Vbscript Syntax
I would lke to use the VBS module to check if prompt1.wav exists.
If YES then I want to go back to the vg.vgs module for further processing
If NO then I want to go back to the vg.vgs module for further processing
Could someone please check/correct the code snippet to achieve the desired result.
__________________________________________________________________________
Set objFSO = CreateObject("Scripting.FileSystemObject")
If objFSO.FileExists("C:\Program Files\VoiceGuide\Scripts\Prompts\prompt$RV[Get Numbers].wav") Then
vg.Script_Goto "C:\Program Files\VoiceGuide\Scripts\Prompts\Prompt Menu.vgs", "Play Prompt"
Else
vg.Script_Goto "C:\Program Files\VoiceGuide\Scripts\Prompts\Prompt Menu.vgs", "EvaluateDigitsFail"
End If
For VoiceGuide v7 use:
set objFSO = CreateObject("Scripting.FileSystemObject")
 vg.Script_Goto "C:\Program Files\VoiceGuide\Scripts\Prompts\Prompt Menu.vgs", "Play Prompt", ""
Else
 vg.Script_Goto "C:\Program Files\VoiceGuide\Scripts\Prompts\Prompt Menu.vgs", "EvaluateDigitsFail", ""
End If
set vg = Nothing
set objFSO = Nothing
See: http://www.voiceguide.com/vghelp/source/html/com_script_goto.htm
It looks like the module [Run VB Script Digits] is not set to wait for the VBScript to return.
If you want to let the ran VBScript to return data to VoiceGuide and have VoiceGuide act on that data then you need to select the "Wait until script completes" option.
Please see http://www.voiceguide.com/vghelp/source/html/modvbs.htm - setion "Wait until script completes option"
If you still encounter issues please post the script used along with the traces.
Looking at the VBScript again, it appears to have some issues as well. $RV_LINEID is missing.
Please see: http://www.voiceguide.com/vghelp/source/html/com_script_goto.htm
The script should be:
 vg.Script_Goto $RV_LINEID, "C:\Program Files\VoiceGuide\Scripts\Prompts\Prompt Menu.vgs", "Play Prompt", ""
Else
 vg.Script_Goto $RV_LINEID, "C:\Program Files\VoiceGuide\Scripts\Prompts\Prompt Menu.vgs", "EvaluateDigitsFail", ""
End If
set vg = Nothing
All the code ran from "Run VBScript" type modulas is saved as .vbs files in VoiceGuide's \temp\ subdirectory.
You can test how that VBScript runs by just double clicking on relevant file. Any errors tht VBScript would have will then show is a displayed dialog box.
