"send Pager Massage" Module
I'm currently using Dialogics board and 4.x version of VoiceGuide. I'm trying to set up the "Send Pager Massage" module, but somehow it only dial the pager number, and it didn't seem to dial the message. Does anyone know how to solve this problem? =O
I'm assuming that since I can do call forwarding, that means my VG Dialer option is good to go, because it can do outbound dialing, so I'm not exactly sure what cost this problem, can someone explain to me how will the system "dial" the digits specified in the Message text box under the "Send Pager Message" module?? =)
An other question is in the User's Guide, under "Sound files" it stated that there's a directory \system\voicedlgc\ which are recorded in the PCM 11025Hz, 8bit, Mono format and those are the pre-recorded system files I need to use with my Dialogics card, but the problem is I can not find that directory, it only have \system\voice\ directory, which are no use to me. Did anyone run into this problem too?? and how can I get those files? or that directory?? Because I don't really want to convert all the voice files from \system\voice\ directory, and I can not use any default sound right now, (i.e. the beep before recording a message or any time when I want to let a user check what number they inputed.)
Any help will be great!!
Thanks!! :D
Where did you get v4 of VG from?
Sounds like you are just setting up your system - just download the current version form our WWW and use that version instead... current version does not require you to manually replace files etc for use with Dialogic, it's all included...
Call forwarding does not use VG Dialer... are you using an evaluation version or a registered version of VG? What is the license type? Let us know in who's name/company is the license and I can also find what license type you have...
opps... I mean "Transfer Call" not call forward... ^^;;
and we brought the V4.8.45 Enterprise, VG Dialer, 4 line license awhile ago,
I'm doing upgrade to our system and the script. =)
Can I still just download your current version and use it with my current code?
As I don't really want to post my system ID and code on a public forum.
Please let me know. Thanks. =D
To use the current version you will need to purchase an upgrade (plz see the WWW order form).
If VG Dialer is enabled then you should be able to use the Send Pager Message module.
To obtain replacement sound files please see the links provided on: http://voiceguide.com/vgDownload.htm
yes that's the problem, my VG Dialer is enabled, and when I test the Send Pager Message module with a phone number it actual dial, but it doesn't seem to dial the digits that I specified in the Message text box. So I want to know how does the system dial the digits in the Message text box in order to help me solve this problem.
Thanks. :)
Could you please post a copy of VoiceGuide's Debug Printout which captures the problem, this will allow us to see what is going wrong.
I did as you told, and here's the log information that came up,
74218 5 tapie linedevstate 2048 0 0
74234 5 tapie ring 0
64531 6 tapie linedevstate 2048 0 0
64796 5 tapie linedevstate 2048 0 0
65859 5 tapie linedevstate 1024 0 0
65890 5 tapie linedevstate 512 0 0
77203 6 tapie linedevstate 2048 0 0
78250 6 tapie linedevstate 1024 0 0
78281 6 tapie linedevstate 512 0 0
Hope this'll help.
Thanks. :)
This trace does not capture a complete incoming call... or a call was not answered...
After a lot of testing I kind of make the Pager Module work. Now my problem is
1) It only worked every other time, like the 1st time I called, it dial the message, the 2nd time I called, it didn't dial the message, the 3rd time I called, it dial the message, the 4th time I called, it didn't dial the message... etc. etc... And I have no clue what causes this.
2) It took the module 30sec to start dialing the message, is there anyway to make it dial the message any sooner? I didn't add in any single commas at the beginning of the message.
Thanks. :)
Which version of VG are you using?
I'm using V4.8.45 Enterprise.
Here's a log file that dial the message.
