Declaring Number Of Inbound Used Channels
Is possible to set up numbers of inbound available channels in e1 trunk?
I have 2 x E1 Dialogic card and want to set first 40 channels only as inbound and no one more to be sure that next 20 channels are reserved for outbound calls.
Now happen that we have more incoming calls as we can dialout.
You need to set this up with Telco/PBX that is providing the lines.
It's the Telco/PBX that decides on which channels to send in the new calls.
Usually In/Out is set on a per trunk basis, not fractionally.
You would need to speak with Telco to see what configuration options they have available.
