Music On Hold Problem
VG not stoping MusicOnHold
we use MoH in transfer call module and with loop we try to connect with first available Agent.
To test see connection with session id: ID20140224131809164
on 4th channel
After try to connect we need to go to "medivet komunikat" module to play prompt, but VG still playing MoH.
We try to add
DoNotStopMOH=0
and VBS:
"set vg = CreateObject("vgServices.CommandLink")
vg.Play_Stop $RV_LINEID
set vg = Nothing
but without success.
On VG monitor we see "medivet komunikat" module with task play prompt but caller still hear transfer calll module MoH
Still coming back needed functionality witch terminating prompt when starting module including prompt.
Maybe solution is to add option (terminate any prompt) in modules included prompt option ?
vgEngine_2014_02_24.zip
It looks like the VBScript module has a problem running.
This system is using an external script interpreter to run the VBScript modules.
If this system is running latest VoiceGuide version then did you change the VG.INI [moduleRunScript] Engine entry to us an external engine instead of the default internal engine?
VBScripts ran using external engine can be affected by anti-virus programs or similar. We recommend using the default internal engine to execute VBScripts.
131813.866  6  10   4 state [Transfer Call fa with CALLER ID] Monitored Dial and Connect to 48616225502
131813.866  6  10   4       dial  IvrDevState strCID=[], strDialoutOptions=[<CallerId>$RV_CIDNUMBER</CallerId><RV>[CDR_user]{$RV[session_id]}</RV>]
131813.867  6  10   4       dial  sCidSentThisCall=$RV_CIDNUMBER (extracted from strDialoutOptions)
131813.867  6  10   4       rv    replace start [$RV_CIDNUMBER]
131813.867  6  10   4       rv    replace end   [224896039]
131813.867  6  10   4       dial  sCidSentThisCall=[224896039] (post RV replace)
131813.867  6  10   4       rv    replace start [<CallerId>$RV_CIDNUMBER</CallerId><RV>[CDR_user]{$RV[session_id]}</RV>]
131813.867  6  10   4       rv    replace end   [<CallerId>224896039</CallerId><RV>[CDR_user]{ID20140224131809164}</RV>]
131813.867  6  10   4       dial  strDialoutOptions=[<CallerId>224896039</CallerId><RV>[CDR_user]{ID20140224131809164}</RV>] (post RV replace)
131813.867  6  10   4       outbound call announce message not defined. vgm=299 [Transfer Call fa with CALLER ID]
131813.867  6  10   4       calling FindFreeLine
131813.867  6  10   4       dial  found free dev=59 (iLid_OutboundLeg=172, iLid=10)
131813.867  6  10   4       dial  str2LineRecordToThisFile=[]
131813.868  6  10   4       moh file [$RV[Sound_on_Call]]
131813.868  6  10   4       FindSoundFile start [$RV[Sound_on_Call]]
131813.868  6  10   4       rv    replace start [$RV[Sound_on_Call]]
131813.868  6  10   4       rv    replace end   [komunikaty\ring_multiple_medivet_long.wav]
131813.868  6  10   4       moh play start [5] : $RV[Sound_on_Call]
131813.868  6  10   4       FindSoundFile start [C:\Program Files (x86)\VoiceGuide\Scripts\manager\komunikaty\ring_multiple_medivet_long.wav]
131813.868  6  10   4 t     timer clear (force=False)
131813.868  6  10   4       q_tel +     cmd_PlayStart -450229 ,C:\Program Files (x86)\VoiceGuide\Scripts\manager\komunikaty\ring_multiple_medivet_long.wav []
131813.868  6  10   4       play  start ok, playId=-450229
131813.868  6  10   4       rv    replace start [ $RV[insert_call_order_timeout_$RV[kolejnosc]]]
131813.868  6  10   4       rv    replace end   [ 30]
131813.868  6  10   4 t     timer set   30 sec : EV_TIMEOUT_GOTOMODULE
131813.868  6  10   4       sRvOutboundLeg=[CDR_user]{ID20140224131809164}, strDialoutOptions=<CallerId>224896039</CallerId><RV>[CDR_user]{ID20140224131809164}</RV>
131813.875  7  10   4       q_tel run   cmd_PlayStart 0 00:00:00.0070004 max:4|00:00:00.3200183
131910.216  6  10   4 state [Do Not Stop MOH_podaj numer_108] Evaluate [0]
131910.216  6  10   4       eval  [0]
131910.216  6  10   4       eval  InvokeMember Eval returned
131910.216  6  10   4       rvns  add   Do Not Stop MOH_podaj numer_108_Input|0
131910.216  6  10   4       rvns  add   Do Not Stop MOH_podaj numer_108|0
131910.216  6  10   4       creating new (non-global) rv : DoNotStopMOH
131910.216  6  10   4       rvns  add   DoNotStopMOH|0
131910.216  6  10   4       Eval Expr result:[0] stored in RV[DoNotStopMOH]
131910.216  6  10   4       bDoNotStopMoh = false
131910.216  6  10   4       path {0} not found
131910.216  6  10   4       matching path not found [0], try boolean paths.
