Config Of D/4pci For Hong Kong
I want to config the dialogic card (D/4PCI) for Hong Kong use, but I can't find the my country in country parameter of Dialogic Configuration Manager, How to config about it!
And I test the VG to receive the call need a long time (3-4 rings), I just want 2 rings.
And I use the phone to dial to VG, it doesn't answer the call and I hear "beep" sound like a fax receive voice.
Thanks!
Can you ask the distributor from whom you purchased the card for advice on what the selections in the DCM (Dialogic Configuration Manager) should be? The local people from whom you purchased the card should know this kind of 'local' knowledge...
Could you please post a copy of VoiceGuide's Debug Printout which captures an incoming call, this will allow us to see how the call arrives...
Also, can you attach a telephone handset 'in parallel' with the phone lines plugged into the Dialogic card and see how many times the telephone handset rings before the call is answered by VG? On some phone networks the caller will hear ringing before the destination extension has started ringing - attaching a phone 'in parallel' will let you better see how many rings the Dialogic card actually sees.
I thought you just said that the call is answered...(after 3-4 rings). If you hear beeps when you dial then you should ask your phone company why thay are playing these beeps..
Thanks for your reply!
My conditions
I use the VG just record data to database
No need to transfer call
I would like to ask about country parameter in (DCM), what for use? If I use default setting...(that mean I choose China or US)...what will be affect with this setting?
And my dailogic card (D/4PCI) is buy from internet...where can I get the information about country parameter setting?
Also I enclosed the VG Event Trace Log for after 3-4 rings to receive the call (I just want 2 rings) , and TSP config of D/4PCI (attached file: d41cfg.txt). Is the setting correct?
VG Event Trace Log
151107.77 5 linedevstate 2048 0 0
151107.78 5 callstate OFFERING 66133 0 4
151107.82 5 Lev_CallerID [31881076,]
151107.82 5 callinfo CALLEDID
151107.82 5 callinfo ORIGIN
151107.82 5 ring 0
151113.79 5 ring 2
151113.79 5 Answer the call at 1/30/2004 15:11:13
151113.80 5 lineAnswer(66133) => 66116
151114.34 5 callstate CONNECTED 66133,1,0
151114.35 5 WorkingModeTAPI@Connected=
151114.35 5 WorkingModeScript@Connected=
151114.38 5 Inband detection not enabled
151114.39 5 StartLoadedVgs at 1/30/2004 15:11:14
151114.40 5 tapi Reply (LineEvReply) ok 66116 0
151114.40 5 [Welcome] Playing
151114.40 5 [Welcome] Playing (C:\Program Files\SetupProject\VG\Voice\Welcome.wav)
151114.44 5 PlaySoundStart ok [C:\Program Files\SetupProject\VG\Voice\Welcome.wav]
151114.44 5 RunModule PLAY end
151118.28 5 wb(98511800)
151118.33 5 Play End line[5] (id=985118)
151118.34 5 LsPlayMsg EV_PLAY_FINISHED
151118.34 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
151118.34 5 [Lookup Site No] DB Query
151118.35 5 Jet mode used (To use ODBC mode specify ODBC Connect string)
151118.39 5 RVreplace start: [sELECT site_no FROM site_tel_line WHERE line_no=$RV_CIDNUMBER]
151118.39 5 RVreplace end: [sELECT site_no FROM site_tel_line WHERE line_no=31881076]
151118.39 5 About to execute Retrieve Operation [sELECT site_no FROM site_tel_line WHERE line_no=31881076]
151118.40 5 [Lookup Site No] row count=1
151118.41 5 [init Guard No Counter] Evaluate [0]
151118.43 5 .Eval(0)
151118.44 5 Eval Expr result:[0] stored in $RV[GuardNoCounter]
151118.44 5 path {0} not found
151118.45 5 [init Password Counter] Evaluate [0]
151118.46 5 .Eval(0)
151118.46 5 Eval Expr result:[0] stored in $RV[PasswordCounter]
151118.46 5 path {0} not found
151118.46 5 [Get Guard No] Number Input
151118.47 5 [Get Guard No] Playing (C:\Program Files\SetupProject\VG\Voice\GetGuardNo.wav)
151118.52 5 PlaySoundStart ok [C:\Program Files\SetupProject\VG\Voice\GetGuardNo.wav]
151122.77 5 Play End line[5] (id=989184)
151122.77 5 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
151127.79 5 dtmf 2 (66133,50,2)
151127.79 5 LsGetNbrsRxDigits 2
151127.79 5 [Get Guard No] Number Input 2
151127.80 5 path {2} not found
151128.41 5 dtmf 0 (66133,48,2)
151128.41 5 LsGetNbrsRxDigits 0
151128.42 5 [Get Guard No] Number Input 20
151128.42 5 path {20} not found
151128.93 5 dtmf 3 (66133,51,2)
151128.93 5 LsGetNbrsRxDigits 3
151128.93 5 [Get Guard No] Number Input 203
151128.93 5 path {203} not found
151129.29 5 dtmf 3 (66133,51,2)
151129.29 5 LsGetNbrsRxDigits 3
151129.29 5 [Get Guard No] Number Input 2033
151129.29 5 path {2033} not found
151130.41 5 dtmf # (66133,35,2)
151130.42 5 LsGetNbrsRxDigits #
151130.42 5 path {2033} not found
151130.42 5 [Lookup Password] DB Query
151130.42 5 Jet mode used (To use ODBC mode specify ODBC Connect string)
