Transfer To Random Extension
I would like set up a script to randomly select anumber form list and then pass the selected number to the transfer call moduleto perform the transfer.
Please show me the script syntax as I believe it requires reading from a file (open text file) and to Randomize the result and pass the $RV result to the transfer module
So far I have come this far with the script - need assistance to complete the transfer section
CONST FOR_READING = 1
Set ofso = CreateObject("Scripting.FileSystemObject")
Set ofile = ofso.OpenTextFile("C:Program Files\Voiceguide\Scripts\Project\extensions.txt",FOR_READING)
arrFile = Split(ofile.readall,vbCrLf)
Randomize
i = Int((Rnd * UBound(arrFile)))
arrLine = Split(arrFile(i),",")
For i=0 To UBound(arrLine)
WScript.Echo arrLine(i)
vg.Script_Goto iLineId, "", "TransferToExt", sRv
set fso = Nothing
set vg = Nothing
Next
Probably the most straightforward approach here would be to use a "Run VBScript" type module and make it run a VBScript that opens the input file (or to simplify just set the phone numbers in the VBScript) and loads them into an array. Then a random selection of the array index is made and the contents of that array entry are saved as $RV which is then used in Transfer Call module.
Why was this included:
The below should probably be enough:
Randomize
sRv = "[xferdest]{" & arrFile(i) & "}"
set ofile = Nothing
set ofso = Nothing
set vg = Nothing
then use $RV[xferdest] in the module "TransferToExt"
Thank you
Here is the final script that works for other like me who need a little help on the coding...
Set ofile = ofso.OpenTextFile("C:\Program Files\Voiceguide\Scripts\Project\extensions.txt",FOR_READING)
Randomize
sRv = "[TransfertoExt]{" & arrFile(i) & "}"
'sRv = arrFile(i)
vg.Script_Goto $RV_LINEID, "", "TransferToExt", sRv
'vg.Script_Goto $RV_LINEID, "", "C:\Program Files\VoiceGuide\Scripts\Project\Project.vgs\TransferToExt", sRv
set ofile = Nothing
set ofso = Nothing
set vg = Nothing
