Voicemail
I have 126 messages in a mailbox however when I try to listen to the recorded messasges I receive a recording that states:
"There has been an error playing this file, please check the file format."
Could you please send us a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong.
Please also attach the file that is reported by VG as the one that is causing a problem...
I've attached the debug as follows but I am unsure of which file to attach.
A window has popped up with a
"Windows Script Host" Error
Script: C:\Program Files\VoiceGuide\data\vbs_8_8.vbs
Line: 58
Char: 7
Error: Permission Denied
Code: 800A0046
Source: Microsoft VBScript runtime error
VG_Debug.txt
The debug trace did not capture entire call - please make sure the trace window is open and saving to file before you make the call.
also, please attach the C:\Program Files\VoiceGuide\data\vbs_8_8.vbs (or whatever file will be mentioned in error report).
101928.32 8 linedevstate 2048 0 0
101928.32 8 callstate OFFERING 65672 0 4
101928.34 8 callinfo CALLEDID
101928.34 8 callinfo ORIGIN
101928.34 8 ring 0
101934.34 8 ring 2
101934.34 8 Could not obtain handle to kill process. (new call) 4028, 1496
101934.34 8 Answer the call at 12/02/2004 10:19:34 AM
101934.34 8 lineAnswer(65672) => 65655
101934.87 8 callstate CONNECTED 65672,1,0
101934.89 8 WorkingModeTAPI@Connected=
101934.89 8 WorkingModeScript@Connected=
101934.92 8 Inband detection not enabled
101934.92 8 StartLoadedVgs at 12/02/2004 10:19:34 AM
101934.92 8 tapi Reply (LineEvReply) ok 65655 0
101934.92 8 [Welcome] Playing
101934.92 8 [Welcome] Playing (F:\ALS\IVR\Welcome.wav)
101934.95 8 PlaySoundStart ok [F:\ALS\IVR\Welcome.wav]
101934.95 8 RunModule PLAY end
101943.02 8 wb(25370300)
101943.07 8 Play End line[8] (id=253703)
101943.07 8 LsPlayMsg EV_PLAY_FINISHED
101943.07 8 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
101943.07 8 [Menu1] Playing
101943.07 8 [Menu1] Playing (F:\ALS\IVR\info or cust serv.wav)
101943.11 8 PlaySoundStart ok [F:\ALS\IVR\info or cust serv.wav]
101943.11 8 RunModule PLAY end
101951.09 8 dtmf 2 (65672,50,2)
101951.09 8 LsPlayMsg 2
101951.11 8 voicemail used: Scripted
101951.11 8 stack idx=1
101951.11 0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\VmLm.vgs at idx=2
101951.17 8 PlaySoundStop ok
101951.17 8 [VmLmStart] Running VB Script...
101951.17 8 RVreplace start (strlen>100)
101951.20 8 Run Script waiting... (shellid=4028, process=1516)
101951.23 0 cl Vm_VmbConfig_Get 0660, DeleteAfterForward
101951.25 8 cl Run_ResultReturn >>[Key_VmLmStopRecAndPlay]{1}[Key_VmLmDelRecRecAgain]{2}[Key_VmLmSaveAndPlayGre
ting]{3}[Key_VmLmDeleteGoGroupPrevious]{4}[Key_VmLmDeleteAndPlayGreeting]{5}[Key
VmLmDeleteGoGroupNext]{6}[Key_VmLmSaveGoVmLogin]{8}[Key_VmLmSaveVmExit]{0}[Key_V
LmSaveGoLmRecMsgMenu]{#}[RecMessage]{}[VmbWelcMsg]{C:\Program Files\VoiceGuide\data\VmWelc\0660.wav}<<
101951.27 8 [VmLmWelc] Playing
101951.27 8 RVreplace start: [$RV[VmbWelcMsg]]
101951.27 8 RVreplace end: [C:\Program Files\VoiceGuide\data\VmWelc\0660.wav]
101951.28 8 [VmLmWelc] Playing (C:\Program Files\VoiceGuide\data\VmWelc\0660.wav)
101951.30 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\data\VmWelc\0660.wav]
101951.30 8 RunModule PLAY end
101953.66 8 dtmf 8 (65672,56,2)
101953.66 8 LsPlayMsg 8
101953.72 8 PlaySoundStop ok
101953.72 8 [VmLmMenu] Running VB Script...
