Problems with Send Email Module
please can you look at this output in the event logger and advise what I have done wrong. It won't let me send an email.
120617.27 7 [send Email test] Send Email
120617.27 7 RVreplace start: [test message xxx New Recruit $RV[GetStudyId_1_1]]
120617.27 7 RVreplace end: [test message xxx New Recruit 612300]
120617.27 7 RVreplace start (strlen>100)
120617.28 7 Que email to: xxxx@mail.wch.sa.gov.au
120617.28 0 eng EmailDbQueue_Insert_Error Syntax error (missing operator) in query expression ''This is an automatic message generated when VoiceGuide has randomised a woman into the xxx Trial - 612300
Hospital Code = 1000
Patient UR = 11
Mother's DOB = 12/05/84
Multiple Birth = 1
BirthWeight (1 = <1250gms, 2 = >=1250gms) = 1
Strata = 1
DateRand = 20/02/2004
Time Rand = 12:05:57
StudyID = 612300
AllocGroup = Yellow
', '', 0, 'MAPI', 0, 0, '', '', '', 0, '', 0, 0, '', '', '', 0, 0, 3, 10)'.
Any help would be greatly appreciated.
I am using the latest version....I think...5.1.7
The Script is as follows
[send Email test]
Type=Send Email
DispSize=69
Txt=Send email message and attachments.
strEmailAddrTo=cnrctrials@mail.wch.sa.gov.au
strEmailSubject=test message DINO New Recruit $RV[GetStudyId_1_1]
strEmailMessageText=This is an automatic message generated when VoiceGuide has randomised a woman into the DINO Trial - $RV[GetStudyId_1_1]\
Hospital Code = $RV[Enter Hospital Code]\
Patient UR = $RV[EnterUR]\
Mother's DOB = $RV[MDOB_DAY]/$RV[MDOB_MONTH]/$RV[MDOB_YEAR]\
Multiple Birth = $RV[MultipleBirth]\
BirthWeight (1 = <1250gms, 2 = >=1250gms) = $RV[birthWeight]\
Strata = $RV[GetStrata_1_1]\
DateRand = $RV[Date]\
Time Rand = $RV[Time]\
StudyID = $RV[GetStudyId_1_1]\
AllocGroup = $RV[GetStudyId_2_1]\
strEmailAttachmentFileName=
iEmailAttachmentDeleteAfterSend=0
strEmailReturnAddress=
strEmailReturnName=
strEmailCC=
strEmailBCC=
lEmailSendRetries=3
lEmailRetriesDelay=10
strEmailSendMethod_1=MAPI
strEmailSmtpServ_1=
lEmailSmtpPort_1=0
iEmailSmtpUseAuth_1=0
strEmailSmtpAuthUser_1=
strEmailSmtpAuthPassword_1=
strEmailSendMethod_2=SMTP
strEmailSmtpServ_2=
lEmailSmtpPort_2=0
iEmailSmtpUseAuth_2=0
strEmailSmtpAuthUser_2=
strEmailSmtpAuthPassword_2=
on {success} goto [Log Sent email]
on {fail} goto [Log Sent email]
Position=234,990
thanks for your help in anticipation
Just tested with the module details provided and it worked fine for me (tested with 5.1.8).
Could you please try:
1. stop VG.
2. delete the EmailQue.mdb file in VoiceGuide's \data\ subdirectory
3. start VG and try running script again.
(If you have recently upgraded to v5.1.7 then EmailQue.mdb may be still in the old format and that may be causing your problems)
If you re still experiencing problems can you please try uninstalling v5.1.7 and installing v5.1.8 (current download from our WWW)
(you may want to backup your voicemailbox config before uninstalling v5.1.7)
I have now uninstalled version 5.1.7 and installed 5.1.8 as directed, and I can't even open it as I get a message "Runtime error 9 - subscript out of range and then it closes.
Please help me urgently as I am running out of time to get this up and running.
thanks
