"insert Into" Sql Statement Not Working In Msacess Db
I have been testing this simple SQL to add a single record to a Microsoft Access database table. It is not creating the record.
The Field is called "Pword_entered"
"INSERT INTO IncomingCalls (Pword_entered) VALUES ('Testpass');"
This is an Access 2007 database
I am having no problem reading from my access tables with the SQL calls from Voiceguide.
Could you please post a copy of VoiceGuide's Trace Logs which captures the call, this will allow us to see what happened.
[Log]
VoiceGuide=10
CallLoader=0
VoicemailManager=0
EmailSender=0
ktTel=10
ktTts=0
Then restart VG and make a test call.
[Log]
VoiceGuide=10
CallLoader=0
VoicemailManager=0
EmailSender=0
ktTel=10
ktTts=0
0604log.zip
Trace shows:
214310.421 12 1 db oledb ConnectAndRun_OleDb begin. Create connection: [Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\Program Files\VoiceGuide\Scripts\Local 50 Answering Machine\CallLog.mdb]
214310.421 12 1 db oledb connection open call [Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\Program Files\VoiceGuide\Scripts\Local 50 Answering Machine\CallLog.mdb]
214310.578 12 1 ERROR v7.0.3068.31216 (Mon 26/05/2008 16:20:32.16) ConnectAndRun_OleDb init : Could not find file 'C:\Program Files\VoiceGuide\Scripts\Local 50 Answering Machine\CallLog.mdb'.
Does the file 'C:\Program Files\VoiceGuide\Scripts\Local 50 Answering Machine\CallLog.mdb' exist?
Maybe try moving for now to C:\ and use 'C: \CallLog.mdb' as the filename and see if the ADO.NET layer can find the database file.
I am more familiar with Access 2003. I changed the format of the database to Access 2003 and the SQL call worked. Do you know if Access 2007 DB requires a connect string? Or is their some setting in Access 2007 I need to update?