92296 5 tapie linedevstate 2048 0 0
92312 5 tapie callstate OFFERING 65670 0 4
92328 5 tapie callinfo CALLEDID
92343 5 tapie callinfo ORIGIN
92359 5 tapie ring 0
92359 5 Answer the call
92375 5 lineAnswer(65670) => 66151
92921 5 tapie callstate CONNECTED 65670,1,0
92937 5 WorkingModeTAPI=
92953 5 WorkingModeScript=
92984 5 tapi Reply 66151 0
93000 5 tapie callinfo MONITORMODES
93015 5 TimeoutClear
93031 5 [Greeting] Playing
93046 5 [Greeting] Playing (Natual Voice\greeting.wav)
93093 5 PlaySoundStart ok [D:\Voice\Natual Voice\greeting.wav]
93109 5 TimeoutClear
93125 5 RunModule PLAY end
93140 5 wa(7180,79306200)
93156 5 tapie callinfo MONITORMODES
93171 5 tapie callinfo MONITORMODES
94062 5 tapie monitordigits 53 2
94078 5 LsPlayMsg [5]
94140 5 PlaySoundStop ok
94156 5 TimeoutClear
94171 5 [Get PhoneNu] Number Input
94187 5 [Get PhoneNu] Playing (Natual Voice\PhoneNu.wav)
94218 5 PlaySoundStart ok [D:\Voice\Natual Voice\PhoneNu.wav]
94234 5 TimeoutClear
94234 5 wa(7190,79420300)
94250 5 tapie callinfo MONITORMODES
94265 5 tapie callinfo MONITORMODES
96296 5 tapie monitordigits 52 2
96312 5 LsGetNbrsPlayWelcMsg [4]
96375 5 PlaySoundStop ok
96390 5 [Get PhoneNu] Number Input 4
96406 5 TimeoutSet 5 EV_TIMEOUT_GOTOMODULE
96515 5 tapie monitordigits 53 2
96531 5 LsGetNbrsRxDigits [5]
96546 5 [Get PhoneNu] Number Input 45
96562 5 TimeoutSet 5 EV_TIMEOUT_GOTOMODULE
96843 5 tapie monitordigits 54 2
96859 5 LsGetNbrsRxDigits [6]
96875 5 [Get PhoneNu] Number Input 456
96906 5 TimeoutSet 5 EV_TIMEOUT_GOTOMODULE
97265 5 tapie monitordigits 54 2
97281 5 LsGetNbrsRxDigits [6]
97296 5 [Get PhoneNu] Number Input 4566
97312 5 TimeoutSet 5 EV_TIMEOUT_GOTOMODULE
97484 5 tapie monitordigits 54 2
97500 5 LsGetNbrsRxDigits [6]
97515 5 [Get PhoneNu] Number Input 45666
97531 5 TimeoutSet 5 EV_TIMEOUT_GOTOMODULE
97734 5 tapie monitordigits 53 2
97750 5 LsGetNbrsRxDigits [5]
97765 5 [Get PhoneNu] Number Input 456665
97765 5 TimeoutSet 5 EV_TIMEOUT_GOTOMODULE
98000 5 tapie monitordigits 55 2
98015 5 LsGetNbrsRxDigits [7]
98015 5 [Get PhoneNu] Number Input 4566657
98031 5 TimeoutSet 5 EV_TIMEOUT_GOTOMODULE
98421 5 tapie monitordigits 35 2
98437 5 LsGetNbrsRxDigits [#]
98453 5 TimeoutClear
98468 5 fn PlaySoundStartNumbers C:\Program Files\ivg\system\voicedlgc\GetNbrsConfirmIntro.wav, C:\Program Files\ivg\system\voicedlgc\GetNbrsConfirmMenu.wav, 4566657, Digits
98484 5 twcal PlaySayNumber C:\Program Files\ivg\system\voicedlgc\GetNbrsConfirmIntro.wav, C:\Program Files\ivg\system\voicedlgc\GetNbrsConfirmMenu.wav, 4566657, , 1
98546 5 PlaySoundStartNumbers ok
98562 5 TimeoutClear
98578 5 wa(13862,79850008)
98593 5 tapie callinfo MONITORMODES
00500 5 tapie monitordigits 49 2
00515 5 LsGetNbrsPlayConfirm [1]
00578 5 PlaySoundStop ok
00593 5 TimeoutClear
00609 5 [Pager Message 28] Send Pager Message
00609 5 RVreplace start: [$RV[Get PhoneNu]]
00625 5 RVreplace end: [4566657]
00656 5 TimeoutClear
00671 5 [Thanks] Playing
00687 5 [Thanks] Playing (Natual Voice\thanks.wav)
00703 5 PlaySoundStart ok [D:\Voice\Natual Voice\thanks.wav]
00718 5 TimeoutClear
00734 5 RunModule PLAY end
00750 5 wa(5907,80068700)
00765 5 tapie callinfo MONITORMODES
00781 5 tapie callinfo MONITORMODES
02093 0 Ready To DialOut : 1 (out of 1)
02109 6 Dialing: 94926087
02125 6 MakeCall => 66288
02140 6 TimeoutSet 60 EV_TIMEOUT_MAKECALL_NORESPONSE
02156 6 TapiCbTrigSet 66288 7002
02906 6 tapi Reply 66288 0
02921 6 TapiCbTrigClear
02937 6 tapie linedevstate 2048 0 0
02937 6 tapie callstate DIALTONE 66253 0 0
02953 6 tapie callstate DIALING 66253 0 0
02968 6 tapie callstate PROCEEDING 66253 0 0
02984 6 tapie callinfo CALLEDID
03000 6 tapie callinfo REASON
03015 6 Lev_CallerID [0000,]
03031 6 tapie callinfo ORIGIN
06687 5 Play End line[5] (id=800687)
06703 5 LsPlayMsg EV_PLAY_FINISHED
06718 5 TimeoutSet 10 EV_TIMEOUT_HANGUP
06734 5 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
06750 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
06765 5 TimeoutClear
06781 5 Hanging up call...
