<Break> Tag Does Not Work For Tts Speech
Hello Support team,
I have a script that uses "Capture Entered Number" module that has a path to a text file for TTS reading.
The problem is that <break> tag does not work: I tried <rate> tag and this tag is working properly.
I am using VG7 on Windows7 with ATT Natural Voice, Audreay.
I tried to use xml tag (as you suggested somewhere in this forum for VG6 user), but no use...
a Comma works as "break", but I would like to have longer period of pause than a comma.
What am I doing wrong?
Thanks for your help.
The script below is the contennt of the text file TTS is reading.
<?xml version="1.0" encoding="ISO-8859-1"?>
<speak version="1.0" xml:lang="en-US"
xmlns="http://www.w3.org/2001/10/synthesis">
<rate absspeed="-1">
The list of choice is , 0001 <break time = "3000ms" /> 0002 , 0003 , 0004
</rate>
</speak>
VoiceGuide passes the specified TTS expression to the TTS engine which you have installed on the system.
The TTS expression is passed on without modification.
For AT&T TTS engines this tag should work:
<Break time=”3s”/>
If that does not work then the next step would be to contact the TTS engine supplier.
Woops, I was wrong: it turned out that this machine uses microsoft speech engin, only applying "Audrey" voice from AT&T natural voice.
So the "break" tag for the engine had to be "Silence" like the example below,
<silence msec="3000"/>
Thanks for your clarification.
