Problems With Audio Files
Hello,
We are having a few problems with voiceguide.
Everything works fine for a while however after a few calls, or multiple calls, all of a sudden voiceguide will hangup straight away and not do anything. Analysis of the logs shows that the problem is with the Audio samples we are playing. The weird thing is if we restart the program it works fine for a while.
Heres the logs, any idea?
154117.67 16 linedevstate 2048 0 0
154117.69 16 callstate OFFERING 66191 0 4
154117.69 16 Lev_CallerID [,OVERSEAS]
154117.69 16 callinfo CALLEDID
154117.69 16 callinfo ORIGIN
154117.69 16 ring 0
154123.69 16 ring 2
154123.69 16 Answer the call at 8/01/2004 3:41:23 PM
154123.69 16 lineAnswer(66191) => 66255
154124.22 16 callstate CONNECTED 66191,1,0
154124.22 16 WorkingModeTAPI@Connected=
154124.22 16 WorkingModeScript@Connected=
154124.22 16 Inband detection not enabled
154124.23 16 StartLoadedVgs at 8/01/2004 3:41:24 PM
154124.23 16 tapi Reply (LineEvReply) ok 66255 0
154124.23 16 [detect_CID] Evaluate [$RV_CIDNUMBER]
154124.23 16 RVreplace start: [$RV_CIDNUMBER]
154124.23 16 RVreplace end: []
154124.23 16 .Eval()
154124.23 16 Eval Expr result:[] stored in $RV[CID_DETECTED]
154124.23 16 [play_no_CID] Playing
154124.23 16 [play_no_CID] Playing (C:\ivr\sound_files\no_CID.wav)
154124.25 16 PlaySoundStart err=[0 play PlaySoundStart
ResetWavOutAndContinuePlay=>4] file[C:\ivr\sound_files\no_CID.wav]
154124.25 16 PlaySoundStart line[16] err=[0 tr 5 waveOutOpen(id=11)
MMSYSERR_ALLOCATED but hWaveOut = NULL] [C:\Program
Files\VoiceGuide\system\voice\ErrorPlayingFile.wav]
154124.25 16 For Dialogic use: PCM 11Khz 8bit Mono
154124.25 16 Hanging up call... [srlib PlaySoundStart]
154124.27 16 RecSoundStop ok
154124.27 16 PlaySoundStop ok
154124.27 16 fnHangupCall end
154124.27 16 RunModule PLAY end
154124.28 16 tapie PlayEnd old line=16 0 328078
154126.25 16 linedevstate 2048 0 0
154126.25 16 callstate IDLE 66191 0 0
154126.25 16 WorkingMode@Idle=
154126.27 16 After Hangup
script:[C:\ivr\ivr_scripts\commercial\SHAZAM_hangup_com_early.vgs]
154126.27 0 LoadedVgs_Find
C:\ivr\ivr_scripts\commercial\SHAZAM_hangup_com_early.vgs at idx=4
154126.27 16 tapi Reply (LineEvReply) ok 66256 0
154126.27 16 [submit_request] Running vb script:[C:\ivr\ivr_scripts\commercial\SHAZAM_hangup_com_early.vgs]
154211.28 0 LoadedVgs_Find
154211.28 16 tapi Reply (LineEvReply) ok 65612 0
154211.28 16 [submit_request] Running VB Script...
154211.28 16 RVreplace start (strlen>100)
154211.30 16 VBScript Run continuing...
154211.31 16 Hanging up call... [Hangup Module]
154211.31 16 HangupCall_Common Mode=AfterHangupRun
154211.31 16 ReinitTelephony due to IDLE start
154211.33 16 tapic lineDeallocateCall(MainCall:65987) 0
154211.36 16 lineOpen(16) => 0
154211.36 16 Waiting for a call...
154211.36 16 lineOpen(16)LineHandle=66221
Please place the attached file in "C:\" and restart VoiceGuide.
Log files called "TapiwrapLogMMDD.txt will be created in "C:\"
When problem occurs please .ZIP up the log file for the day when the problem occurred and post it here or email it to us. We will then be able to see what events have led up to this issue...
TapiWrapLogSelect.txt