06796 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
06812 5 PlaySoundStop ok
06828 5 fnHangupCall end
06859 5 tapie linedevstate 2048 0 0
06875 5 tapie callstate IDLE 65670 0 0
06890 5 WorkingMode@Idle=
06906 5 TimeoutClear
06984 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
07000 5 tapi Reply 66339 0
08000 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE
08000 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
08015 5 Initialise telephony (due to IDLE)
08031 6 tapie callstate CONNECTED 66253,1,0
08046 6 WorkingModeTAPI=
08062 6 WorkingModeScript=
08093 6 TimeoutSet 2 EV_TIMEOUT_READYTOBEGINTRANSFER
08109 0 DELETE FROM CallQue WHERE ID=126;
08156 5 tapic lineDeallocateCall(MainCall:65670) 0
08343 5 Waiting for a call...
08359 5 hLine=66389
08375 5 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT
10468 6 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
10484 6 LsOutboundCall_NumericPager EV_TIMEOUT_READYTOBEGINTRANSFER
10484 6 Playing numeric pager message:4566657
10500 6 TimeoutSet 30 EV_TIMEOUT_HANGUP
10531 6 tapic lineGenerateDigits(66253,4566657) => 0
11578 6 tapie generate LINEGENERATETERM_DONE
11593 6 TimeoutSet 1 EV_TAPI_GENERATE
12625 6 Timer fired EV_TAPI_GENERATE
12625 6 LsOutboundCall_NumericPager EV_TAPI_GENERATE
12640 6 TimeoutSet 5 EV_TIMEOUT_HANGUP
13968 5 Timer fired EV_TIMOUT_ATERIDLE_ALLOWOUT
18140 6 Timer fired EV_TIMEOUT_HANGUP
18156 6 LsOutboundCall_NumericPager EV_TIMEOUT_HANGUP
18156 6 Hanging up call...
18171 6 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
18187 6 PlaySoundStop ok
18203 6 Waiting for a call...
18218 6 fnHangupCall end
18234 6 PlaySoundStop ok
18250 6 Hanging up call...
18265 6 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
18281 6 PlaySoundStop ok
18296 6 Waiting for a call...
18312 6 fnHangupCall end
18328 6 tapie linedevstate 2048 0 0
18328 6 tapie callstate IDLE 66253 0 0
18343 6 WorkingMode@Idle=
18359 6 TimeoutClear
18375 6 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
18390 6 tapi Reply 66133 0
18406 6 tapi Reply 66014 LINEERR_INVALCALLSTATE [8000001C]
19406 6 Timer fired EV_TIMEOUT_TIMETOREINITLINE
19406 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
19421 6 Initialise telephony (due to IDLE)
19453 6 tapic lineDeallocateCall(MainCall:66253) 0
19609 6 Waiting for a call...
