Msi 160 Help
I need some help with my MSI 160 Card. Everything seems to install right on startup and all firmware is loaded, but no audio is played out to the stations after startup.
My dealer says I need a new card. Is there any circuit diagram out there I can use to test it out. Thanks.
If when using the sample programs that come with Dialogic's drivers you do not hear the software play any sound files when the handset has been picked up then it does look like the card is faulty...
