Voice Guide Dont Play Any Thing Help Me
look i have downloaded the voice guide 5.1.8 for dialogic hope thas ok .as i am on win 2000 with D4/PCI card and when i use voice guide application staus come waiting for call
when call comes it picks the call but dont paly the script s
its hang up so what coud be the problem i have tried the given VGS files as well as my vgs same happnes ..
help me
s u asked for the print of the log file its here
121736.38 7 linedevstate 2048 0 0
121736.41 7 callstate OFFERING 65672 0 4
121736.41 7 Answer the call at 2/20/2004 12:17:36 PM
121736.41 7 lineAnswer(65672) => 65655
121736.42 7 callinfo CALLEDID
121736.42 7 callinfo ORIGIN
121736.42 7 ring 0
121736.95 7 callstate CONNECTED 65672,1,0
121736.97 7 WorkingModeTAPI@Connected=
121736.97 7 WorkingModeScript@Connected=
121736.00 7 Inband detection not enabled
121736.00 7 StartLoadedVgs at 2/20/2004 12:17:36 PM
121737.02 7 tapi Reply (LineEvReply) ok 65655 0
121737.02 7 [Get Client ID] Number Input
121737.02 7 [Get Client ID] Playing (PayGetId.wav)
121737.03 7 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32] file[PayGetId.wav]
121737.03 7 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>32] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav]
121737.03 7 Hanging up call... [srlib PlaySoundStart]
121737.05 7 RecSoundStop ok
121737.05 7 PlaySoundStop err=0
121737.05 7 fnHangupCall end
121737.06 7 tapie PlayEnd old line=7 0 662468
121738.98 7 linedevstate 2048 0 0
121738.00 7 callstate IDLE 65672 0 0
121738.00 7 WorkingMode@Idle=
121739.02 7 tapi Reply (LineEvReply) ok 65638 0
121740.08 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
121740.08 7 ReinitTelephony due to IDLE
121740.08 7 tapic lineDeallocateCall(MainCall:65672) 0
121740.23 7 lineOpen(7) => 0
121740.25 7 Waiting for a call...
121740.25 7 LineHandle=65621
thankx now its working fine ;)
so now tell me that VG is a free ware or i have to buy lisence as i want to develop some application on this ..
tell the details will this expire after some time ...
what if i want to purchase the software .. tell e the cost
problem i want that when the ring comes on VG then it picks the line after 2 rings what if i want o make it pick the line and start recording when some one picks the phone
reply plz
The license costs are listed on the orders page:
https://bne052v.webcentral.com.au/vs7822_se...re/vg4order.htm
It is not possible to determine if the handset connected "in parallel" had been picked up.
To record calls VG much answer the call and start recording - it can start playing a sound file over speakers first before starting recording to alert people that a call should be answered.
Then after VG answered the phone (and started recording) the other handset can be picked up.
as per our conversation on voice logger . my requirement is that when a call center agent picks up the call then immediately his/her conversation should get recorded what can be the alternative ;(
You should probably look into getting a dedicated passive call recorder, see companies like www.nice.com