19625 6 hLine=65689
19640 6 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT
25125 6 Timer fired EV_TIMOUT_ATERIDLE_ALLOWOUT
Here's a log file that didn't dial the message
24281 5 tapie linedevstate 2048 0 0
24312 5 tapie callstate OFFERING 65706 0 4
24328 5 tapie callinfo CALLEDID
24343 5 tapie callinfo ORIGIN
24343 5 tapie ring 0
24359 5 Answer the call
24375 5 lineAnswer(65706) => 66270
24921 5 tapie callstate CONNECTED 65706,1,0
24937 5 WorkingModeTAPI=
24953 5 WorkingModeScript=
24984 5 tapi Reply 66270 0
25000 5 tapie callinfo MONITORMODES
25015 5 TimeoutClear
25031 5 [Greeting] Playing
25046 5 [Greeting] Playing (Natual Voice\greeting.wav)
25093 5 PlaySoundStart ok [D:\Voice\Natual Voice\greeting.wav]
25109 5 TimeoutClear
25125 5 RunModule PLAY end
25140 5 wa(7180,92504600)
25156 5 tapie callinfo MONITORMODES
26015 5 tapie monitordigits 53 2
26031 5 LsPlayMsg [5]
26093 5 PlaySoundStop ok
26109 5 TimeoutClear
26109 5 [Get PhoneNu] Number Input
26125 5 [Get PhoneNu] Playing (Natual Voice\PhoneNu.wav)
26156 5 PlaySoundStart ok [D:\Voice\Natual Voice\PhoneNu.wav]
26171 5 TimeoutClear
26187 5 wa(7190,92614000)
26203 5 tapie callinfo MONITORMODES
28671 5 tapie monitordigits 52 2
28687 5 LsGetNbrsPlayWelcMsg [4]
28750 5 PlaySoundStop ok
28765 5 [Get PhoneNu] Number Input 4
28781 5 TimeoutSet 5 EV_TIMEOUT_GOTOMODULE
29015 5 tapie monitordigits 50 2
29031 5 LsGetNbrsRxDigits [2]
29046 5 [Get PhoneNu] Number Input 42
29062 5 TimeoutSet 5 EV_TIMEOUT_GOTOMODULE
29375 5 tapie monitordigits 53 2
29390 5 LsGetNbrsRxDigits [5]
29390 5 [Get PhoneNu] Number Input 425
29406 5 TimeoutSet 5 EV_TIMEOUT_GOTOMODULE
30234 5 tapie monitordigits 51 2
30250 5 LsGetNbrsRxDigits [3]
30265 5 [Get PhoneNu] Number Input 4253
30281 5 TimeoutSet 5 EV_TIMEOUT_GOTOMODULE
30531 5 tapie monitordigits 55 2
30546 5 LsGetNbrsRxDigits [7]
30562 5 [Get PhoneNu] Number Input 42537
30578 5 TimeoutSet 5 EV_TIMEOUT_GOTOMODULE
31000 5 tapie monitordigits 51 2
31015 5 LsGetNbrsRxDigits [3]
31031 5 [Get PhoneNu] Number Input 425373
31046 5 TimeoutSet 5 EV_TIMEOUT_GOTOMODULE
31390 5 tapie monitordigits 57 2
31406 5 LsGetNbrsRxDigits [9]
31406 5 [Get PhoneNu] Number Input 4253739
31421 5 TimeoutSet 5 EV_TIMEOUT_GOTOMODULE
31812 5 tapie monitordigits 35 2
31828 5 LsGetNbrsRxDigits [#]
31843 5 TimeoutClear
31859 5 fn PlaySoundStartNumbers C:\Program Files\ivg\system\voicedlgc\GetNbrsConfirmIntro.wav, C:\Program Files\ivg\system\voicedlgc\GetNbrsConfirmMenu.wav, 4253739, Digits
31875 5 twcal PlaySayNumber C:\Program Files\ivg\system\voicedlgc\GetNbrsConfirmIntro.wav, C:\Program Files\ivg\system\voicedlgc\GetNbrsConfirmMenu.wav, 4253739, , 1
31937 5 PlaySoundStartNumbers ok
31953 5 TimeoutClear
31968 5 wa(13542,93189008)
31984 5 tapie callinfo MONITORMODES
34328 5 tapie monitordigits 49 2
34343 5 LsGetNbrsPlayConfirm [1]
34406 5 PlaySoundStop ok
34421 5 TimeoutClear
34437 5 [Pager Message 28] Send Pager Message
34453 5 RVreplace start: [$RV[Get PhoneNu]]
34468 5 RVreplace end: [4253739]
34484 5 TimeoutClear
34500 5 [Thanks] Playing
34515 5 [Thanks] Playing (Natual Voice\thanks.wav)
34546 5 PlaySoundStart ok [D:\Voice\Natual Voice\thanks.wav]
34546 5 TimeoutClear
34562 5 RunModule PLAY end
34578 5 wa(5907,93453100)
34593 5 tapie callinfo MONITORMODES
34609 5 tapie callinfo MONITORMODES
35234 0 Ready To DialOut : 1 (out of 1)
35265 6 Dialing: 94926087
35281 6 MakeCall => 65853
35296 6 TimeoutSet 60 EV_TIMEOUT_MAKECALL_NORESPONSE
35312 6 TapiCbTrigSet 65853 7002
36062 6 tapi Reply 65853 0
36078 6 TapiCbTrigClear
36093 6 tapie linedevstate 2048 0 0
36109 6 tapie callstate DIALTONE 65818 0 0
36125 6 tapie callstate DIALING 65818 0 0
36140 6 tapie callstate PROCEEDING 65818 0 0
36156 6 tapie callinfo CALLEDID
36156 6 tapie callinfo REASON
36171 6 Lev_CallerID [0000,]
36187 6 tapie callinfo ORIGIN
40531 5 Play End line[5] (id=934531)
40546 5 LsPlayMsg EV_PLAY_FINISHED
40562 5 TimeoutSet 10 EV_TIMEOUT_HANGUP
40578 5 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE
40578 5 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
40593 5 TimeoutClear
40609 5 Hanging up call...
