Activex Problem
I've just installed the trial version of VoiceGuide (originally 5.1.3a) on Windows XP Pro. When I try to call "CreateObject("VoiceGuide.CommandLink")" (from asp) I get the error "ActiveX component can't create object: 'VoiceGuide.CommandLink'".
The voiceguide application itself works fine, it's just the activeX component.
I notice that VgMulti.exe is started under the IUSR_XXXX login, and does not drop off (causing the normal application not to work) until you end the process.
I don't think it's a permissions problem as I made IUSR_XXXX an administrator to test the fact.
I reinstalled VoiceGuide (this time 5.1.7) and have exactly the same error.
I tried installing it on to a Win2k Server machine but have the same problem. On the Win2k install, some of the dlls did not register themselves. I tried regsvr32 manually also.
Is this all because I'm using the trial version?
Cheers
Dave
Can you access the VoiceGuide.CommandLink object from normal VBScripts ?
Try running a simple VBScript while VG is running, eg:
vg.Admin_TraceLogAdd 0, 0, "This trace was printed from an external VB Script"
set vg = Nothing
(Click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before running VBScript.)
112150.38 0 This trace was printed from an external VB Script
112203.08 0 sys cleanup Start
112203.08 0 sys cleanup End
Runs fine.
Asp problem your think? Has anyone ran it under asp before?
Dave
Looks like you can create and access the VoiceGuide.CommandLink object from normal VBScripts ran on the system with no problems... so I'm not too sure why you cannot do the same from other processes ran on this system...
Is the ASP code executed on the same system on which VG is installed? If yes then it looks like it's some sort of permissions problem with the ASP process not being able to create the VoiceGuide.CommandLink object...
I don't know too much about ASP so I'm not too sure what you should be looking at next...
Thanks for the responses.
If asp is not well supported, I guess I'll give it a miss.
So I'm building an app in VB now, and I get this error when trying to make an outbound call (I get the same error when I use the outdial queue mdb).
I read some information on MSDN about lineMakeCall but I'm not sure how your software calls the function and hence can't figure out what I'm doing wrong.
http://msdn.microsoft.com/library/default....inemakecall.asp
155529.65 0 cl Dialer_MakeCall 0413777758, , 1
155529.65 0 Search for free lines in range [7-7]
155529.65 7 Calling 0413777758
155529.66 7 MakeCallEx => 65849
155529.66 7 TapiCbTrigSet 65849 7003
155529.66 7 tapi Reply (LineEvReply) err 65849 LINEERR_INVALCALLPARAMS [80000019]
155529.66 7 TcTrig.lTrigType = TcTrig_MakeCallForConferenceFinished
155529.66 7 Hanging up call... [MakeCall returned -2147483623]
155529.66 7 RecSoundStop ok
155529.68 7 PlaySoundStop ok
155529.68 7 HangupCall : lCallHandle& = 0 - lets close and open line
155529.68 7 ReinitTelephony due to IDLE start
155529.70 7 lineOpen(7) => 0
155529.70 7 Waiting for a call...
155529.70 7 lineOpen(7)LineHandle=65764
155529.71 7 fnHangupCall end
155529.71 1 Hanging up call... [MakeCall returned -2147483623]
155529.71 1 RecSoundStop ok
155529.71 1 PlaySoundStop ok
155529.71 1 HangupCall : lCallHandle& = 0 - lets close and open line
155529.71 1 ReinitTelephony due to IDLE start
155529.71 1 ERROR 5.1.7001 Loading Vgs err=-1, file=[], device=0
155529.71 1 Waiting for a call...
155529.71 1 fnHangupCall end
155529.71 7 MakeCall => LINEERR_INVALCALLPARAMS [80000019]
155529.73 7 TapiCbTrigClear
Any help would be much appreciated.
Cheers
Dave
FYI, I'm using a US Robotics Message modem plus (voice modem).
Here's the error from the autodialer.
161633.45 0 ERROR 5.1.7001 DialListDbFindDueCall [invalid use of Null]
161633.45 0 dial callque update id=20 next call time 0401091618
161633.45 0 dial callque DB update returned
161633.45 7 dial found entry: tel[0413777758] ann[C:\Program Files\VoiceGuide\Scripts\Credit Card Payment\PayThankyou.wav] vgs[C:\Program Files\VoiceGuide\Scripts\Booking Angel\Credit Card Payment.vgs] am[C:\Program Files\VoiceGuide\Scripts\Booking Angel\Credit Card Payment.vgs]
161633.46 7 Calling MakeCallEx(0413777758)
161633.46 7 Dialing: 0413777758
161633.46 7 MakeCall => 66105
161633.46 7 TapiCbTrigSet 66105 7002
161633.46 7 tapi Reply (LineEvReply) err 66105 LINEERR_INVALCALLPARAMS [80000019]
161633.46 0 dial callque update id=20 next call time 0401091618
161633.46 0 dial callque DB update returned
161633.46 7 Hanging up call...
161633.48 7 RecSoundStop ok
161633.48 7 PlaySoundStop ok
161633.48 7 HangupCall : lCallHandle& = 0 - lets close and open line
161633.48 7 ReinitTelephony due to IDLE start
161633.49 7 lineOpen(7) => 0
161633.49 7 Waiting for a call...
161633.49 7 lineOpen(7)LineHandle=66277
161633.49 7 fnHangupCall end
161633.51 7 TapiCbTrigClear
It looks like the v5.1.7 is trying to access the older style OutDial.mdb database - this will cause problems similar to what you are seeing..
Please stop VG, then delete both .MBD files from VoiceGuide's \data\ subdirectory and then try outdialing again.
There is a bug with the uninstall procedure which results in all files not getting deleted - this then causes old files (in VoiceGuide's \data\ subdirectory in particular) to be retained and the newer version of VG then ends up using the old versions of these files...
Right now when upgrading to a newer version of VG it's a good idea to either install the new version in a new directory or first delete the VG directory tree before installing the new version...
Initially removing the DB did not solve the problem, but after deleting the old install and reinstalling, everything works fine.
Thanks again for your help
Dave
What was the final out come on .asp? I am having problems also using asp program to interact with VG?
Thank You
Can you post a snippet of the code which is causing a problem and describe how your system is set up in enough detail so that we can reproduce the problem...