101953.73 8 RVreplace start (strlen>100)
101953.80 8 Run Script waiting... (shellid=1552, process=1504)
101953.82 8 cl Script_Goto 8, vmLogin.vgs, VmLoginStart, [VmLmRec]{}
101953.84 2 tr NewVgsVgm_Goto vmLogin.vgs,VmLoginStart,[VmLmRec]{},,,0
101953.91 0 LoadedVgs_Find C:\Program Files\VoiceGuide\system\vm\vmLogin.vgs at idx=3
101953.91 2 tr NewVgsVgm_Goto 1
101953.92 2 tr NewVgsVgm_Goto 2
101953.94 8 [VmLoginStart] Running VB Script...
101953.95 8 RVreplace start (strlen>100)
101953.00 8 Run Script waiting... (shellid=4296, process=1512)
101953.00 2 tr NewVgsVgm_Goto end
101954.06 8 cl Run_ResultReturn >>[Key_VmMmNewMsgs]{1}[Key_VmMmSavedMsgs]{2}[Key_VmMmAdminGreeting]{3}[Key_VmMm
dminPin]{4}[Key_VmMmAdminForwardPhone]{5}[Key_VmMmRecMessage]{6}[Key_VmMmAdminNa
e]{7}[Key_VmMmGoVmLogin]{8}[Key_VmMmVmExit]{0}[Key_VmMmPlayMessageCounts]{#}[Key
VmRmReplayCurrent]{1}[Key_VmRmSaveAndPlayNext]{2}[Key_VmRmDeleteAndPlayNext]{3}[
ey_VmRmPlayPrevious]{4}[Key_VmRmPlayCurrent]{5}[Key_VmRmPlayNext]{6}[Key_VmRmPla
MessageInfo]{7}[Key_VmRmGoVmLogin]{8}[Key_VmRmExitRetrieveMessages]{0}[Key_VmAdm
nWelcMsgPlayCurrent]{1}[Key_VmAdminWelcMsgDeleteAndRecNew]{2}[Key_VmAdminWelcMsg
aveAndReturn]{3}[Key_VmAdminWelcMsgDeleteAndReturn]{4}[Key_VmSendMsg_StopRecAndP
ay]{1}[Key_VmSendMsg_DelRecAndRec]{2}[Key_VmSendMsg_SaveRecAndAddress]{3}[Key_Vm
endMsg_DelRecAndReturn]{4}[Key_VmSendMsg_DelRecAndReturn2]{0}[Key_VmSendMsg_Stop
ecAndPlayVmSendMenu]{#}[VmbId]{}[VmbLoginIntro]{none}<<
101954.07 8 [VmLoginAskVmb] Number Input
101954.07 8 RVreplace start: [$RV[VmbLoginIntro],$RV[PathSysVoice]VmbAccessGetVmbIdRetrieve.wav]
101954.11 8 RVreplace end: [none,C:\Program Files\VoiceGuide\system\voice\VmbAccessGetVmbIdRetrieve.wav]
101954.12 8 [VmLoginAskVmb] Playing (none,C:\Program Files\VoiceGuide\system\voice\VmbAccessGetVmbIdRetrieve.wav)
101954.17 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\VmbAccessGetVmbIdRetrieve.wav]
101956.17 8 dtmf 0 (65672,48,2)
101956.19 8 LsGetNbrsPlayWelcMsg 0
101956.25 8 PlaySoundStop ok
101956.27 8 [VmLoginAskVmb] Number Input 0
101956.28 8 path {0} not found
101956.57 8 dtmf 6 (65672,54,2)
101956.59 8 LsGetNbrsRxDigits 6
101956.61 8 [VmLoginAskVmb] Number Input 06
101956.62 8 path {06} not found
101956.89 8 dtmf 6 (65672,54,2)
101956.89 8 LsGetNbrsRxDigits 6
101956.92 8 [VmLoginAskVmb] Number Input 066
101956.94 8 path {066} not found
101957.30 8 dtmf 0 (65672,48,2)
