Sending Email Problems
We have problems with sending emails from vg.
log:
074353.358 7 7 3 RunModule start Send Email, [send Email], iModuleIdx=618, previous: vgm=618, vgs=11:11
074353.359 7 7 3 state [send Email] Send Email
074353.358 77 7 3 db odbc query completed.
074353.359 7 7 3 rv replace start [$RV[id_proj_pg_email]]
074353.359 7 7 3 rv replace end [maciej@invoso.com]
Dnia: $RV_YY-$RV_MM-$RV_DD o godzinie: $RV_HH:$RV_NN abonent numeru: $RV_CIDNUMBER pozostawil nagranie w załaczniku.
074353.359 7 7 3 rv replace end [Dnia: 14-05-05 o godzinie: 07:43 abonent numeru: 502131638 pozostawil nagranie w załaczniku.
074353.359 7 7 3 rv replace start [c:\abc.mp3]
074353.359 7 7 3 rv replace end [c:\abc.mp3]
074353.360 7 7 3 rv add Send Email|maciej@invoso.com
074353.360 7 7 3 rv add Send Email_Subject|Wiadomosc poczty glosowej z infolinii TELESTRADA S.A.
074353.360 7 7 3 rv add Send Email_Message|Dnia: 14-05-05 o godzinie: 07:43 abonent numeru: 502131638 pozostawil nagranie w załaczniku.
074353.360 7 7 3 rv add Send Email_Attachment|c:\abc.mp3
074353.361 7 7 3 rv add Send Email_Cc|
074353.361 7 7 3 rv add Send Email_Bcc|infolinia@invoso.com
074353.361 7 7 3 email to: maciej@invoso.com
074353.361 7 AddEmailToSend from:infolinia@agenta.pl|infolinia@agenta.pl, to:maciej@invoso.com, cc:, bcc:infolinia@invoso.com, reply:infolinia@agenta.pl, subj:Wiadomosc poczty glosowej z infolinii TELESTRADA S.A., att:c:\callrecord\manager11\ID20140505074320183.mp3, usertoken:(<to>maciej@invoso.com</to><subject>Wiadomosc poczty glosowej z infolinii TELESTRADA S.A.</subject><guid>c2efcfac-a0e9-4a3d-a9c9-ee4520b127dd</guid>) smtp:ssl:smtp.agenta.pl|587 timeout:300sec, sParamsXml:
074353.362 7 SmtpClient created ok
074353.362 7 setting EnableSsl as port = 587
074353.362 7 .Host=smtp.agenta.pl .Port=587 .EnableSsl=True sCredentialUserName=[user]
074353.362 7 SmtpClient clientEs configured ok
074353.362 7 email send start <to>maciej@invoso.com</to><subject>Wiadomosc poczty glosowej z infolinii TELESTRADA S.A.</subject><guid>c2efcfac-a0e9-4a3d-a9c9-ee4520b127dd</guid>, timeout=300sec
074353.385 7 email SendAsync returned
074353.386 7 7 3 email queued for sending.
074353.386 7 7 3 rv add Send Email_SendResult|ok
074353.386 7 7 3 FindNextVgmTitleInPathList: next module title is=[Hangup the Call 1]
074353.386 7 7 3 t timer clear (force=False)
074353.386 7 7 3 RunModule start Hangup the Call, [Hangup the Call 1], iModuleIdx=621, previous: vgm=618, vgs=11:11
074353.386 7 7 3 HangupCall (Hangup Module) crn_in=0, L1=Disconnected, L2=Running_AfterHangup, lPlayId=0, lRecId=0
074353.386 7 7 3 ccrn_connected=0, crn_NewIncomingCall=0, crn_CurrentMakeCall=0, crn_InProcessOfReleasing=2cc01cb
074353.386 7 7 3 rv add Hangup Source|Hangup Module
074353.387 7 7 3 rv add DropCall_Source|Hangup the Call 1
074353.387 7 7 3 state Hanging up... [Hangup Module]
074353.387 7 7 3 WriteToLogFiles_CurrScriptOnly begin
074353.387 7 7 3 WriteToLogFiles_DoWrite begin : strLogFnameLessSuffix=C:\Program Files (x86)\VoiceGuide\Scripts\manager\manager_termination
074353.387 7 7 3 WriteToLogFiles_DoWrite : log subdirectory exists, strLogFnameLessSuffix=C:\Program Files (x86)\VoiceGuide\Scripts\manager\log\manager_termination
074353.798 77 email send error. <to>maciej@invoso.com</to><subject>Wiadomosc poczty glosowej z infolinii TELESTRADA S.A.</subject><guid>c2efcfac-a0e9-4a3d-a9c9-ee4520b127dd</guid> System.Net.Mail.SmtpException: Failure sending mail. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure.
