Add Auto Answer and Auto Switch
i have a siemens sentral type hicom 130
i want add auto answer and auto switch
how can do that for this problem
please sent me all information about that
thank
Have you downloaded the VoiceGuide software and installed the Dialogic card in your PC? These would be the first two steps - thereafter I'd recommend you read the section in VG Help file on Inband Signalling and look at the Voicemail system's Auto-Attendant feature...
BTW. the Inband Signaling configuration example in VoiceGuide's Help file is for a Siemens PBX... It should not require much work to modify this for the Hicom...