101957.31 8 LsGetNbrsRxDigits 0
101957.32 8 [VmLoginAskVmb] Number Input 0660
101957.34 8 path {0660} not found
101958.09 8 dtmf # (65672,35,2)
101958.09 8 LsGetNbrsRxDigits #
101958.11 8 path {0660} not found
101958.12 8 [VmLoginAskPin] Number Input
101958.14 8 RVreplace start: [$RV[PathSysVoice]VmbAccessGetVmbPin.wav]
101958.16 8 RVreplace end: [C:\Program Files\VoiceGuide\system\voice\VmbAccessGetVmbPin.wav]
101958.17 8 [VmLoginAskPin] Playing (C:\Program Files\VoiceGuide\system\voice\VmbAccessGetVmbPin.wav)
101958.22 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\VmbAccessGetVmbPin.wav]
101959.11 8 dtmf 0 (65672,48,2)
101959.12 8 LsGetNbrsPlayWelcMsg 0
101959.19 8 PlaySoundStop ok
101959.19 8 [VmLoginAskPin] Number Input 0
101959.20 8 path {0} not found
101959.55 8 dtmf 6 (65672,54,2)
101959.55 8 LsGetNbrsRxDigits 6
101959.56 8 [VmLoginAskPin] Number Input 06
101959.57 8 path {06} not found
101959.91 8 dtmf 6 (65672,54,2)
101959.91 8 LsGetNbrsRxDigits 6
101959.92 8 [VmLoginAskPin] Number Input 066
101959.94 8 path {066} not found
102000.25 8 dtmf 0 (65672,48,2)
102000.25 8 LsGetNbrsRxDigits 0
102000.27 8 [VmLoginAskPin] Number Input 0660
102000.30 8 path {0660} not found
102000.66 8 dtmf # (65672,35,2)
102000.67 8 LsGetNbrsRxDigits #
102000.69 8 path {0660} not found
102000.70 8 [VmLoginCheckPin] Running VB Script...
102000.72 8 RVreplace start (strlen>100)
102000.75 8 Run Script waiting... (shellid=3480, process=148)
102000.78 0 cl Vm_VmbConfig_Get 0660, Pin
102000.80 8 cl Script_Goto 8, , VmMmMsgCountsCalc, [VmbId]{0660}
102000.81 2 tr NewVgsVgm_Goto ,VmMmMsgCountsCalc,[VmbId]{0660},,,0
102000.82 2 tr NewVgsVgm_Goto 1
102000.84 2 tr NewVgsVgm_Goto 2
102000.86 8 [VmMmMsgCountsCalc] Running VB Script...
102000.87 8 RVreplace start (strlen>100)
102000.92 8 Run Script waiting... (shellid=1356, process=1536)
102000.92 2 tr NewVgsVgm_Goto end
102001.22 8 cl Run_ResultReturn >>[VmMsgCount_New]{127}[VmMsgCount_Saved]{0}<<
102001.23 8 RVreplace start: [$RV[VmMsgCount_New]]
102001.25 8 RVreplace end: [127]
102001.27 8 [VmMmMsgCountsPlayNew] Say numbers: 127 as Number
102001.28 8 fn PlaySoundStartNumbers $RV[PathSysVoice]VmbAccessYouHave.wav, $RV[PathSysVoice]VmbAccessNewMessagesAnd.wav, 127, Number
102001.30 8 RVreplace start: [$RV[PathSysVoice]VmbAccessYouHave.wav]
102001.31 8 RVreplace end: [C:\Program Files\VoiceGuide\system\voice\VmbAccessYouHave.wav]
