Problem: Tone Is Received By The Wrong Port Line
Hello,
I use this Dialogic Card - D4PCIUFEQEU.
which is connected to 2 phone lines.
I have an IVR system which only receives calls.
A tone is send to the IVR system through PhoneLine1
But is it also received by PhoneLine2.
I have attached this zip file, which include also the vgs file + The Scenario's description
Thank you
Meir
wrong_Port_Line.zip
Trace shows that Dialogic card reports hearing a DTMF tone on port 2 about 180-190ms after reporting hearing it on port 1.
If you are making test calls from two phones close to each other then maybe the sound of DTMF tone pressed on first phone can be heard by phone connected to the second line?
120133.968  1244   1 ev    TDX_CST (CST Event Received)
120133.968  1244   1       TDX_CST DE_DIGITS data=49 [1], KeysUsed=0
120133.968  1244   1 r     dtmf 1
120134.156  1244   3       CtEventProcess idx=20 : evttype=134(134), crn=0, data=090B8620(08B918E0), len=4(4) q: 0/1
120134.156  1244   3 ev    TDX_CST (CST Event Received)
120134.156  1244   3       TDX_CST DE_DIGITS data=49 [1], KeysUsed=0
120134.156  1244   3 r     dtmf 1
120134.687  1244   1       CtEventProcess idx=21 : evttype=134(134), crn=0, data=090B8650(08B918E0), len=4(4) q: 0/1
120134.687  1244   1 ev    TDX_CST (CST Event Received)
120134.687  1244   1       TDX_CST DE_DIGITS data=52 [4], KeysUsed=0
120134.687  1244   1 r     dtmf 4
120134.859  1244   3       CtEventProcess idx=22 : evttype=134(134), crn=0, data=090B8680(08B918E0), len=4(4) q: 0/1
120134.859  1244   3 ev    TDX_CST (CST Event Received)
120134.859  1244   3       TDX_CST DE_DIGITS data=52 [4], KeysUsed=0
120134.859  1244   3 r     dtmf 4
120135.343  1244   1       CtEventProcess idx=23 : evttype=134(134), crn=0, data=090B86B0(08B918E0), len=4(4) q: 0/1
120135.343  1244   1 ev    TDX_CST (CST Event Received)
120135.343  1244   1       TDX_CST DE_DIGITS data=55 [7], KeysUsed=0
120135.343  1244   1 r     dtmf 7
120135.531  1244   3       CtEventProcess idx=24 : evttype=134(134), crn=0, data=090B86E0(08B918E0), len=4(4) q: 0/1
120135.531  1244   3 ev    TDX_CST (CST Event Received)
120135.531  1244   3       TDX_CST DE_DIGITS data=55 [7], KeysUsed=0
120135.531  1244   3 r     dtmf 7
Yes , probably That was the reason,
I tested again, with two phones far apart, and it was fine.
Thank you!
Meir