131910.216  6  10   4       FindNextVgmTitleInPathList: next module title is=[STOP ring not reachable targets_109]
131910.216  6  10   4       matching path found (Boolean False)
131910.216  6  10   4 t     timer clear (force=False)
131910.216  6  10   4       RunModule start Run VB Script, [STOP ring not reachable targets_109], iModuleIdx=1099, previous: vgm=1100, vgs=19:19
131910.216  6  10   4 t     timer set   30 sec : EV_TIMEOUT_HANGUP
131910.216  6  10   4       QueueUserWorkItem scrmod_RunVbs.RunModule call
131910.216 23  10   4 state [STOP ring not reachable targets_109] type: Script_VBScript, iRunWait=1
131910.216 23  10   4       rv    replace start
set vg = Nothing
131910.217 23  10   4       rv    replace end   [set vg = CreateObject("vgServices.CommandLink")
vg.Play_Stop 10
vg.Run_ResultReturn 10, "success"
set vg = Nothing]
131910.217 23  10   4       script will be ran from file: C:\Program Files (x86)\VoiceGuide\temp\vbs_10_1.vbs
131910.217 23  10   4       on_hold_file=, iModuleIdx=1099
131910.217 23  10   4       delete existing: C:\Program Files (x86)\VoiceGuide\temp\vbs_10_1.vbs
131910.217 23  10   4       current objVbsOrExeProcess (vbsrun) : id=8640, handle=20844, hash=45122392, hasExited=True, startTime=2014-02-24 13:16:36, exitTime=2014-02-24 13:16:36
131910.217 23  10   4       RunVBScriptFile [cscript][C:\Program Files (x86)\VoiceGuide\temp\vbs_10_1.vbs][] timeout=60 (vbsPath=C:\Program Files (x86)\VoiceGuide\temp), start (new Process)
131910.217 23  10   4       objProcess.Start call
131910.226 23  10   4       objProcess.Start returned. handle=20952, id=11044, hash=14795945, starttime=2014-02-24 13:19:10, HasExited=False
131910.229 23  10   4       VBScript started [C:\Program Files (x86)\VoiceGuide\temp\vbs_10_1.vbs], handle=20952, VbsOrExeProcess.WorkingSet=[2269184]
131910.229 23  10   4       RunModule_Script_AfterScriptStarted start
131910.229 23  10   4       Run Script waiting. iRunWait=1 (process:20952)
131910.229 23  10   4 t     timer set   1 sec : EV_TIMEOUT_CHECKONSTATE
131910.229 23  10   4       moh file not specified
131911.305  3  10   4 timer EV_TIMEOUT_CHECKONSTATE
131911.305  3  10   4       q_scr +     evScriptEvent 9007 EV_TIMEOUT_CHECKONSTATE
131911.305  6  10   4       q_scr run   evScriptEvent sCode=[EV_TIMEOUT_CHECKONSTATE] iActionID=0, crn=0 [0|0|0|0|0][|||||] 00:00:00 max:3|00:00:00.0280016
131911.305  6  10   4       se    EV_TIMEOUT_CHECKONSTATE 9007  0|0|0  || LineState=LS_RUN_WAITTILLFINISHED
131911.305  6  10   4       LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE lCode2Str=EV_TIMEOUT_CHECKONSTATE
131911.305  6  10   4       Process.HasExited flag set (System.Diagnostics.Process (wscript))
131911.305  6  10   4       task completed. vgm=1099, iRunWait=1, iRunWait_ExeResult_NextVgm=0=[]
131911.305  6  10   4       ExeResult_NextVgm has not been set. check for Result file.
