Selecting Ports To Be Used For Dialing Out
How to determine ports to use for dialout action?
I have to use only ports form 16-30 to dialout.
Easiest way to specify which ports are to be used by system to dial out is using the Config.xml file.
In Config.xml:
for channels that are never to make any outgoing calls set each channel’s “AllowDialOut” entry to 0,
for channels ton which outgoing calls are allowed set each channel’s “AllowDialOut” entry to 1,
then restart the VoiceGuide service,
Outbound calls will only be made on channels that have the “AllowDialOut” entry set to 1.