40625 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
40640 5 PlaySoundStop ok
40656 5 fnHangupCall end
40703 5 tapie linedevstate 2048 0 0
40703 5 tapie callstate IDLE 65706 0 0
40718 5 WorkingMode@Idle=
40734 5 TimeoutClear
40812 5 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
40828 5 tapi Reply 65570 0
41828 5 Timer fired EV_TIMEOUT_TIMETOREINITLINE
41843 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
41843 5 Initialise telephony (due to IDLE)
41875 5 tapic lineDeallocateCall(MainCall:65706) 0
42031 5 Waiting for a call...
42046 5 hLine=66475
42062 5 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT
43156 6 tapie callstate DISCONNECTED 65818,16,0
43171 6 LsWaitAfterDialingOut EV_REMOTEPARTY_DISCONNECT
43187 6 Answering Machine or Fax Detected
43203 6 TimeoutSet 2 EV_TIMEOUT_READYTOBEGINTRANSFER
43218 0 DELETE FROM CallQue WHERE ID=127;
45328 6 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
45343 6 LsOutboundCall_NumericPager EV_TIMEOUT_READYTOBEGINTRANSFER
45343 6 Playing numeric pager message:4253739
45359 6 TimeoutSet 30 EV_TIMEOUT_HANGUP
45375 6 tapic lineGenerateDigits(65818,4253739) => LINEERR_INVALCALLSTATE [8000001C]
45390 6 Hanging up call...
45406 6 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
45421 6 PlaySoundStop ok
45437 6 Waiting for a call...
45453 6 fnHangupCall end
45484 6 tapie linedevstate 2048 0 0
45500 6 tapie callstate IDLE 65818 0 0
45515 6 WorkingMode@Idle=
45515 6 TimeoutClear
45531 6 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
45546 6 tapi Reply 65980 0
46562 6 Timer fired EV_TIMEOUT_TIMETOREINITLINE
46562 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
46578 6 Initialise telephony (due to IDLE)
46593 6 tapic lineDeallocateCall(MainCall:65818) 0
46765 6 Waiting for a call...
46781 6 hLine=66169
46781 6 TimeoutSet 5 EV_TIMOUT_ATERIDLE_ALLOWOUT
48000 5 Timer fired EV_TIMOUT_ATERIDLE_ALLOWOUT
52265 6 Timer fired EV_TIMOUT_ATERIDLE_ALLOWOUT
Thanks.
Trace shows that in second call the paging service did not answer the call, but some sort of a message was played on the line which resulted in the call not succeeding:
Both traces show the outbound cal being made within a couple of seconds:
1)I'm sorry, I did not understand what do you mean by
What kind of message? Can you give me an example?
2)Yes, the outbound call is beening make within couple of seconds, but the message wasn't send till after 30 seconds. Do you know anyway of fixing this problem?
Thanks.
The lines in log:
indicate that some automated message was played on the line...
When 94926087 is called, does it answer and is silent usually, or is there a message played on the line prompting caller to enter the page information?
Trace shows that after call was answered the digits "4566657" get played within 1 second and that the call is hung up a few seconds later... if it takes 30 seconds for you to receive a page on the pager then the delay is caused by the pager company...
1) 94926087 is a normal phoneline, I'm just using this to check when does the system send out the pager message, since my pager never ring.
Eventually I want the system to call Telus's pager system, then when Telus picked it up, the system will just dial the message, so my pager will pick it up.
2) I'm sorry, but you misunderstood, the digits "4566657" is the message that I was trying to send to my pager, but since it never ring, so I changed the phone number to dial to a normal phoneline, so I can pick it up and listen to it, try to finger out what went wrong and also use a timer to time how long does it take for the system to dial the message. By my count, the system didn't play the message till after I picked up the call and wait 30 seconds. So now I don't understand is if the system played the message within 1 second and the call hung up a few seconds later, then why do I only hear the message beening played after I waited 30 seconds?
The trace shows that the digits were dialed a few seconds after call was answered - not anywhere near 30...
Was the trace for the same call?
You may want to test the system a few more times - it's best to look at the trace log while answering the call...
