Transfer Call
Basically, we have only one problem. Transfer call. Everything else works outstanding.
When a transfer sequence is executed, we can hear (headset of the phone) DTMF, but not the Dial Tone before them. After Transfer, all we can hear (after DMTF) is silence and after timeout period, modem hangs up.
Note: We don’t have PBX – we are using phone line.
Modem that we have is Hayes V.90 PCI VoiceFaxModem and here is an event trace log:
102531.78 0 callstate OFFERING 66240 0 4
102531.78 0 ring 1
102537.75 0 ring 2
102537.75 0 Answer the call at 1/22/2004 10:25:37 AM
102537.75 0 lineAnswer(66240) => 66342
102537.75 0 callstate ACCEPTED 66240 0 0
102537.92 0 tapi Reply 66342 0
102537.92 0 callstate CONNECTED 66240,0,0
102537.92 0 WorkingModeTAPI=
102537.92 0 WorkingModeScript=
102537.92 0 Inband detection not enabled
102537.92 0 StartLoadedVgs at 1/22/2004 10:25:37 AM
102537.92 0 [Welcome to ISG] Playing
102537.92 0 [Welcome to ISG] Playing (C:\Documents and Settings\Administrator\My Documents\My music\Mike welcome3-16m.wav)
102538.17 0 PlaySoundStart ok [C:\Documents and Settings\Administrator\My Documents\My music\Mike welcome3-16m.wav]
102538.17 0 RunModule PLAY end
102542.89 0 dtmf 0 (48,2)
102542.89 0 LsPlayMsg 0
102543.50 0 PlaySoundStop ok
102543.94 0 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
102543.94 0 [Transfer Call to Matt] Blind Conference to ,6027908034 (Generate)
102543.94 0 tapic lineGenerateDigits(66240,!,100) => 0
102544.31 0 generate LINEGENERATETERM_DONE
102545.41 0 LsXferStart EV_TAPI_GENERATE
102546.50 0 LsXferPlayVts EV_HOOKFLASHFINISHED
102546.50 0 tapic lineGenerateDigits(66240,,6027908034,100) => 0
102550.22 0 generate LINEGENERATETERM_DONE
102551.31 0 LsXferPlayVts EV_TAPI_GENERATE
102551.31 0 tapic lineGenerateDigits(66240,!3,100) => 0
102552.03 0 generate LINEGENERATETERM_DONE
102553.13 0 LsXferPlayAnn EV_TAPI_GENERATE
102553.13 0 PlayFinishCause=
102553.13 0 Success path not defined - wait till call ends (iXferType=2)
102620.59 0 callstate DISCONNECTED 66240,1,0
102620.59 0 LsXferWaitEndCall EV_REMOTEPARTY_DISCONNECT
102620.59 0 Hanging up call...
Thank you in advance,
Pete
Do the phone lines that you are using have the call transfer feature enabled on them by the phone company?
Can you transfer calls on these lines manually? If yes then how do you do the manual call transfer? do you press hookflash then the number then hookflash then 3? Do you need to wait till 2nd call is connected before you press 'hookflash 3' ?
It sounds like even the first hookflash is not recognized by the PBX (it sounds like it is too short), and as it's not possible to set hookflash length on most of the modems then your only solution is to get a Dialogic card...
Modems inability to regulate hookflash length is the main reason why we recommend a Dialogic card to be used whenever call transfers are required.
