Call Log
I need to create a call log that will allow me to enter information that will be automatically alphabetized by client and flagged when duplicated. Is that possible? I would also like to create an automatic color-coded system for urgency and neccessity of each entry that I could click on to insert. Thank you for your input. The downside is, I am not very savy only when it comes to creating documents on the PC...but resourceful.
Sounds like you should be viewing the Scripts's log files (.CSV log files) in MS Excel - Excel allows you to sort rows based on data in columns etc...
Maybe you should setup your script to save data you consider urgent in a different log file altogether...
Probably best to find a local technically-savvy person to whom you can better explain how you wish to view & analyze your log data and they could suggest an appropriate application to use.
