Way2call
Help please,
I got way2call Hi-Phone Desktop.
I would like to record automatically incoming and outgoing phone calls.
What hookup should look like.
My hookup is:
from phone line ->phone(Hi-Phone)
line(Hi-Phone) -> my regular phone
USA(Hi-Phone)-> TO MY COMPUTER
When I try to make a phone call "VoiceGuide" asks me If I want to record,
I say yes but then it hangs up.
What is wrong?
[$RV_STARTTIME]{2/11/2004 10:46:55 AM}[$RV_DEVICEID]{7}[$RV_CIDNAME]{}[$RV_CIDNUMBER]{}[Call Alert_ResultReturn]{yes}[Record Coversation]{C:\Program Files\VoiceGuide\Scripts\Call Recorder\__0211_104658.wav}[Record Coversation_RecLen100ms]{10}[Record Coversation_EndRecCause]{silence}[Hangup Time]{2/11/2004 10:47:01 AM}
192959.03 7 callstate OFFERING 65911 0 4
192959.05 7 Start without answering the call
192959.05 7 StartLoadedVgs at 2/11/2004 7:29:59 PM
192959.05 7 ring 0
192959.05 7 [Call Alert] Running VB Script...
192959.05 7 RVreplace start (strlen>100)
192959.06 7 Run Script waiting... (shellid=1996, process=828)
193000.05 7 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
193000.05 7 task still running (shellid=1996, process=828)
193001.14 7 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
193001.14 7 task still running (shellid=1996, process=828)
193002.23 7 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
193002.23 7 task still running (shellid=1996, process=828)
193003.06 7 callstate CONNECTED 65911,0,0
193003.06 7 WorkingModeTAPI@Connected=
193003.06 7 WorkingModeScript@Connected=BeforeAnswerRun
193003.06 7 Inband detection not enabled
193003.06 7 [Call Alert] Running VB Script...
193003.06 7 RVreplace start (strlen>100)
193003.08 7 Run Script waiting... (shellid=1764, process=876)
193004.09 7 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
193004.09 7 task still running (shellid=1764, process=876)
193005.19 7 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
193005.19 7 task still running (shellid=1764, process=876)
193006.28 7 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
193006.28 7 task still running (shellid=1764, process=876)
193006.56 7 cl Run_ResultReturn >>yes<<
193006.56 7 [Record Coversation] Recording
193006.56 7 RVreplace start: [$RV_CIDNUMBER_$RV_CIDNAME_$RV_MM$RV_DD_$RV_HH$RV_NN$RV_SS.wav]
193006.56 7 RVreplace end: [__0211_193006.wav]
193006.58 7 RecSoundStart file[C:\Program Files\VoiceGuide\Scripts\Call Recorder\__0211_193006.wav] ok
193006.58 7 RecFile[C:\Program Files\VoiceGuide\Scripts\Call Recorder\__0211_193006.wav]
193008.02 7 cl Run_ResultReturn >>yes<<
193008.02 7 path {yes} not found
193008.02 7 Hanging up call... [RunResultReturn could not find module...]
193008.03 7 RecSoundStop ok
193008.03 7 PlaySoundStop ok
193009.64 7 fnHangupCall end
193009.66 7 LsAwaitingCalls EV_REC_FINISHED
193009.66 7 callstate IDLE 65911 0 0
193009.66 7 WorkingMode@Idle=
193009.66 7 tapi Reply (LineEvReply) ok 65894 0
193010.64 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
193010.64 7 ReinitTelephony due to IDLE start
193010.73 7 tapic lineDeallocateCall(MainCall:65911) 0
193011.25 7 lineOpen(7) => 0
193011.25 7 Waiting for a call...
193011.25 7 lineOpen(7)LineHandle=65877
193012.13 7 callstate UNKNOWN 65826 0 4
193012.13 7 callinfo CALLEDID
193018.17 7 callstate DIALTONE 65826 1 0
193025.73 7 callstate IDLE 65826 0 0
193025.73 7 WorkingMode@Idle=
193025.73 7 LineState(iLineId).iVgsIdx = 0
193026.80 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
193026.80 7 ReinitTelephony due to IDLE start
193027.31 7 lineOpen(7) => 0
193027.31 7 Waiting for a call...
193027.31 7 lineOpen(7)LineHandle=65809
193043.38 0 sys cleanup Start
193043.38 0 sys cleanup End
Trace shows that as well as receiving a response to go ahead with recording:
two seconds later something is sending another "go down "yes" path" command to VG:
Whatever is sending this second "yes" is what's causing your problems - you can see from trace that this is the reason why the call is hung up...
Please post the VG script that you are using...
I used the script that came with VoiceGuide.
(Call Recorder.vgs in Call Recorder folder)
Can you recommend please some simple script that would just start automatically recording phone calls without asking anything.
Thank you
Version=5.0
DefaultModuleDisplayHeight=
StartModule=Call Alert
RunAtHangup=
StartWithoutAnswer=1
CtmAsiName=
[Call Alert]
Type=Run VB Script
DispSize=69
Txt=When a Call arrives popup mesasge box displaying the Caller ID, asking whether the call should be recorded or not.
VbsWait=2
VbScript='Script : Call Recorder.vgs
'Module : Call Alert
if msgbox("Number : $RV_CIDNUMBER" & vbCrLf & "Name : $RV_CIDNAME", vbYesNo + vbQuestion , "Record Call ?") = vbYes then
vg.Run_ResultReturn $RV_DEVICEID, "yes"
else
vg.Run_ResultReturn $RV_DEVICEID, "no"
end if
set vg = Nothing
VbsHoldPlay=
on {success} goto [Record Coversation]
on {yes} goto [Record Coversation]
on {fail} goto [Do not record]
on {no} goto [Do not record]
on {timeout 30} goto [Do not record]
Position=132,23
Type=Record
DispSize=69
Txt=User selected to record the call. Record to a sound file which includes the Caller ID and time details in the filename.
RecFile=$RV_CIDNUMBER_$RV_CIDNAME_$RV_MM$RV_DD_$RV_HH$RV_NN$RV_SS.wav
PlayTone=OFF
Position=31,258
[Do not record]
Type=Hangup the Call
DispSize=69
Txt=User has selected not to record the call. Do not record. Detail of incoming call and an indication that user elected not to record it is still saved in the log file.
Position=240,254
[Call Alert EXE]
Type=Run Program
DispSize=69
Txt=Alternate way of asking user for selection. When a Call arrives run Popup.exe which shows Caller ID and asks whether the call should be recorded or not.
ProgramToRun=popup.exe $RV_LINEID
RunHoldPlay=
RunMode=1
RunWait=2
Position=133,121