102001.32 8 RVreplace start: [$RV[PathSysVoice]VmbAccessNewMessagesAnd.wav]
102001.34 8 RVreplace end: [C:\Program Files\VoiceGuide\system\voice\VmbAccessNewMessagesAnd.wav]
102001.36 8 sVbsFunctionToUse=Number
102001.42 8 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_8_SayNumber.vbs)
102001.47 8 cl Play_Start C:\Program Files\VoiceGuide\system\voice\VmbAccessYouHave.wav,1.wav,hundred.wav,20.wav,7.wav,C:\Program Files\VoiceGuide\system\voice\VmbAccessNewMessagesAnd.wav
102001.55 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\VmbAccessYouHave.wav,C:\Program Files\VoiceGuide\system\voice\1.wav,C:\Program Files\VoiceGuide\system\voice\hundred.wav,C:\Program Files\VoiceGuide\system\voice\20.wav,C:\Program Files\VoiceGuide\system\voice\7.wav,C:\Program Files\VoiceGuide\system\voice\VmbAccessNewMessagesAnd.wav]
102007.36 8 wb(28025005)
102007.42 8 Play End line[8] (id=280250)
102007.42 8 LsSayNbrPlay EV_PLAY_FINISHED
102007.44 8 LsSayNbrPlay EV_TIMEOUT_GOTOMODULE
102007.45 8 RVreplace start: [$RV[VmMsgCount_Saved]]
102007.47 8 RVreplace end: [0]
102007.48 8 [VmMmMsgCountsPlaySaved] Say numbers: 0 as Number
102007.50 8 fn PlaySoundStartNumbers none, $RV[PathSysVoice]VmbAccessSavedMessages.wav, 0, Number
102007.52 8 RVreplace start: [$RV[PathSysVoice]VmbAccessSavedMessages.wav]
102007.53 8 RVreplace end: [C:\Program Files\VoiceGuide\system\voice\VmbAccessSavedMessages.wav]
102007.56 8 sVbsFunctionToUse=Number
102007.62 8 Started SayNumber VBScript OK. (C:\Program Files\VoiceGuide\data\vbs_8_SayNumber.vbs)
102007.66 8 cl Play_Start 0.wav,C:\Program Files\VoiceGuide\system\voice\VmbAccessSavedMessages.wav
102007.69 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\0.wav,C:\Program Files\VoiceGuide\system\voice\VmbAccessSavedMessages.wav]
102010.05 8 wb(28642101)
102010.11 8 Play End line[8] (id=286421)
102010.11 8 LsSayNbrPlay EV_PLAY_FINISHED
102010.12 8 LsSayNbrPlay EV_TIMEOUT_GOTOMODULE
102010.16 8 [VmMmMenuPlay] Playing
102010.16 8 RVreplace start: [$RV[PathSysVoice]VmbAccessMenu.wav]
102010.17 8 RVreplace end: [C:\Program Files\VoiceGuide\system\voice\VmbAccessMenu.wav]
102010.19 8 [VmMmMenuPlay] Playing (C:\Program Files\VoiceGuide\system\voice\VmbAccessMenu.wav)
102010.23 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\VmbAccessMenu.wav]
102010.23 8 RunModule PLAY end
102012.28 8 dtmf 1 (65672,49,2)
102012.30 8 LsPlayMsg 1
102012.36 8 PlaySoundStop ok
102012.37 8 [VmMmMenu] Running VB Script...
