Vg Dialer And A Long List Error 13
I have just purchased VoiceGuide+Dialer. I need to make calls to over 2000 numbers. The dialer has worked great in my testing for a smaller set of numbers, but when I try to load up the list with the 2000 numbers, it tells me as follows:
Run Time Error 13
Type Mismatch
However, I checked the file and there isn't any mismatch.
Can someone tell me why I might be seeing this error?
Thanks,
Santosh Krishnan
Please .ZIP the file you are trying to load and either post it here or email it to support@katalinatech.com
How are you loading the list? Using the "Telephone Number Loader" or some other way?
Are you using v5.1.7 of VoiceGuide or some other version?
Does it work when you try to load a smaller amount of numbers? (eg. few hundred or so...)
We load much longer lists (tens of thousands is not uncommon) so it may be something in the list that you are using that is causing the problem here...
