ODBC with MySQL problem, VG v4.7 (old version)
Hello,
I am using VoiceGuide 4.7 and have problems writing/updating databases via ODBC
I am using MySQL via MyODBC on a WIN2k server
All read actions (like SELECT from ..) are OK but for some reason I cannot write or update records via ODBC
I always get "ERROR: DB Execute: 3001,Invalid argument." in the event log.
Please help, I also tried a MS Access ODBC dbase but same problem.
Many thanks,
Peter
This is my test vgs script:
Version=4.5
DisplayType=
StartModule=Database Query 32
RunAtHangup=
StartWithoutAnswer=0
CtmAsiName=
[Database Query 32]
Type=Database Query
DispSize=69
Txt=Search the database for data. You can then use the returned results later in your script (see Result Variables), eg: in the Say Number module or as parameters to the program calles in a Run Program module.
DbDatabase=sql_imode
DbUser=
DbConnectString=ODBC;DRIVER={MySQL ODBC 3.51 Driver};server=localhost;database=sql_imode;user=root;password=;port=3306
DbSql=UPDATE sessies SET tijd_call='nu' WHERE ID=28962
Position=21,33
this is the eventlog:
43395 6 tapie linedevstate 2048 0 0
43395 6 tapie callstate OFFERING 0 4
43395 6 Answer the call
43405 6 lineAnswer(65727) => 66105
43405 6 tapie callinfo CALLEDID
43405 6 tapie callinfo ORIGIN
43415 6 tapie ring 0
43936 6 tapie callstate CONNECTED 65727,1,0
43946 6 WorkingModeTAPI=
43946 6 WorkingModeScript=
43966 6 tapi Reply 66105 0
43976 6 tapie callinfo MONITORMODES
43976 6 TimeoutClear
43976 6 [Database Query 32] DB Query
43986 6 ODBC mode used
44076 6 About to execute Action Query
44086 6 ERROR: DB Execute: 3001,Invalid argument.
44086 6 Hanging up call...
44096 6 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
44096 6 PlaySoundStop ok
44106 6 HangupCall lineDrop(6, 0) =>66329 (66329)
44106 6 fnHangupCall end
44116 6 tapi Reply 66243 LINEERR_OPERATIONFAILED [80000048]
45979 6 tapie linedevstate 2048 0 0
45989 6 tapie callstate IDLE 0 0
45989 6 WorkingMode@Idle=
45989 6 TimeoutClear
45999 6 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
46009 6 tapi Reply 66329 0
46981 6 Timer fired 6, 9008
46981 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
46991 6 Initialise telephony (due to IDLE)
46991 6 tapic lineDeallocateCall(MainCall:65727) 0
47061 6 Waiting for a call...
47071 6 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT
52078 6 Timer fired 6, 9025
v4.7 is a pretty old version now (3 years?) So it's a bit hard to comment on issues which you encounter with that version.
I'd recommend updating to v5.1 – there are many sites running a MySQL/MyODBC combination using VG v5.x with no problems.