102012.39 8 RVreplace start (strlen>100)
102012.45 8 Run Script waiting... (shellid=3392, process=1404)
102012.48 8 VmMmMenu VmMsgList_Create(0660, 1, 1) sMsgMatch=[C:\Program Files\VoiceGuide\data\VmSave\0660_??????????_1_*.wav]
102012.66 8 cl Script_Goto 8, , VmRmPlayMsg, [VmMsgList_NewOrSaved]{1}[VmMsgCurr_Index]{0}[VmMsgCurr_Filename]{0660_111810574
_1_9__.wav}
102012.67 2 tr NewVgsVgm_Goto ,VmRmPlayMsg,[VmMsgList_NewOrSaved]{1}[VmMsgCurr_Index]{0}[VmMsgCurr_Filename]{0
60_1118105749_1_9__.wav},,,0
102012.69 2 tr NewVgsVgm_Goto 1
102012.69 2 tr NewVgsVgm_Goto 2
102012.70 8 [VmRmPlayMsg] Playing
102012.72 8 RVreplace start: [$RV[PathDataVm]VmSave\$RV[VmMsgCurr_Filename]]
102012.73 8 RVreplace end: [C:\Program Files\VoiceGuide\data\VmSave\0660_1118105749_1_9__.wav]
102012.75 8 [VmRmPlayMsg] Playing (C:\Program Files\VoiceGuide\data\VmSave\0660_1118105749_1_9__.wav)
102012.78 8 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>7] file[C:\Program Files\VoiceGuide\data\VmSave\0660_1118105749_1_9__.wav]
102012.82 8 RunModule PLAY end
102012.82 2 tr NewVgsVgm_Goto end
102012.84 8 tapie PlayEnd old line=8 0 291546
102017.34 8 Play End line[8] (id=291546)
102017.34 8 LsPlayMsg EV_PLAY_FINISHED
102017.36 8 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
102017.37 8 [VmRmPlayMenu] Playing
102017.39 8 RVreplace start: [$RV[PathSysVoice]VmbAccessListenMsgMenu.wav]
102017.41 8 RVreplace end: [C:\Program Files\VoiceGuide\system\voice\VmbAccessListenMsgMenu.wav]
102017.42 8 [VmRmPlayMenu] Playing (C:\Program Files\VoiceGuide\system\voice\VmbAccessListenMsgMenu.wav)
102017.47 8 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\VmbAccessListenMsgMenu.wav]
102017.47 8 RunModule PLAY end
102031.69 8 wb(29621800)
102031.75 8 Play End line[8] (id=296218)
102031.75 8 LsPlayMsg EV_PLAY_FINISHED
102032.09 8 dtmf 2 (65672,50,2)
102032.11 8 LsPlayMsgFinished 2
102032.12 8 [VmRmMenu] Running VB Script...
102032.14 8 RVreplace start (strlen>100)
102032.22 8 Run Script waiting... (shellid=4104, process=1548)
102033.20 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102033.22 8 task still running (shellid=4104, process=1548)
102034.32 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102034.34 8 task still running (shellid=4104, process=1548)
102035.45 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102035.47 8 task still running (shellid=4104, process=1548)
102036.57 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102036.59 8 task still running (shellid=4104, process=1548)
102037.70 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102037.72 8 task still running (shellid=4104, process=1548)
102038.82 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102038.84 8 task still running (shellid=4104, process=1548)
102039.95 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102039.97 8 task still running (shellid=4104, process=1548)
102041.07 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102041.09 8 task still running (shellid=4104, process=1548)
102042.20 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102042.22 8 task still running (shellid=4104, process=1548)
102043.32 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102043.34 8 task still running (shellid=4104, process=1548)
102044.45 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102044.47 8 task still running (shellid=4104, process=1548)
102045.57 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102045.59 8 task still running (shellid=4104, process=1548)
102046.72 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102046.73 8 task still running (shellid=4104, process=1548)
102047.84 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102047.86 8 task still running (shellid=4104, process=1548)
102048.97 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102048.98 8 task still running (shellid=4104, process=1548)
102050.09 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102050.11 8 task still running (shellid=4104, process=1548)
102051.22 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102051.23 8 task still running (shellid=4104, process=1548)
102052.34 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102052.36 8 task still running (shellid=4104, process=1548)
102053.47 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102053.48 8 task still running (shellid=4104, process=1548)
102054.59 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102054.61 8 task still running (shellid=4104, process=1548)
102055.72 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102055.73 8 task still running (shellid=4104, process=1548)
102056.84 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102056.86 8 task still running (shellid=4104, process=1548)
102057.97 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102057.98 8 task still running (shellid=4104, process=1548)
102059.09 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102059.11 8 task still running (shellid=4104, process=1548)
102100.22 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102100.23 8 task still running (shellid=4104, process=1548)
102101.34 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102101.36 8 task still running (shellid=4104, process=1548)
102102.47 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102102.48 8 task still running (shellid=4104, process=1548)
102103.59 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102103.61 8 task still running (shellid=4104, process=1548)
102104.72 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102104.73 8 task still running (shellid=4104, process=1548)
