Ring Count
Is there a settings file that can be edited to change the number of rhings before answering?
When running VoiceGuide go to View menu and select "Device Config" - you will then see the option to change the 'answer after ring count' setting.
I know how to do it that way, I've created a web site that allows all users to get ther messages via the web, and was wondering if there was a file that could be edited directly to change the ring count so I can and that ability to the web page.
Thank you
The Ring Count can also be set in a VG.INI file - but these setting are only read in when VoiceGuide is started...
So at this stage it is not possible to dynamically set Ring Count via external config files or commands...
