Subscripts
hi!
how can i pass parameters when i call subcript. actually i need send a number when i call subsript. Is there any way to do that..... Please Help
Thanks in advance.....
Pradeep Sabharwal
The subscript can read all the Result Variables which have been set so far during the current call on the line, so all that you need to do is to define a Result Variable using a "Evaluate Expression" module before calling the subscript...
Alternatively you may use the Script_Gosub command from within a VBScript module to call the subscript - you can specify new RV's as part of that command call...