151130.43 5 RVreplace start: [sELECT pwd FROM guard_profile WHERE guard_no='$RV[Get Guard No]']
151130.43 5 RVreplace end: [sELECT pwd FROM guard_profile WHERE guard_no=2033]
151130.43 5 About to execute Retrieve Operation [sELECT pwd FROM guard_profile WHERE guard_no=2033]
151130.46 5 [Lookup Password] row count=1
151130.47 5 [Get Password] Number Input
151130.47 5 [Get Password] Playing (C:\Program Files\SetupProject\VG\Voice\GetPassword.wav)
151130.48 5 PlaySoundStart ok [C:\Program Files\SetupProject\VG\Voice\GetPassword.wav]
151134.52 5 Play End line[5] (id=1181)
151134.52 5 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
151136.44 5 dtmf 2 (66133,50,2)
151136.44 5 LsGetNbrsRxDigits 2
151136.44 5 [Get Password] Number Input 2
151136.45 5 path {2} not found
151136.81 5 dtmf 0 (66133,48,2)
151136.81 5 LsGetNbrsRxDigits 0
151136.81 5 [Get Password] Number Input 20
151136.82 5 path {20} not found
151137.01 5 dtmf 3 (66133,51,2)
151137.02 5 LsGetNbrsRxDigits 3
151137.02 5 [Get Password] Number Input 203
151137.02 5 path {203} not found
151137.29 5 dtmf 3 (66133,51,2)
151137.29 5 LsGetNbrsRxDigits 3
151137.29 5 [Get Password] Number Input 2033
151137.30 5 path {2033} not found
151137.67 5 dtmf # (66133,35,2)
151137.68 5 LsGetNbrsRxDigits #
151137.68 5 path {2033} not found
151137.68 5 [Evaluate Password] Evaluate [$RV[Get Password]=$RV[Lookup Password_1_1]]
151137.68 5 RVreplace start: [$RV[Get Password]=$RV[Lookup Password_1_1]]
151137.69 5 RVreplace end: [2033=2033]
151137.69 5 .Eval(2033=2033)
151137.69 5 Eval Expr result:[True]
151137.69 5 [Get Menu Choice] Number Input
151137.70 5 [Get Menu Choice] Playing (C:\Program Files\SetupProject\VG\Voice\GetMenuChoice.wav)
151137.72 5 PlaySoundStart ok [C:\Program Files\SetupProject\VG\Voice\GetMenuChoice.wav]
151152.56 5 wb(841100)
151152.61 5 Play End line[5] (id=8411)
151152.62 5 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
151155.09 5 dtmf 1 (66133,49,2)
151155.09 5 LsGetNbrsRxDigits 1
151155.10 5 [Get Menu Choice] Number Input 1
151155.10 5 [Lookup Still On Duty] DB Query
151155.10 5 Jet mode used (To use ODBC mode specify ODBC Connect string)
151155.11 5 RVreplace start (strlen>100)
151155.11 5 RVreplace end: [sELECT * FROM time_attendance WHERE site_no='HC' AND guard_no='2033' AND end_time IS NULL]
151155.12 5 About to execute Retrieve Operation [sELECT * FROM time_attendance WHERE site_no='HC' AND guard_no='2033' AND end_time IS NULL]
151155.14 5 [Lookup Still On Duty] movelast err : µL²{¥Îªº°O¿ý¡C
151155.14 5 [invalid Report Attendant] Playing
151155.16 5 [invalid Report Attendant] Playing (C:\Program Files\SetupProject\VG\Voice\InvalidReportAttendant.wav)
151155.20 5 PlaySoundStart ok [C:\Program Files\SetupProject\VG\Voice\InvalidReportAttendant.wav]
151155.21 5 RunModule PLAY end
151203.42 5 Play End line[5] (id=25866)
151203.42 5 LsPlayMsg EV_PLAY_FINISHED
151203.42 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
151203.43 5 [Thank You] Playing
151203.43 5 [Thank You] Playing (C:\Program Files\SetupProject\VG\Voice\ThankYou.wav)
151203.45 5 PlaySoundStart ok [C:\Program Files\SetupProject\VG\Voice\ThankYou.wav]
151203.45 5 RunModule PLAY end
151207.38 5 Play End line[5] (id=34138)
151207.38 5 LsPlayMsg EV_PLAY_FINISHED
151207.38 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
151207.38 5 Hanging up call... [Hangup Module]
151207.38 5 RecSoundStop ok
151207.39 5 PlaySoundStop ok
151207.39 5 fnHangupCall end
151207.43 5 linedevstate 2048 0 0
151207.43 5 callstate IDLE 66133 0 0
151207.45 5 WorkingMode@Idle=
151207.47 5 tapi Reply (LineEvReply) ok 66099 0
151208.39 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
151208.39 5 ReinitTelephony due to IDLE start
151208.39 5 tapic lineDeallocateCall(MainCall:66133) 0
151208.55 5 lineOpen(5) => 0
151208.55 5 Waiting for a call...
151208.55 5 lineOpen(5)LineHandle=66082
One more questions....
I try to dail to VG, if I hangup the phone when the the VG still playing script, after I wait the VG go back ready status(Waiting for a call...), and then I dail to VG again, It just hear like connect to fax modem sound, and my phone will hangup by the system...(VG did not answer THIS call )
So sorry ask many questions, because I am a beginner of the field.
d41cfg.txt
Can you attach a telephone handset 'in parallel' with the phone lines plugged into the Dialogic card and see how many times the telephone handset rings before the call is answered by VG?
Also please read:
http://voiceguide.com/forums/index.php?showtopic=1104
Not sure what the DCM Country & Parameter Files should be for HK. You should seek support on such localization-related questions from your local Dialogic distributor/reseller in HK... (obtaining access to such support is a major factor why people buy cards from local authorized distributors).
Have you tried setting VG to answer after 1 ring?
