Voiceguide Beeps
When I answer a call (before VoiceGuide picks up) I here a beep. It is not recording the calls (I don't want it to) I just need to know what is causing this beep. It was not doing this yesterday and I have made no changes to my script or settings.
If VG has not answered the call then it could not be playing anything on the line - the phone line needs to be picked up by VG first before VG will be able to play/record anything to/from line.
It is answering the call (set to 7 rings). If I unplug the modem there is no beep. But if I plug itback in it beeps whenever I answer a call.
I understand that you answer the call before VG answers the call - correct?
Could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is happening.
Here is my debug log. This event trace log has been running for a fiew days now, but the modem has been unpluged most of the time. Also the problem has become speratic now and does not happen all the time.
voiceguidelog.txt