131911.305  6  10   4       no result file returned from program (VGRUNRESULT_10.TXT).
131911.305  6  10   4       LsRunWaitTillFinished LsRunWaitChooseNext boolExeResult=False
131911.305  6  10   4       FindNextVgmTitleInPathList: next module title is=[medivet komunikat]
131911.306  6  10   4       task completed LsRunWaitChooseNext iNextVgm=367
131911.306  6  10   4 t     timer clear (force=False)
131911.306  6  10   4       RunModule start Play, [medivet komunikat], iModuleIdx=367, previous: vgm=1099, vgs=19:19
131911.306  6  10   4       [medivet komunikat] VGMTYPE_PLAY run start
131911.306  6  10   4       CheckForAnyPlayActionsAndSetkeysIfNecessary no PlayActions, vgmidx=367, strPaths=on {timeout 1} goto [insert_call_order]
131911.306  6  10   4       PrepareAndPlayWavAndTts start iModuleIdx=367, iPlayFileIdx=1, bMakeTtsFile=True, sSoundFileIs=
131911.306  6  10   4       PrepareAndPlayWavAndTTS sPlayFile=C:\Program Files (x86)\VoiceGuide\Scripts\manager\moh\medivet_komunikat.wav
131911.306  6  10   4 state [medivet komunikat] Playing wav (C:\Program Files (x86)\VoiceGuide\Scripts\manager\moh\medivet_komunikat.wav)
131911.306  6  10   4       FindSoundFile start [C:\Program Files (x86)\VoiceGuide\Scripts\manager\moh\medivet_komunikat.wav]
131911.306  6  10   4       q_tel +     cmd_PlayStart -392789 ,C:\Program Files (x86)\VoiceGuide\Scripts\manager\moh\medivet_komunikat.wav []
I attach actual data about VG version.
I don't find any [moduleRunScript] Engine option in vg.ini file.
No antivir software instaled on this server.
Any hint?
vgEngine_start.log
Please update system to the latest release of VoiceGuide that is available from our WWW Downloads page, and post traces as before if the problem still persists.
The latest version of VoiceGuide by default uses an internal engine to execute any VBScript modules
Problem not solved.
module [MoH connecting_permission true] playing prompt not following to next module.
Please post the VoiceGuide Debug Traces that capture system startup and that demonstrate the situation encountered.
We can then see what is happening on your system.
VoiceGuide Debug Traces are the files created in Voiceguide’s \log\ subdirectory.
Please .ZIP up any traces before posting them on the support forum.
It's the vgEngine and ktTel trace files.
Still VG stopping on VBS module
vg.Play_Start $RV_LINEID, "C:\Program Files (x86)\VoiceGuide\Scripts\manager\komunikaty\ring_multiple.wav"
set vg = Nothing
even option " Do not wait for VB Script to complete."
Other options:
set vg = Nothing
working properly.
0226_1543_vgEngine.zip
0226_ktTel.zip
Traces show that VBScripts are running fine now - and as you confirm the PlayStop issued from a VBScript module is ran and stops the playing of the On-Hold Message/Music.
In the other, new issue that you raise:
When you say that "VG stopping on VBS module" do you mean that it is not progressing to next module after running that script?
Please try adding a Run_ResultReturn function call to that module. VoiceGuide will then be able to move to next module from the VBScript module.
Also, we would recommend using a "Play" type to play a sound file.
Using a "Run VBscript" type module to play a sound file adds overheard and does not start the playing of sound file as quickly as a "Play" type module.
This version will go down a Success path in VBScript module immediately if the module's wait option is set to "Do not Wait"
[old link removed]