at System.Net.Mail.SmtpConnection.ConnectAndHandshakeAsyncResult.End(IAsyncResult result)
at System.Net.Mail.SmtpClient.ConnectCallback(IAsyncResult result)
--- End of inner exception stack trace ---
074354.301 7 7 3 WriteToLogFiles_DoWrite completed
074354.301 7 7 3 RvSaveToLogFiles_CurrAndStack iScriptCallStack_LastUsed_Idx=0
074354.301 7 7 3 L2_set Idle_WaitingForNextCall (called from HangupCall)
074354.301 7 7 3 t timer set 3 sec : EV_TIMEOUT_AFTERIDLE_ALLOWOUT
074354.301 7 7 3 GoOnHoook_IssueDropCall start (crn_in=2cc01cb, crn_connected=0, crn_makecall=0, crn_NewCallArriving=0, crn_InProcessOfReleasing=2cc01cb, L1=Disconnected)
074354.301 7 7 3 t timer set 20 sec : EV_TIMEOUT_WAITFORIDLEAFTERDropCall
074354.302 7 7 3 set crn_InProcessOfReleasing=2cc01cb
074354.302 7 7 3 set crn_connected=0 (called from GoOnHoook_IssueDropCall)
074354.302 7 7 3 q_tel + cmd_DropCall 2cc01cb [0,0,0,0,0][||||]
074354.302 7 7 3 GoOnHoook_IssueDropCall end
074354.302 8 7 3 q_tel run cmd_DropCall 2cc01cb 00:00:00 max:5|00:00:00.2790160
VG not using alternate email send method. Each time after unsuccessful email send process VG terminating module.
We use configuration:
SMTP Server: ssl:smtp.agenta.pl
port:587
This same configuration settings working on thunderbird but not in VG.
The error returned by .NET's email sending routines is:
This apparently can be caused by the email server's SSL certificate not being imported in properly, or SSL certificate was actually created for a differnet URL, or there is a date mismatch on the machines, etc.
Some trobleshooting instructions from Microsoft for this error can be found here: http://blogs.msdn.com/b/jpsanders/archive/2009/09/16/troubleshooting-asp-net-the-remote-certificate-is-invalid-according-to-the-validation-procedure.aspx?Redirected=true
other problem:
082912.225 7 SmtpClient created ok
082912.225 7 setting EnableSsl as port = 587
082912.225 7 .Host=ta.hb.pl .Port=587 .EnableSsl=True sCredentialUserName=[poczta.glosowa.infolinii@telestrada.hb.pl]
082912.225 7 SmtpClient clientEs configured ok
082912.225 7 email send start <to>maciej@____.pl</to><subject>Wiadomosc poczty glosowej z infolinii TELESTRADA S.A.</subject><guid>6b5f1629-5ae1-4567-82fb-acbf46deb640</guid>, timeout=300sec
082916.231 7 ERROR v7.4.5207.24383 (2014-04-04 13:32:46.19) AddEmailToSend SendAsync: The SMTP host was not found.
082916.231 7 31 11 email not queued for sending.
082916.231 7 31 11 rv add Send Email_SendResult|The SMTP host was not found.
082916.232 7 31 11 FindNextVgmTitleInPathList: next module title is=[Hangup the Call 1]
082916.232 7 31 11 t timer clear (force=False)
082916.232 7 31 11 RunModule start Hangup the Call, [Hangup the Call 1], iModuleIdx=566, previous: vgm=563, vgs=11:11
082916.232 7 31 11 HangupCall (Hangup Module) crn_in=0, L1=Disconnected, L2=Running_AfterHangup, lPlayId=0, lRecId=0
082916.232 7 31 11 ccrn_connected=0, crn_NewIncomingCall=0, crn_CurrentMakeCall=0, crn_InProcessOfReleasing=2b00327
082916.232 7 31 11 rv add Hangup Source|Hangup Module
082916.232 7 31 11 rv add DropCall_Source|Hangup the Call 1
But Host=poczta.hb.pl not ta.hb.pl as show VG.
Why VG cutting part of HOST name?
