Message Indicator
Is there a means to set the Message lights on an extension when new voicemail is waiting? I have a Panasonic DBS-824.
If there are others with similar Panasonic DBS, any suggested settings to work with that and the Dialogic 4/PCI would be most appreciated.
So for, my quest for a decent voicemail/auto-attendant that has some external interfacability has stopped here. Good bang for reasonable $.
Lance
If you can supply us with information on how this PBX can accept a command to turn on/off a particular extension’s Message light then I can provide you with instructions on how to make VG turn on the lamp.
Turning on the lamp for a particular extension usually just requires dialing a particular code followed by the extension number - the way the codes are dialed differs from one PBX to another - but if you can let us know the codes (or better yet provide us with the complete manual for this PBX) then we can easily have VG set up to turn the lights on/off.
It looks like it is
Message Light On *4,E
Message Light Off *5,E
