$rv Returns Only The Last Character When A Star
I have a "capture entered number" module. The path is set so that "on star key" move to the next module. So the user might type in 123* for example.
If I then use $RV to read the value of the module, it only returns the star.
Is this a bug?
Is there a work around?
thank you
Tim
Please use an on {success} goto .... path.
If you have an on {*} goto .... path then when a * key is pressed then it is an exact match for that path and that path will be taken.
* is often used in IVR systems to indicate that a caller wants to go back up a menu, or does not want to enter anything in this module.
Usually to finish entering a number users should be asked to press the # key.
