Error Recording
I am trying to use the record module to record a call but it does not record and shows an error on the log.
Please can you take a look.
Matt Thompson
105926.84 11 linedevstate 2048 0 0
105926.86 11 callstate OFFERING 65570 0 4
105926.86 11 Answer the call at 04/02/2004 10:59:26
105926.88 11 lineAnswer(65570) => 65553
105926.89 11 callinfo CALLEDID
105926.89 11 callinfo ORIGIN
105926.91 11 ring 0
105927.47 11 callstate CONNECTED 65570,1,0
105927.47 11 WorkingModeTAPI@Connected=
105927.47 11 WorkingModeScript@Connected=
105927.51 11 Inband detection not enabled
105927.51 11 StartLoadedVgs at 04/02/2004 10:59:27
105927.52 11 tapi  Reply (LineEvReply) ok 65553 0
105927.55 11 [Set Sound Files] Evaluate ["C:\Program Files\VoiceGuide\System\voice_sue"]
105927.55 11 .Eval(Cstr("C:\Program Files\VoiceGuide\System\voice_sue"))
105927.55 11 Eval Expr result:[C:\Program Files\VoiceGuide\System\voice_sue] stored in $RV[DIRSYSTEMVOICE]
105927.55 11 path {C:\Program Files\VoiceGuide\System\voice_sue} not found
105927.55 11 [Member Number] Number Input
105927.55 11 [Member Number] Playing (Sounds\input-access-code.wav)
105927.70 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\START\Sounds\input-access-code.wav]
105934.69 11 wb(45622700)
105934.95 11 Play End line[11] (id=456227)
105934.95 11 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
105935.47 11 dtmf 9   (65570,57,2)
105935.47 11 LsGetNbrsRxDigits 9
105935.47 11 [Member Number] Number Input 9
105935.47 11 path {9} not found
105935.89 11 dtmf 9   (65570,57,2)
105935.89 11 LsGetNbrsRxDigits 9
105935.89 11 [Member Number] Number Input 99
105935.89 11 path {99} not found
105936.52 11 dtmf 9   (65570,57,2)
105936.52 11 LsGetNbrsRxDigits 9
105936.52 11 [Member Number] Number Input 999
105936.53 11 path {999} not found
105937.43 11 dtmf 8   (65570,56,2)
105937.43 11 LsGetNbrsRxDigits 8
105937.44 11 [Member Number] Number Input 9998
105937.75 11 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
105937.75 11 [3 way call] Announced Conference to 0034661180060 (TAPI)
105937.75 11 fn    SrSetupConferenceTapi
105937.75 11 [3 way call] Number: 0034661180060
105937.76 11 lineSetupConference(65570,65638,0,0) in SrSetupConferenceTapi => 65536
105939.91 11 tapi  Reply (LineEvReply) ok 65536 0
105939.91 11 callstate CONFERENCED 65570 0 0
105939.93 11 linedevstate 2048 0 0
105939.93 11 callstate DIALTONE 66441 2 0
105939.93 11 lineDial(66441,0034661180060) => 66458
105939.95 11 callstate ONHOLDPENDCONF 66475 0 0
105939.95 11 callstate DIALING 66441 0 0
105939.96 11 callstate PROCEEDING 66441 0 0
105939.96 11 callinfo CALLEDID
105949.42 11 callstate CONNECTED 66441,1,0
105949.42 11 WorkingModeTAPI@Connected=SetupConferenceAnnounced
105949.42 11 WorkingModeScript@Connected=
105949.43 11 lineMonitorDigits(66441) => 0
105949.43 11 [3 way call] Playing (Sounds\announced-conference-call.wav)
105949.61 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\START\Sounds\announced-conference-call.wav]
105949.63 11 tapi  Reply (LineEvReply) ok 66458 0
105951.45 11 wb(47810900)
105951.48 11 Play End line[11] (id=478109)
105951.48 11 LsXferPlayAnn EV_PLAY_FINISHED
105951.48 11 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
105951.49 11 [3 way call] Playing (Sounds\announced-conference-call.wav)
105951.73 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\START\Sounds\announced-conference-call.wav]
105953.57 11 wb(48017200)
105953.61 11 Play End line[11] (id=480172)
105953.61 11 LsXferPlayAnn EV_PLAY_FINISHED
105953.61 11 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
105953.61 11 [3 way call] Playing (Sounds\announced-conference-call.wav)
105953.75 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\START\Sounds\announced-conference-call.wav]
105955.61 11 wb(48229500)
105955.64 11 Play End line[11] (id=482295)
105955.64 11 LsXferPlayAnn EV_PLAY_FINISHED
105955.64 11 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
