posting trace if problem still persists.
PS.
Are the database problems you were having initially all sorted out?
VgEmailSender_5.2.1001.zip
No, the database problems as illlustrated in the event log that I sent you, are still happening. Any clues?
Added more debugging around the area where error occurs. Please update v5.2.1 directory with this .exe and post trace.
What is the Database used?
Can you post the script and sample database so that we may reproduce the error?
How is the MAPI email send going after updating with new EmailSender.exe ?
[posted .EXE removed]
Edited by SupportTeam
The database is an Access 2000 database and it worked perfectly with the earlier version 5.1.8 of Voiceguide. I am not at work now, so I have not been able to test the .exe file you sent me. I will do it tomorrow morning. Here is an example of the database and the script for the module used.
[GetStrata]
Type=Database Query
DispSize=69
Txt=Using Birthweight, determine strata
DbDatabase=C:\VoiceGuide\Scripts\Randomisation\ACTORDSrand.mdb
DbUser=
DbConnectString=
DbSql=SELECT Strata FROM tblStrata WHERE (BirthWt = $RV[birthWt] and Gender = $RV[Gender])
on {Timeout 15} goto [ineligGA]
on {Fail} goto [ineligGA]
on {Success} goto [EntryCriteria]
What did you mean by this line:
Was this in relation to the email sender .exe file. If not, then you didn't attach another file.
The "Added more debugging around the area where error occurs. Please update v5.2.1 directory with this .exe and post trace" comment was related to the database problems you are having - the extra logging is in the vgmult.exe which was attached in same message.
New EmailSender.exe was posted in the previous post - please update your directory with both files and .zip and post both traces.
I have installed the files you gave me into the Voiceguide folder and have tried on 2 occasions to run the program. Attached are the .txt files it created.
I look forward to your response.
Trace_logs.zip
Looks like the sending of email is OK now....
Trace shows first send attempt did not work due to logon failure as but next send attempt was OK and no more attempts after that were made.
We've determined cause of database problem.
In VG.INI file, section [moduleDBQuery] change:
RecordsetGetRowsMax=0
to
RecordsetGetRowsMax=1000
(or some other high value)
Well that has fixed the problem of retrieving the information from the database, but now it will not say the digits for the study number. As I have said before, I have not changed the scripts since upgrading to v5.2.1 and all these other things keep happening now.
Can you please have a look at the script that I have attached with particular notice to this module. It is meant to say the numbers after the voice file: Your number is: and followed by Please press 1 to confirm or 2 to hear the number again. It is playing the two voice files but not the numbers.
[say StudyID]
Type=Say Numbers
DispSize=69
Txt=Say the Study Number
PlayFile1=Voice Files\YourRandNoIs.wav
PlayFile2=$RV[GetStudyID_1_1]
PlayFile3=Voice Files\ProceedNoAgain.wav
Replay=0,0
SayNbrType=Digits
on {Timeout 9} goto [Print StudyID]
on {1} goto [Print StudyID]
on {2} goto [say StudyID]
0311vgm.txt
The patch version had a bug...
Please see: http://voiceguide.com/forums/index.php?showtopic=1247
and download the .exe in the last post from that thread.
(BTW: the current download from our WWW has all these issues addressed and there are no such bugs in the main download - this bug was in the 'special patch' version which was posted in a couple of threads. I will now remove the .exe with the bug from previous post...)
Thanks that has worked.
Now, how do I get rid of the extra debugging code that appears in the *vgtm.txt file?
To reduce amount of data logged to file set the entries in VG.INI file section [Log] to a lower number (0 to turn off).
For log files which are to be supplied for us to look at we will need the tracing to be set to 10 (max value). otherwise log files do not have enough info in them for us to be able to diagnose problems.
Spoke too soon.
There is now a runtime error '6' overflow that is being created. I have attached the log file that may help.
Sarah
0312vgm.txt