102105.84 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102105.86 8 task still running (shellid=4104, process=1548)
102106.97 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102106.98 8 task still running (shellid=4104, process=1548)
102108.09 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102108.11 8 task still running (shellid=4104, process=1548)
102109.22 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102109.23 8 task still running (shellid=4104, process=1548)
102110.34 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102110.36 8 task still running (shellid=4104, process=1548)
102111.48 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102111.48 8 task still running (shellid=4104, process=1548)
102112.57 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102112.57 8 task still running (shellid=4104, process=1548)
102113.67 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102113.67 8 task still running (shellid=4104, process=1548)
102114.77 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102114.77 8 task still running (shellid=4104, process=1548)
102115.86 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102115.86 8 task still running (shellid=4104, process=1548)
102116.95 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102116.95 8 task still running (shellid=4104, process=1548)
102118.05 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102118.05 8 task still running (shellid=4104, process=1548)
102119.14 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102119.14 8 task still running (shellid=4104, process=1548)
102120.23 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102120.23 8 task still running (shellid=4104, process=1548)
102121.36 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102121.36 8 task still running (shellid=4104, process=1548)
102122.45 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102122.45 8 task still running (shellid=4104, process=1548)
102123.55 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102123.55 8 task still running (shellid=4104, process=1548)
102124.64 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102124.64 8 task still running (shellid=4104, process=1548)
102125.73 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102125.73 8 task still running (shellid=4104, process=1548)
102126.82 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102126.82 8 task still running (shellid=4104, process=1548)
102127.92 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102127.92 8 task still running (shellid=4104, process=1548)
102129.02 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102129.02 8 task still running (shellid=4104, process=1548)
102130.11 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102130.11 8 task still running (shellid=4104, process=1548)
102131.20 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102131.20 8 task still running (shellid=4104, process=1548)
102132.30 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102132.30 8 task still running (shellid=4104, process=1548)
102133.39 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102133.41 8 task still running (shellid=4104, process=1548)
102134.52 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102134.53 8 task still running (shellid=4104, process=1548)
102135.64 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102135.64 8 task still running (shellid=4104, process=1548)
102136.75 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102136.75 8 task still running (shellid=4104, process=1548)
102137.84 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102137.84 8 task still running (shellid=4104, process=1548)
102138.94 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102138.94 8 task still running (shellid=4104, process=1548)
102140.03 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102140.03 8 task still running (shellid=4104, process=1548)
102141.12 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102141.12 8 task still running (shellid=4104, process=1548)
102142.22 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102142.22 8 task still running (shellid=4104, process=1548)
102143.31 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102143.32 8 task still running (shellid=4104, process=1548)
102144.44 8 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE
102144.45 8 task still running (shellid=4104, process=1548)
102145.02 0 btn Hangup on line 8
102145.05 8 LsRunWaitTillFinished EV_TIMEOUT_HANGUP
102145.06 8 Hanging up call...
102145.07 8 RecSoundStop ok
102145.09 8 PlaySoundStop ok
102145.12 8 fnHangupCall end
102145.16 8 linedevstate 2048 0 0
102145.19 8 callstate IDLE 65672 0 0
102145.20 8 WorkingMode@Idle=
102145.23 8 tapi Reply (LineEvReply) ok 65638 0
102146.25 8 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
102146.27 8 ReinitTelephony due to IDLE start
102146.28 8 tapic lineDeallocateCall(MainCall:65672) 0
102146.45 8 lineOpen(8) => 0
102146.48 8 Waiting for a call...
102146.50 8 lineOpen(8)LineHandle=65621
vbs_8_7.vbs
The problem seems to be with the file C:\Program Files\VoiceGuide\data\VmSave\0660_1118105749_1_9__.wav
Can you play this WAV file OK using windows? - just double click on sound file and see what happens.
Please post this file here and we can have a look at is as well.
Any chance that this sound file was at the time opened by another program?
In the meantime I'd recommend just moving this problem sound file to another directory - this should allow you to access the rest of your mailbox.