105955.64 11 [3 way call] Playing (Sounds\announced-conference-call.wav)
105955.77 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\START\Sounds\announced-conference-call.wav]
105957.58 11 wb(48432800)
105957.75 11 Play End line[11] (id=484328)
105957.75 11 LsXferPlayAnn EV_PLAY_FINISHED
105957.75 11 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
105957.75 11 [3 way call] Playing (Sounds\announced-conference-call.wav)
105957.92 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\START\Sounds\announced-conference-call.wav]
105959.71 11 wb(48643100)
105959.95 11 Play End line[11] (id=486431)
105959.95 11 LsXferPlayAnn EV_PLAY_FINISHED
105959.95 11 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
105959.96 11 [3 way call] Playing (Sounds\announced-conference-call.wav)
110000.23 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\START\Sounds\announced-conference-call.wav]
110002.07 11 wb(48864400)
110002.11 11 Play End line[11] (id=488644)
110002.11 11 LsXferPlayAnn EV_PLAY_FINISHED
110002.11 11 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
110002.11 11 [3 way call] Playing (Sounds\announced-conference-call.wav)
110002.24 11 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\START\Sounds\announced-conference-call.wav]
110003.08 11 dtmf 1   (66441,49,2)
110003.08 11 LsXferPlayAnn 1
110003.18 11 PlaySoundStop ok
110003.24 11 dtmf 1   (65570,49,2)
110003.24 11 LsXferPlayAnn 1
110003.26 11 PlaySoundStop ok
110004.16 11 LsXferPlayAnn EV_PLAY_FINISHED
110004.16 11 lineAddToConference(66475,66441) in LsXferPlayAnn => 66407
110004.16 11 As no timeout path specified, setting max talk time to 600 seconds.
110004.17 11 Going down Success path in LsXferPlayAnn_AcceptTransfer_TAPI
110004.17 11 [Record 1] Recording
110004.25 11 RecSoundStart err[3]
110004.25 11 Hanging up call...
110004.27 11 RecSoundStop ok
110004.30 11 PlaySoundStop ok
110004.35 11 fnHangupCall end
110004.35 11 RecFile[C:\Program Files\VoiceGuide\Scripts\recruitment\incomingcall\START\0204110004_11_.wav]
110004.38 11 tapi  Reply (LineEvReply) ok 66407 0
110004.39 11 tapi  Reply (LineEvReply) err 66424 LINEERR_RESOURCEUNAVAIL [8000004B]
Could you please try setting in VG.INI file, section [PBX] entries TransferControl_Modem and TransferControl_TelBoards to be their default values:
TransferControl_Modem=Generate
TransferControl_TelBoards=Generate
Then run the transfer script again and post the trace here...
THanks that seems to have fixed it.... just a quick question... it appears my telco wont let me do blind conference calling -
Just a thought --- is there any way of the person answering the call accepting the call without actually pressing anything as we want to use voiceguide to record conference calls and obvioulsly as everyone is in a conference area there is no one physically picking the phone up and accepting/declining the calls......?
Please let me know.. Thanks...
p.s. do you have any idea when the sound file fix is ready? I;ve asked a couple of times but not heard from you
Your telco needs to be able to support the 'blind conference' feature if you want to use it on your system....
Keep in mind that you may build more complicated hookflash/DTMF play sequences by just using Play modules - this gives you great flexibility when issuing hookflashes/tones and is sometimes used when the "Call Transfer" module is deemed not sufficient (this is used rarely - Call Transfer module is used in 99% of situations)
PS.
Still working on the TTS fix - a couple more days by the look of it...
thanks for letting me know about the tts issue.....its quite important as my machines not done anything for a week now...
also ref the DTMF tones - is what your saying is i can record the !,3 to simulate someone pressing confirming they want the call.... if this is the case could you let me know how you can record these tones to a sound file as when i try using the record module it obvioulsy thinks im sending a real command....
Matt
